2001 Prius - dead battery with continuous horn
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by NYCpriusdriver, Sep 7, 2009.
  1. NYCpriusdriver
    NYCpriusdriver New Member
    New York City
    2001 Prius
    Hi everyone,
    I hope this is the right forum for this. I've searched everywhere and haven't found the specifics of my problem so I feel there might still be hope. I live in New York City and rarely drive my 2001 Prius at all since I moved here 4 years ago. Before that I used to drive it a lot more, but it still only has 50,000 some miles on it.
    I've been trying to take it on a good drive at least once a month. Sometimes I need to hook up a charger to the 12v or use a booster battery to get it going. This has worked up until now.
    A couple weeks ago I started it with the booster and let it run until the engine shut off. I know this doesn't completely charge everything but I turned it off and it started again without the booster. So then a week ago I tried to start it again with the booster and got nothing except the hazard lights went on solid.
    Since then I've been charging it with a Vector 2/6/10 amp charger on the 2 amp setting. After over 12 hours of charging it said it was charged, but if I disconnect the charger and connect it again after a while it still takes more of a charge.
    Before I got the 12v supposedly "charged" and again after, at a certain point the horn would come on and stay on continuously. I either had to wait for it to drain the battery enough to shut off or disconnect the battery which I finally did. Now I'm charging the 12v by itself, when I connect it I still get nothing, no lights, nada, but if I hook up the charger while it's connected then the horn will still come on.
    It would at least start two weeks ago. I highly doubt the traction battery has completely died in that time. The 12v battery was replaced less than three years ago so I could just need a new one but I'm hoping I can get at least one more start out of it so I don't have to get it towed. Any thoughts? Any advice much appreciated. (Also if anyone is really interested in acquiring a first gen Prius considering the above, please send me a PM).
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  3. NYCpriusdriver
    New York City
    2001 Prius
    Thanks, but I didn't see any first gen forums on this site. I started to post in the newbie forum (even less technical I figured) and it came up with similar threads involving 2001 Priuses, all in the Gen II forums. If a mod could move my thread to the appropriate forum that would be great.
  4. Patrick Wong
    18,210
    6,510
    It sounds like your 12V battery is dead, but I am also wondering why the horn is sounding when the charger is connected. Do you have an aftermarket alarm system installed?
    To verify that the battery is bad, assuming that you don't have access to a voltmeter, you could try turning on the headlights to see whether the lights are at normal brilliance (with the charger disconnected). If the lights are dim, that is strong evidence the battery is dead or close to it.
    It's generally not a good idea to use the "booster" function of the battery charger to start the Prius. The reason for this is that the voltage produced by the charger under that condition is relatively high, and may damage the Prius ECUs. If you follow the Toyota TSB advice on battery care, you are supposed to disconnect and remove the 12V battery from the car before charging it, to eliminate any possibility of damage to the vehicle.
    To avoid having to tow the car, is it reasonable for you to take a cab to a local Toyota dealer so that you could buy the correct 12V battery and install it yourself?
  5. NYCpriusdriver
    New York City
    2001 Prius
    No, it's the same one it came with. Before when I've brought it back to life the alarm system would come on with the horn intermittent, but something different seems to be going on here.
    For the last couple weeks I haven't been able to get any lights to come on at all. No trunk light, no dome light, nothing. Just the horn. I managed to dig up a voltmeter and it read 14~ with the charger (the charger also has this function) and 12~ when I took the charger off. I also got a quick 10A reading along with a spark but I didn't want to risk blowing my meter. Seems like it's still got some juice in it and the capacity to hold some.
    The booster and the charger are two devices I bought separately. I've never had them hooked up at the same time. I'll keep that in mind for the future about disconnecting the battery before charging it but it hasn't been a problem up until now. I assume the booster is just a smaller battery which you charge separately and the Prius just draws whatever it needs from it when you hook it up.
    I could probably even take the subway, but with the battery appearing to at least hold a charge for a little while it makes me wonder if something else isn't going on. There may well be a problem with the ECU or another computer component that only a dealer would know anything about. Maybe there's just a fuse that needs replacing? Thanks for the help so far.
  6. Patrick Wong
    18,210
    6,510
    Yes, this would also explain why the car is not starting. It sounds like you will need to check the fuses by removing them one by one and measuring each fuse's resistance with an ohmmeter. The resistance of each fuse should be very close to zero.
    If you can find the DOME fuse (which powers various instrument panel circuits, i.e., much more than just the dome light) you'll may find that it has blown. If that fuse is OK, then another fuse upstream from that (or maybe a fusible link) is probably the problem.
    As I'm traveling currently, I don't have access to the wiring manual. If you have trouble finding the fuse(s) that need replacing, you might want to consult your owner's manual. If you can read the wiring diagrams, you may want to download them at techinfo.toyota.com
    If the "booster" is just a compact-sized 12V battery, then no worries about its use on Prius.
    Good luck.
  7. NYCpriusdriver
    New York City
    2001 Prius
    Thanks. I think this got me over the hump. I didn't really know where to start with the fuses and most of the big ones are opaque. Upon examination, three 15amp fuses are visibly blown. DOME and also AM2 and THRO. A visit to the auto parts store tomorrow during lunch should take care of this. The battery is now charging at a steady 2.2-2.3 amps so maybe it got past its false charged state and will be full by tomorrow.
    Thanks again. I'll post a follow-up to help out the few others out there still driving around in first generation Priuses.
  8. Patrick Wong
    18,210
    6,510
    Pls note that the fuse physical size is non-standard, so your local discount auto parts store may not have the right replacements. I suggest you bring a blown fuse when shopping. You may need to visit your Toyota dealer to obtain the correct fuses.
    I hope that the replacement of those three fuses helps, but I am concerned that a fusible link may also have blown. Then there's the question of why the fuses popped in the first place?
  9. tochatihu
    tochatihu Senior Member
    9,783
    3,769
    Kunming Yunnan China
    2001 Prius
    Hate to mention the possibility that blown fuses could have resulted from an accidental polarity reversal when connecting the external power source.
  10. NYCpriusdriver
    New York City
    2001 Prius
    No, no polarity reversals but they may have blown either from the booster battery or from briefly having the charger on the 6 and 10 amp settings. Stupid, I know, but I just wanted to get it going and wasn't going to do it very long. I learned my lesson. Also I had gotten in the habit of boosting it with the key set to "on" so the alarm wouldn't go off. No more of that either.
    So here's the latest:
    The fuses did the trick and now it starts. But only for a few minutes, then it kind of sputters and shuts off. Trying to start it again kicks on the horn, windshield wipers and maybe an engine alert or two. I left the battery charger on overnight and it switched to automatic float charge, but I didn't want to leave it on during the day while I was gone so I disconnected it. Tried it after I got home and put in the fuses, it started but didn't last so I charged it some more and hooked up the booster.
    It seems to do okay with the booster connected but I don't think the battery can hold a good charge or maybe it isn't charged sufficiently to where the alternator (or whatever it is on the Prius) can keep it charged. I'm guessing it may have been deep cycle discharged, which I've read conflicting things about whether or not that means it's toast. It was replaced I believe in late fall 2006 so it's still less than three years old. Right now the battery is back to drawing 2.5 amps or so from the charger and I can try that for a few more days. After a little more playing around I'll probably try and drive it to the dealer, maybe with the booster connected the whole way but taking local roads in case it completely dies on me en route. Surely even on the '01 Prius they thought of some way to automatically test the integrity of the 12v battery so it doesn't die in the middle of the road???
  11. tochatihu
    9,783
    3,769
    2001 Prius
    Good news on the startup - it excludes some scary options. We have to get you on a known-good battery. Are you aware of the throttle butterfly and induction cleaning procedures? Do you have sufficient fuel in the tank?
    Sorry, I know of no other long distance approach than taking tiny steps.
  12. Patrick Wong
    18,210
    6,510
    Glad to hear you are making progress.
    If your booster is just another 12V battery, then I think you should try disconnecting the Prius 12V battery, and rely solely on the booster battery. See if that helps or not.
  13. NYCpriusdriver
    New York City
    2001 Prius
    Throttle butterfly and induction cleaning procedures? Don't know anything about those but if you can point me to a good source I'm willing to give them a try. The tank is almost completely full, still has all ten bars on it.
    The booster battery is a Black & Decker somethingorother, I don't have the specs in front of me. It's smaller than even the Prius battery. I think it says it can deliver a maximum of 200 amps. I'll have to look and see if it says anything about driving on it as the sole 12v battery (of course they probably don't address driving on it in combination with the HV battery). If I did drive it solely with the booster battery, I wouldn't want to do it for very long.
    One thing I haven't had time to do yet is start it after the 12v battery has just been completely topped off by the charger. If it drains while it's not charging during the day then I'm guessing it either still has a long way to go to be fully charged or it has serious problems and needs to be replaced. Hopefully I will have time by this weekend to try this but a rain forecast in the next few days is going to complicate things, although I might be able to cover it with a tarp. In the meantime I'm just going to keep charging it whenever I can, assuming the charger is smart enough not to damage it by overcharging at 2 amps.
  14. tochatihu
    9,783
    3,769
    2001 Prius
    See Bob's how to:
    Cleaning Prius Throttle
    If your Prius battery cannot hold a charge it needs to get gone. Lead recycler, or doorstop.
  15. NYCpriusdriver
    New York City
    2001 Prius
    So I'm going to give this maybe one more try before I break down and take it to a dealer. Again, sorry this is in the wrong forum. I swear I didn't see the Generation 1 forum before (maybe the link was different?)
    I went ahead and ordered then installed the Miata battery from eLearnAid and it seems fine. It was testing at 12.6v out of the box so I didn't charge it any more initially. I installed it Wednesday, it started fine and seemed to stay running so I shut it off. Saturday I took it out on an errand for about an hour. No problems during the trip except what I had been neglecting to realize was a bigger problem this whole time: since I replaced the fuses, the interior lights work and everything comes on when I turn the key to ON, but in ACC mode none of the accessories or anything come on. I did notice a whirring sound of some sort when I hold it in ACC mode, then when I turn to on the engine starts along with a brief beep from the horn and the windshield wipers wipe once. This behavior has been consistent with both the old and new battery since I replaced the fuses.
    To top it off, when I got back from the errand I left it running for a while and the engine stayed on longer than I thought it should while I was trying to call Car Talk (didn't realize they call you back first and don't take live calls). It seemed to sputter and die during this time and when I tested the voltage it was only about 11.5. I broke out the charger and charged it overnight and got it up to 13.5, and then I got a ! triangle after starting it but still nothing when the key is on ACC. The battery charger does have an alternator check which I tried and it came back bad, but it does say your specific model of car may have crazy electronics which are not compatible with the alternator check.
    So it appears the 12v battery is not being charged, and I can only assume this is related to ACC not coming on. I've tested the ACC fuse along with most of the others and they all have low resistance, and all of the non-opaque ones visually look good.
    note: I know this is already long-winded, but for anyone who cares about the surrounding details: if possible I need to take this car on a 1,000+ mile trip in late November to be inspected in another state. I'm hoping against hope that since I'll have to take it to a dealer then anyway, I can just wait until then to have any major issues looked at in one shot. Bad idea?
  16. Patrick Wong
    18,210
    6,510
    If the radio and other accessories don't work when the key is at the ACC-ON position, then you must have more fuses that are bad, or a bad relay.
    Prius does not have an alternator so please do not use any tests that are not intended for that car.
    Do you have a digital voltmeter? If so, measure the voltage across the battery when the Prius is READY. What voltage do you get?
    If ~13.8V then the 12V battery is being charged. If much below that, then the battery is not being charged and the DC to DC converter within the inverter is probably bad (or the DC/DC 100A fusible link has blown).
    There's no way you will be able to drive 1,000 miles in that case, you'll have to seek help from a local Toyota dealer.
  17. tochatihu
    9,783
    3,769
    2001 Prius
    I hope it's the fusible link! perhaps we don't have a good how-to on testing or replacing that. First use your owner's manual to identify the correct under hood fuse box. Disconnect the 12 volt. Unbolt the fuse box and test the connections underneath for continuity.
  18. EZW1
    EZW1 Active Member
    722
    81
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    Note: My owners manual says to adequately charge the 12V by letting the car idle, you've got to leave it on for 1/2hour. Most people do the 5 to 15 minute thing and that may not be enough.
  19. NYCpriusdriver
    New York City
    2001 Prius
    Thanks everyone for your help, but I made an appointment to take it to the dealer tomorrow morning. Since I know I can at least drive it that far I think I'm just going to do it. I tested the voltage with the engine running and it drops down to about 11.5v so I don't think there's any way it's charging. I tried to take the 110A DC/DC fuse out to test it and ended up popping the clear plastic cover off. At least I saved a few bucks and hopefully got a better battery with the Miata battery. If they try and charge me an arm and a leg for something that's simple and possible to do myself, maybe I'll give it another go. I'll let you know how it goes.
  20. Patrick Wong
    18,210
    6,510
    My guess is that the inverter has failed. If so, then the dealer will probably charge you around $3K to replace it.
    An alternate approach would be for you to buy a salvage part for $1K and install it yourself.
