Does anyone use the Voice Commands?
Discussion in 'Gen 3 Prius Main Forum' started by dogllama, Sep 8, 2009.
  1. dogllama
    dogllama New Member
    118
    Los Angeles
    I have been trying to use my fancy voice commands to dial phone numbers in my Gen 3, but I am getting frustrated with how many steps it takes to dial.
    Step 1 - Phone
    Step 2 - Dial by Name
    Step 3 - Say Person's Name
    Step 4 - Confirm Person's Name
    Step 5 - Dial
    On top of this the computer repeats what I just said along every step.
    Why not just let us say "Call so-and-so".
    In the end I am pulling my phone out my pocket to dial and just using the bluetooth to talk so I don't get a ticket. I would use my contacts to dial, but the damn thing locks me out while I am moving....
    Does this bother anyone else?
  2. eglmainz
    eglmainz New Member
    887
    141
    Chicagoland, IL
    While I do use the voice commands, hat can get tiresome.
    Instead, I have programmed like 14 of the 18 'speed dials' on the NAV screen, and when I need to make a call to one of my contacts, I simply hit the call button on the steering wheel, then click with a quick finger on the 'speed dial' button, then the name I want, and it goes very quickly. Try doing that instead, and it should help you for the top numbers that you call.
  3. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    It a major pain in the a$$$
    I am also have a hard time with it
  4. qbee42
    3,079
    I also use speed dial, but in general I try to avoid talking on the phone while driving.
  5. Indyking
    Indyking Happy Hyundai owner...
    1,280
    I don't know... Indy, Chicago, Madison (WI)... it
    It appears that you're talking about the voice commands for Bluetooth. I don’t have the NAV, but have the speed dial feature programmed in the sound system interface. I just hit the call button, and then quickly hit my preset speed dial number, then the off hook switch and it places the call... quick and simple! I also found placing a call by voice very annoying and tiresome; especially because the bloody system often don't understand a word of what I say… :D, therefore I end up having to put up with my American friends that keep teasing me saying that the problem is my thick accent :mad:.
    Losers…
  6. LoraJ
    LoraJ Active Member
    507
    68
    2018 Prius Prime
    Do you have the guidance turned off?
  7. dogllama
    dogllama New Member
    118
    Los Angeles
    Yeah I do have the guidance off.
    Programming the speed dial with as many as I can fit numbers does seem like a good work around for most of the time. Just wish I could shorten the guidance feature to 2 steps max. Thanks!
  8. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    I also added frequently called numbers as speed dials. Press the unhook button on the steering wheel once and you can then press the speed dial icon on the screen, or press the button again and it takes to your recent calls, and you call select one of them.
  9. jaywolf
    jaywolf Member
    107
    Vincennes, IN
    Dial by number really sucks, it you hesitate just a second it dials
  10. bps
    bps Active Member
    304
    119
    Dial by number works great for me. You don't have to wait for the voice to answer back or confirm. Just say "Dial by number" and then immediately press the voice button again. Then say the number and immediately press the off-hook button. It will dial the number as soon as this is complete. It really is quick and simple...
    Bryan
  11. djasonw
    djasonw Active Member
    962
    123
    Coconut Creek, FL
    Some of the Non Nav voice commands are overkill. I don't every recall issuing the command "68 degrees".
  12. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    only use voice commands for dial by number options. well to be honest with ya, i really only call a small handful of people on a regular basis. speed dials takes care of that, but most of the time, i use the speed dial directly from the phone
  13. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    I didn't think that the procedure was all that cumbersome but I had to wait to get to work to verify if the process was as long as being noted herein.
    Actually it takes less than 5 sec with two clicks of the 'VOICE' icon, two voice commands and one click of the OFF HOOK switch.
    • Touch the VOICE icon, wait a heartbeat, say "Dial by Number ( or Name )"
    • The system begins to verify that you've chosen 'DIAL BY NUMBER', cut if off immediately by touching the VOICE icon again.
    • Say the desired number, "XXX-XXX-XXXX", wait a heartbeat
    • Touch the OFF HOOK switch.
    You don't have to wait for the nice Nav lady to go through all the options on each level of the menus. Simply touch the voice icon and you'll drop down to the the next level of menu commands.
  14. waters511
    waters511 Junior Member
    Memphis
    I discovered on accident that if you push the voice command button and say a name that happens to not sounds like any of the starting out commands, it will recognize it - repeat the name and you just push the dial button and go. =0)
  15. checo446
    checo446 New Member
    35
    Dallas, TX
    Yeah on the names i have programmed in, I just push the voice command and say "Dial <Name>", it confirms it with saying push the off hook command to connect. It works just about every time.
  16. rstark18
    rstark18 Member
    442
    75
    Los Angeles
    I use some speed dials for my most frequent numbers but I do use voice commands for other and it's pretty quick for me.
    The first thing you have to do is turn off the feedback so nav doesn't say the menu names. Then just say dial by name, it beeps, then say the name.
  17. Zythryn
    Zythryn Senior Member
    6,408
    4,407
    While the number of steps is frustrating, calling the wrong person would be far worse in my opinion.
    That said, I typically don't call while driving. On the rare occasion that I do I use the speed dial.
    For voice commands, I frequently use them to zoom out and in, show restaraunts, show parking. That is about it.
  18. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    The voice commands work fairly well. I would as many have suggested setting those "frequent contacts" in speed dials, then you can say "CALL SUE" for example.
    The secret to not have to listen to the guidance prompts each time is to hit the TALK button a second time each time and it skips it. It's still nice to have that option when you have a "brain fart". ;)
    But hitting the TALK button a second time works great to stop the repetitive commentary.
  19. nparker13
    nparker13 Member
    121
    CT
    There is a setting that disables that.
  20. bighouse
    bighouse Active Member
    822
    126
    Guerneville, CA
    Are there voice options for the Nav System? I'm hoping I can switch mine out to a Cylon Battle Centurion circa 1979 or so...
