Do You Use The Emergency Brake When Parking?
Discussion in 'Gen 3 Prius Main Forum' started by PriusRoadWarrior, Sep 3, 2009.
  1. PriusRoadWarrior
    76
    Wisconsin
    Do you use the emergecy brake when parking or do most of you just use the "P" button? When using the "P" button, does it lock on the brakes? I have been just using the "P" button so far and my car doesn't seem to have moved when I get back. I guess I take Park in the Prius is like Park in any other car in that it will lock it down when in there. I have never used my emergency brake in any of my other cars. Responses please!
  2. anne1965
    anne1965 Gotta love the game...
    131
    Leiden, The Netherlands
    I
    You can save even more effort :) by not putting it in 'P'. The car puts itself in 'P' automatically on shutdown. The 'P' button does not activate the brakes, it blocks the transmission.
  3. eaglesight333
    eaglesight333 Senior Member
    6,956
    81
    Northern, IL
    Just use the emergency brake like you normally would, when parked on a steep hill or driveway. No need to use it for anything else. The P is all you need when parking normally.
  4. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    I always set the 'emergency' brake before I emerge from the car.
    It seems to rock somewhat if I don't and I can't imagine that being good for the transmission.
    I'm always annoyed when the oil-change guys forget to do it, but they must fix their own cars or something so it doesn't bother them...
  5. jay_man2
    jay_man2 jay_man_also
    1,246
    144
    Manassas, VA
    I do use it, but it's just out of habit more than anything else.
  6. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    I use the "P" button and not the Emergency Brake. I would as someone else suggested to use that on non-level road conditions.
    The little give for the normal "P" does not seem to bother me. In fact, I think it may be minute but minute enough that if someone should "Tap" you the give be it ever so small might be a benefit to avoid a "Tap" to a car that has the Emergency Brake engaged with no slight give...
    My personal opinion only...
    :eek:
  7. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i never use the parking brake unless i feel it necessary for complete safety precautions. iow, if parked on a slope.
    unfortunately, the parking brake is using 130 year old technology. its 100% mechanical and therefore it will wear out. for those of you that do it "by habit"...i suggest a 12 step program ASAP
  8. qbee42
    3,079
    This is my approach as well. On a steep hill, or somewhere that rolling is likely to be catastrophic, I will use the parking brake. Otherwise I don't.
    As for wearing out the parking brake, I have also had them fail from lack of use. I try to strike a balance.
  9. prioki
    prioki Member
    116
    CA
  10. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    well i also agree with that...my suggestion only goes to "habitual use". now i am located about 4 miles from the very southern tip of Puget Sound AND, i cannot swim. which means that all ground slopes toward the water. so yes, i do have a use for parking brakes anywhere from 2-10 times a month or so.
  11. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Hi I am Peter, I use my parking brake habitually. Please forgive me. lol
  12. yardman 49
    yardman 49 Active Member
    606
    77
    Northern Kentucky
    For those who live in areas where there is snow and ice, not using the parking brake is a worse thing to do. On some cars, if the parking brake is not regularly "exercised", it can become "frozen" as the linkage or cables rust. Then when you actually need it and apply it, it sometimes will not release properly, causing the rear brakes to drag, overheating the brakes, bearings, and causing a loss in gas mileage.
    Using it helps prevent such "freezing" of the mechanism. An added benefit is that if you have rear drum brakes, it lets you know if the rear pad adjuster is doing its job.
    Both Toyota and GM use a really "user friendly" parking brake: you step on it to set it, and step on it again to release it. It's so easy to do that I usually don't even think about it.
    As "exercising" the parking brake is a good thing, I will not be going to 12-step for this one. :)
  13. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    ummm Peter?? i think the correct phrase is;
    " my name is Peter and i am a "brakeaholic"
  14. ecrider
    ecrider New Member
    Maryland
    I only use Park in my own garage but use my emergency brake when parked everywhere else. Probably just superstition, but my concern with only using Park elsewhere is that a bump from another car could damage the transmission.
    By the way, the emergency brake is one of the few things I find awkward about my Prius. I often end up kicking the vinyl trim when trying to engage the brake pedal with my foot, and/or accidentally double tapping the pedal and disengaging it. Much prefer the old hand brake or foot pedal with a hand release.
  15. richard schumacher
    7,664
    1,046
    United States
    Yes. Would you rather have two tires holding your car motionless, or four? One mechanism, or two? Redundancy in safety is a good thing, and consistent use keeps it from freezing up.
  16. Sneezy
    Sneezy Member
    185
    Upstate NY
    We have always used them on all of our cars and will continue to. Here in the great north east if you don't, 1 winter will cure it of working at all.
    I don't need no stinkin 12 step program.
  17. SureValla
    SureValla Member
    590
    Shelton, CT
    I've also heard using the break is a good thing. If you don't do it it won't work when you need it. I used to use it all the time when I parked on a slight incline. Now I only use it occasionally.
  18. oxnardprof
    oxnardprof Member
    250
    17
    Oxnard, CA
    I always use the parking brake and push the P button.
    I notice that if I just shut the car off, it does go to P - but the car jerks or shudders slightly.
    I see no reason why I should not use the mechanical brake - I think of it (obviously) as a parking brake and not an emergency brake. I think the Prius design is particularly easy to use.
  19. PriusRos
    PriusRos A Fairly Senior Member - 2016 Prius Owner
    1,973
    218
    Rockville, MD
    My name is Priusros and I use the parking brake.
    And I'm proud of it.
  20. pdxrose
    pdxrose New Member
    175
    25
    I use it most of the time; ever since a friend's BMW rolled in to his garage wall a few years ago, I always hear his voice saying...I probably should stop on flat ground. If I fail 12 step, guess I know what my first extended warranty repair will be :D I was surprised to see all the items below covered, whereas virtually all of the regular breaks would not be due to wear and tear. I am not a techie so wonder if parking breaks have pads that wear out too or just the stuff below?
    Parking Brake Cable• Parking Brake Control Handle Assembly• Parking Brake Lever Subassembly• Parking Brake Pedal Subassembly•
