Bolt-On Receiver Hitch
Discussion in 'Gen 2 Prius Main Forum' started by The Ericsons, Jun 9, 2005.
  1. The Ericsons
    The Ericsons New Member
    59
    Illinois
    We want to take our bikes on the Prius and found a place, Coastal Electronic Technologies, Inc. in Florida that makes a bolt-on receiver hitch especially for the car. Has anyone used one and is it easy to install by owner? Is there any hitch that is better?
  2. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    Coastal is well known on this forum. They have great products including the bolt on hitch however if you will notice there have been numerious complaints about delayed delivery. This is probably due to the popularity of the Prius and that they are flooded with orders. Regardless of delivery interval they do not process your card until the item you have ordered has shipped.
  3. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    I use a hitch custom made for the Prius by DaLan. Its a bolt on receiver type, and the only mod needed on the car is to cut a hole in the plastic underbody panel to make room for the mounting. I bought it from hitchweb.com. I think it was about $150.
    I actually use the hitch for towing a small trailer with my shifter kart on it, and it works fine.
  4. KTPhil
    KTPhil Active Member
    1,379
    Just received it, and I'll install it this weekend. I expect to use it for a bike carrier, and perhaps a homebuilt storage box for vacation use.
  5. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    I've got one on my '02 for my wife's wheelchair carrier. I eventually plan to put one on my '04 as well. Both from Coastal.
    Note: Coastal's hitches do not have loops for safety chains, so those who are willing to overlook Toyota's recommendations and are looking to tow will have to get creative or look elsewhere.
  6. alsgameroom
    alsgameroom Member
    117
    Northern New Jersey
    I am under the understanding that if you tow any type of trailer without saftey chains you are in violation of the law. Its "Failure to secure a Load" or similar depending on the jurisdiction.
    Check your states laws before towing without saftey chains..or maybe check your brain :) this is just not a good idea!
    Al
  7. seasalsa
    1,278
    Kent, WA
    <div class='quotetop'>QUOTE(alsgameroom\";p=\"97125)</div>
    True, however there are several uses for the bolt-on receiver hitch other than towing a trailer. Possibly that was the reason that Costal left loops for safety chains off their receiver.
  8. hawkjm73
    hawkjm73 New Member
    258
    Phoenix, Arizona
    <div class='quotetop'>QUOTE(htmlspinnr\";p=\"97111)</div>
    I can't help but wonder. Why can a person not just loop the safety chains around the body of the hitch reciever? (I have never towed anything at all, so I really don't know)
    I love my Costal hitch. I carry my bike around on it often. The installation was a breeze, with the only hard part getting the oem bolts loose.
  9. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    Hey Rick, can you give me some info on your wheelchair carrier, like what it can carry, where did you get it, and how much? I'd like an alternative way to carry my friend's wheelchair, especially if we ever go on a long trip and take her service dog.
    I'd PM you for this, but others might appreciate the info as well. I am going to try improvising using a bicycle carrier as many have suggested by renting one, once I get a hitch.
    By the way, I finally did carry her, the wheelchair and the dog without issue. Other than the dog making paw prints on the seat. Oh well, the things you'll do for love. I expect it to clean up OK though.
    Because of the wheelchair, I have to fold down the small seat. Epic (dog's name) looked like he considered going into the hatch where the seat was down, but the wheelchair being in the way had him reconsider.
  10. HTMLSpinnr
    5,341
    920
    251
    My wife, who has MS, uses a folding Quickie2 type power chair for extended outings when walking would be too taxing.
    The carrier we use bolts onto a 1¼" hitch mount - we opted to use a 2" step up type that came w/ her previous draw-tite hitch on her old Hyundai Elantra GT wagon in order to keep the carrier from bottoming out on steeper driveways.
    The carrier itself is a folding type which tilts forward parallel with the back of the car when not in use to reduce length, and is secured with a spring pin (? for lack of better term). When in use it lies flat, carrying the folded chair sideways with the chair back to the car's left. To load the chair, a second spring pin can be released to allow the carrier to tilt to the left in order to load the chair. Once the chair is mounted, a bracket of sort with a hook and friction locking strap is used to secure the rear wheel by clamping down from the top. A second strap with hook and friction lock is used to strap down the front portion of the chair.
    We do take an MPG hit when carrying the chair on the '02 because the chair back adds additional drag.
    I'll see if I can't find the brand name of the carrier.
    The battery pack is then stowed in the trunk area.
