Instrument cluster went out
Discussion in 'Gen 3 Prius Main Forum' started by patflanagan, Sep 4, 2009.
  1. patflanagan
    patflanagan New Member
    62
    Suburb of Chicago
    While driving home last week the instrument cluster that displays the gas tank and speed went black. It just completely went out. I drove to the local Toyota dealer and they told me that there was a bad batch of boards and would order a new board. The following Monday (last Monday) they replaced the board and the screen/cluster is working again. However, it is now not as bright as before during the daytime if I have the lights on.
    Anyone else have a similar problem?
  2. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    Did you turn the little dimmer wheel all the way up until it clicks. It stops then it has one additional setting. Give it a little push until it clicks.
  3. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    All the way up forces day-time mode, all the way down turns off the display completely.
  4. patflanagan
    62
    Suburb of Chicago
    I guess the reason I posted this was to see if anyone else experienced the cluster going completely out. They replaced the board and it really was no inconvenience other than being without my car for half a day and they did give me a loaner. I did rotate the control wheel and it helped but still different than it used to be.
  5. dmvp
    dmvp Member
    364
    Outskirts of Chicago
    I remember someone posting an exact scenario on the day he purchased his car. From down South, if I recall correctly. Bought it in one state and it went out as he approached his home state. Other than that, I don't think anyone else on PC has noted this.
    If they know that there is a bad batch of boards...I'm surprised there isn't a recall. Odd.
  6. jay_man2
    jay_man2 jay_man_also
    1,246
    144
    Manassas, VA
    Bad batch doesn't mean every board is bad. Gotta wait until they fail to find the bad ones in the batch.
  7. Randall Rash
    Randall Rash Member
    149
    25
    Rockwall, TX
    Could be that the "problem" with the board was that it was letting it burn to bright, and like a shooting star, poof. Lights out.
  8. dfran1
    dfran1 New Member
    89
    17
    MA
    I Wonder if this is the correction for the blurry (double image) speedometer/gas gauge.
  9. robnbill
    robnbill Junior Member
    Fairfax, Va
    I turned a corner the other day and the eco light over the eco gauge went out. It would not come on again although the eco bar continued to work fine. I got home turned the car off. The next morning and since the lights have worked fine.
    Don't know what happened. I am just waiting to see if it happens again.
  10. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    Anyone have any Data on when these boards were installed or a manufacture date for their vehicles? Were these early deliveries or deliveries as late as August 2009? Did Toyota have any comment on dates or VIN's affected?
    Thanks
  11. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Hmm, I wonder if it'll be another poorly designed connector
    that will plague the 2010s and give rise to thousands of forum
    postings and a few reverse-engineering projects...
    _H*
  12. LaurenceRooks
    LaurenceRooks New Member
    Arlington
    The same thing happened to me as I was driving my friend's 2010 Prius. How much did it cost for them to replace the board?
    Thanks.
  13. angelrob
    angelrob New Member
    94
    Rochester, NY
    I keep getting the intermittent buzzing sound when the panel is not on full brightness. If I turn the lights off and back on, or turn the panel lights all the way up, it stops. It's on my list to have the dealer review at my first visit.
    Robbin
  14. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    I'm going to make a wild leap in the dark here and say that it was covered 100% by the warranty.
    Your friend should take it to the dealer to have it fixed.
  15. timo27
    timo27 Member
    316
    52
    Baltimore, MD
    The same (or something similar) happened to me yesterday. I wodered if it had been doing this all along, and I just noticed it for the first time. Any others experiencing this? Any resolution?
    Thx,
    Tim
  16. jay_man2
    1,246
    144
    Manassas, VA
    Don't go getting wild and crazy on us now. :pound:
  17. hobbit
    4,089
    469
    Bahstahn
    The "rheostat" for the dash lights isn't actually one in the
    classic sense, but a little PWM circuit -- see this pic of the one
    in an '04. It chops at around 200 Hz, if I remember right, which
    would definitely produce audible noise if it was passing current to
    anything that can physically flex in response to electrical power.
    You'd be surprised what kind of components can go "microphonic"
    sometimes; I would easily believe it causing other parts to become
    noise sources.
    _H*
  18. mwetter
    mwetter Junior Member
    Utah
    I had the same problem. I took it back in for a new board. Apparently there have been several cases of this happening. Hopefully not a trend.
  19. Spartane
    Spartane Member
    149
    43
    Mississauga, Canada
    This sounds like you may have done one of two things:
    1. Switched to PWR mode.
    2. Accidentally bumped the shifter and changed it from "D" to "B". Another side-effect for "B" is that the cruise control will not engage.
    I believe the ECO light goes out while you're in either "B" or PWR mode.
  20. Vincent
    Vincent Don't Wait Until Tomorrow
    641
    31
    South Florida
    Have you checked to be sure something hasn't slipped down the dash and is covering the speedo/gauge projector lens. Remember, you're actually looking at an image projected on a mirror from below. I freaked out a few weeks after I got my 06 when a car wash receipt drifted down over the projector lens and it was lights out for a few days until my service manager made me feel like a fool.
