What is this?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by a64pilot, Sep 3, 2009.
  1. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    Hope I'm attaching a picture, I hope. It's the airfilter cover, It's upside down in the picture. In the top of it there is what appears to be another filter. I don't think that's what it is because whatever it is, it's "welded" to the cover, your not removing it, so your not changing it. It's made from a plastic mesh. I can't figure out it's purpose, anybody know?
  2. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    It's the automotive equivalent of a Native American Dream Catcher. It actually catches nightmares and filters them out before they reach your dreams. Enjoy.
  3. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    I have to assume it's a "Sealed Unit" air filter. I would assume if you can't remove anything and I have not looked at mine yet, that it get's replaced as a whole unit at the hose connection area???
    Wild Guess....but hope I am on track..
  4. Politburo
    Politburo Active Member
    971
    208
    It probably covers the permanent charcoal filter that controls evaporative emissions. Poke around some Gen 2 threads for more info.
  5. a64pilot
    771
    62
    Albany Ga.
    That's usually a cannister with a solenoid that opens for a timed interval to purge vapors from the charcoal in the cannister, but you may be correct. I'll poke around and look for a cannister
  6. a64pilot
    771
    62
    Albany Ga.
    I should have been more specific. It is immediately above the replaceable paper filter, therefore just "downstream" of the filter
  7. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    Probably an extra crud trap to stop people accidentally dropping coins, bolts, keys into the engine when the paper filter has been removed.
  8. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    That would be my guess as well--I had one on my last car.
  9. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    It will save your motor if say a mouse gets into your paper filter and chews it up, it will catch all the little paper chunks and prevent them from getting into your motor.
  10. a64pilot
    771
    62
    Albany Ga.
    If for some reason Toyota deemed it necessary to have an after filter filter for safety reasons I'm sure it would be a form of wire mesh. This thing seems awfully restrictive, which is odd. Restriction adds to pumping losses.
    I think Politburo is correct, even if it seems to me to be an inefficient way to do things.
    Have you noticed the huge resonators on the induction side of things? Somebody worked real hard to quiet the intake "honk"
  11. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    My 2004 Prius had one, so does my 2007 FJ: its an activated charcoal filter that will adsorb any evaporative emissions from the intake manifold (Some intake valves will be open when the engine is off) while the vehicle is off
  12. a64pilot
    771
    62
    Albany Ga.
    That makes sense. I would assume there aren't many vapors, but I guess a little here, a little there add up.
  13. jayman
    13,439
    641
    Winnipeg Manitoba
    On my FJ, all the intake air must be drawn through that thing. Here is a photo
    Some FJ owners have reported that under extremely dusty desert driving, with aftermarket air filters that have allowed too much dirt, they had to remove the carbon charcoal thing because it became plugged
  14. RRxing
    RRxing Senior Member
    2,545
    1,819
    NEPA
    It is definitely the carbon filter (*2 in the diagram.)
  15. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    So when we replace the air filter do we replace this charcoal filter also, or can it just be cleaned with by running water through it?
  16. jayman
    13,439
    641
    Winnipeg Manitoba
    It's not a normally serviceable part. Yanking it out won't set a CEL, but may increase evaporative emissions while the vehicle is off
  17. a64pilot
    771
    62
    Albany Ga.
    It appears that to replace it, you replace the airfilter lid. It has spots melted to the lid. Now that I know it's there, I would look there first if mileage and or power suffers as the car ages. Apparently it's in several Toyota's, and has been there for some time. Pretty safe to assume it won't be a problem as long as you use a paper airfilter
