Maybe I'm hallucinating!
Discussion in 'Gen 2 Prius Main Forum' started by Teris10, Sep 25, 2009.
  1. Teris10
    Teris10 New Member
    Beverly Hills, CA
    Hi all. I was having a problem with the passenger side headlight on my 2007 Prius (Touring model). It would fade out and go off. I'd have to turn the lights on and off to get it to come back on.
    I brought my car in for service and the problem was fixed. However, I no longer seem to have a feature I once had. I was sure that one of my settings for my headlights was an "auto" setting, even thought it wasn't labeled as such (it was labeled with just a round dot on the controls).
    Now the dot setting only puts on a couple of yellow lights and some interior lights. I never kept the headlights on all the time (mainly believing that they would drain battery during the day unnecessarily). I checked the manual and it says that the "dot" is not an auto setting.
    But I know for sure that when driving through tunnels, etc., my headlights would come on by themselves. Has anyone else have this option on this model Prius or am I losing my mind??? :confused:
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Auto headlights are not available in the US, only in Canada. Cut back on your meds... :)
  3. Teris10
    Teris10 New Member
    Beverly Hills, CA
    Wow, you are confirming my worst fears. I hallucinated my headlights coming on when driving through tunnels. Now I don't know if I should cut back on my meds or double the dosage...
  4. Genoz World
    Genoz World ZEN-style living
    797
    22
    La Canada
    DOUBLE the meds. That always helps! (sarcastic)
  5. qmtran
    qmtran Junior Member
    87
    Seattle, WA
    As the other guy mentioned... US models do not have the auto light function. The dot is to turn on your parking lights. If you are sure you have the Auto Light feature, on your dash, in the far left corner, you should see a dome like sensor. If you have this, maybe you do have the feature minus switch.
  6. Teris10
    Teris10 New Member
    Beverly Hills, CA
    Qmtran - thanks for the reply. I DO have the sensor! Now I just have to figure out how and why Toyota disabled the auto feature when I brought the car in for service and how (or if!) I can get it turned back on!
    Why would Toyota put in the sensor and not have the feature properly marked on the headlight controls?
  7. Teris10
    Teris10 New Member
    Beverly Hills, CA
  8. qmtran
    87
    Seattle, WA
    Buy proper relays and a new headlight switch(canadian model) should resolve your issue.
  9. firepa63
    1,761
    208
    If you have auto headlights you will have 2 sensors. One is for the climate control and the other would be for the headlights. Do you have 2 sensors?
  10. Teris10
    Teris10 New Member
    Beverly Hills, CA
    Okay, I didn't realize that. I'm not sure. At the driver's side of the dashboard by the windshield, there is a sensor and a round hole (I haven't looked into it, so I don't know what's in it). I assumed that sensor was for the headlights, but maybe I'm wrong.
  11. firepa63
    1,761
    208
    If you have a Prius built for sale in the US, you never had auto headlights. Toyota never built that feature into the US Prius.
