Using head lights during the day
Discussion in 'Gen 3 Prius Technical Discussion' started by ekutter, Sep 3, 2009.
  1. ekutter
    ekutter New Member
    Seattle
    Does anybody know if there is a way to use the head lights without having the dash dim or the Nav system go into night mode? I prefer driving with my lights on all the time, especially on rural two lane roads. Unfortunately, during the day, my dash is too dim then and the nav system goes into night mode. I talked to a Toyota rep who said some states have a law preventing head lights during the day (I suspect that is not true). I believe this is a safety issue, being able to use the head lights during the day. Anybody figured out a way around this limitation?
  2. eaglesight333
    eaglesight333 Senior Member
    6,956
    81
    Northern, IL
    never heard about it not being safe to have headlights on during day. That sounds crazy.
    To answer your question. To the left of the steering wheel should be the intensity control. Just roll it all the way up, and it will over ride the nighttime mode
  3. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    Sure thing. Your lights are AUTO OFF just in case you did not know that. On the left lower part of your dash is a roller switch that controls the intensity of the dash lights when the headlamps or parking lamps are lit. Roll it to the very top (Detent positon) in other words full up position. Your dash lights and Nav will be an normal full brightness....
    When you turn off the car, the headlamps will go out in 30 seconds as set as a default.
  4. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    I would think he is referring to how DRL's are supposed to be better to aid someone in seeing you. The hard part is everyone is doing either there makeup, drinking coffee, talking on cell phones, coddling the children and that's the reason they don't see us! :)
  5. anne1965
    anne1965 Gotta love the game...
    131
    Leiden, The Netherlands
    I
    In my car, the dash adapts itself to ambient light. Meaning, if I switch on the lights during the day, the dash only dims when I drive through a tunnel. Doesn't yours do that?
    In some European countries it is mandatory to have lights on during the day for safety reasons.
  6. anne1965
    131
    I
    Is that true? In my car, that roller switch you are describing is for adjusting the height of the beam. The dashboard light brightness is a push button the right side behind the steering wheel .
  7. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    The OP is in Seattle WA USA, and the reply is from Buffalo NY USA, it is likely their cars are made to the same Government Standards. Your reply shows you in Leiden, The Netherlands, which may well use different Government Standards.
  8. anne1965
    131
    I
    How is a dashboard light dimmer switch subject to government regulation?
  9. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    U.S. Department of Transportation / Search
    Finds 24 references to Dashboard dimmer switch at dot.gov, I am not as good finding Dutch government regulations.
    So far as I know, our Department Of Transportation does not let any US citizen adjust the height of the headlight beam while driving. (we are allowed High and Low beams, on a stalk, but they are not manually adjustable)
  10. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    In some countries, like Canada for example, DRLs (daytime running lights) are mandatory. I know from experience they make a big difference to the visibility of motorcycles, and to cars. I can't imagine why anyone would think they're more dangerous.
  11. ekutter
    ekutter New Member
    Seattle
    You guys are geniuses! Thanks for all the responses. Yes, if you scroll the little dimmer wheel up to the top, it turns out you can push a little further with a click, and low and behold, it puts the display and nav system back into day mode, even with the head lights on.
    Pretty sad that I asked my dealer to look into this several times and was told you couldn't do it. I asked the Toyota customer service line and was told you can't because of there customer studies and various state laws (I told the gal that this just couldn't be the case). Finally, I told her I might choose not to buy another Toyota because of this lack of feature and she seemed unfased.
    Looks like I was just asking the wrong source. You, the people, are the real experts!
  12. fuzzy1
    10,395
    Canada began requiring automatic daytime running lights roughly two decades ago. (I'm sure a Canadian member can correct me on this.) The U.S. does not, though a significant number of U.S. market cars do have them.
    If it were true, DRLs would be illegal here. They aren't.
    I suspect someone is confusing this with highbeams. In some states -- everywhere I have lived -- daylight is no exception to the requirement for turning down highbeams in the face of other drivers. I just wish the transit buses and heavy trucks would obey.
  13. radioprius1
    radioprius1 Climate Conspirisist
    1,355
    155
    Iceland
    I'm about to just wire my headlight switch to an accessory wire so I automatically have headlights anytime the car is on.
  14. DrJon
    DrJon New Member
    140
    Pinetop, AZ
    Dang! I don't like that she is on PC to show how cool some things are/would/could be. That is so sweet! Too bad it'd be an illegal mod here but, sigh, I suppose the gov. knows better than I!:eek:
  15. SFguy2009
    SFguy2009 Junior Member
    San Francisco
    Nothing wrong with using regular headlights (not highbeams) during the day, because US 2010 Prius do not have DRLs. I have avoided many accidents as the other drivers just barely saw me, especially at or near the blindspots areas while changing lanes. At least the Auto-OFF (30secs) feature is there so you don't have to remember to turn them off every time. My 2cents ...
  16. DaveShepherd
    DaveShepherd Member
    140
    Washington, DC (VA Suburbs)
    I always have left my headlight switch on, both on my 2005 Gen II and my new Gen III. There is an "auto-off" function on both. This way I never have to think about turning them on and I am always extra visible.
    I must say I do like the auto-off function as it worked on the Gen II cars better than on Gen III. On Gen II, when the car is turned off, opening the driver's side door immediately turns off the lights.
    The 30-second delay on the Gen III works IF you have gone through the correct sequence: car must be either on or in IGN position with lights on; then car is turned off; then driver's door is opened; then driver's door is closed; and then the 30 seconds begin, after which the lights go off.
    If you do something outside that sequence, the lights seem to stay on. This has made me a bit nervous a couple times, inducing me to stand watching the car for 30 seconds to make sure the lights turn off.
    2 people like this.
  17. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Just turn them on, in a Gen 2 they turn off when you open the driver's door, in a Gen 3 they turn off in 30 seconds. No need to 'wire' anything.
  18. radioprius1
    1,355
    155
    Iceland
    My defense is that I wrote that very late at night after I had a few drinks :) I was trying to figure out all these elaborate schemes to wire them to turn on automatically - LOL. Oops! :)
  19. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I test drove a used Prius before buying, the Owners Manual had sections like Daytime Running Lights (If so equipped), etc. I emailed Toyota to find out how to get one so equipped, they had no clue.
    Email Toyota
    My salesman, who owned two Prius, knew the right answer. So I had help. I have not had the lights turned off since I drove off his lot.
  20. DaveShepherd
    DaveShepherd Member
    140
    I haven't turned the headlights off on my 2005 (bought in September 2004) for five years. They're always turned on.
    I did have a bit of weirdness this morning after parking my Gen III at my work. For some reason, I must have interfered with the sequence I described above, because they didn't turn off after 30 seconds as I expected them to. I got back into the car, closed the driver's door, turned it on, then turned it off and exited. Then they turned off automatically.
    I just know I'm going to run the aux. battery down by messing this up someday. I'm not yet to a sufficient comfort level where I just walk away from the car with the lights still on.
