2010 Prius Mud Flaps???
Discussion in 'Gen 3 Prius Accessories and Modifications' started by laufaye, Aug 16, 2009.
  1. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Chill dude IT IS a chat room. Don't read the posts if you don't want to. :rolleyes:
  2. Snowbell
    Snowbell That's the cat! Snow...
    67
    Putnam County, NY
    Clearly, you were interested enough to take a look yourself.
    It's just harmless chat...it's all good. :)
  3. clearbraj
    clearbraj Junior Member
    Palm City, Florida
    FYI - as an alternative to the flaps you can install XPEL or 3M paint protection rocker panel kits. You can have the installer wrap into each fender area. Looks great w/o flaps. This is also great protection with the flaps since the kits goes from frt to rear and back behind the rear wheel.
    www.clearshieldprotection.com
    clearbraj
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Do you have it on your vehicle? If so, how much did it cost?
    Thanks,
    Peter
  5. zjkozlica
    zjkozlica New Member
    Chattanooga,TN
    Hi TOP KICK, good job on mud flaps. I have Prius III also and it is same color like yours, you have sad that you have clear bra do you liket I am thinking to instal one. Thnak you for you info.
  6. topkick
    topkick Member
    166
    Oklahoma City
    Yes I had it installed about 4 weeks after I purchased my IV and I would not have a Prius without a clear bra. I also had one on my black 2007 but not till after I got a few dings on it.
  7. hotbrass
    hotbrass New Member
    312
    35
    Cowtown
    Installed my flaps today. Didnt remove the rear tires and it was not really a problem since I have a phillips head driver for my ratchet. Otherwise it would have been more difficult getting the screws straight.
    The flaps seem kinda flimsy for costing $116. If anything ever gets hold of them on the road like a stick or something, they will rip right off. Which I guess its better than tearing the rest of the car up. I still think they are not fastened securely enough and may add a couple more screws.
    As far as looks go, you dont even notice them.
    3 people like this.
  8. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Got mine on today too. I think they will hold just fine. Never had on fall off any of my other vehicles.
    Just in time too, got snow low on the mountains this weekend.
  9. Star gazer
    Star gazer Junior Member
    43
    Maryland
    I have looked at my Prius and also at the pdf instructions kindly listed earlier in this thread. I can see the pre-drilled holes in the front wheel wells, but not in the rear wheel wells. Is there any drilling involved in the installation? I have an offset ratchet with the phillips head, but want to make sure I know what is involved before ordering these. I do not want to drill holes in the metal as I am worried about rusting/corrosion which would not be covered by the warranty. Plus I would be afraid to personally drill a hole in my Prius! :eek:
  10. rachaelseven
    rachaelseven New Member
    616
    212
    Adams, MA
    The rears screw into the plastic bumper cover and undercover, not into metal. And you don't really need to drill the holes at all, just poke the screws right into the plastic. You can make a pinprick with an awl to make them easier to start if you want, but you can just jam them right through if you've got a good wrist.
  11. bighouse
    bighouse Active Member
    822
    126
    Guerneville, CA
    I should be getting mine in a couple of days based on what others have said here.
    Has anyone noticed any change in MPG after the mudflaps are installed?
    I'm looking forward to this as my first "mod". Not only will it function to help keep road dirt off my paint, but I think they make the car look sportier, like it's hugging the road a bit more.
  12. Mark57
    2,945
    2,740
    OK
    No detrimental effects. My mileage has gone up after the install due to refining my driving techniques. If they were a problem, I don't think I would have seen the large positive gains in mileage I've seen since the install.
  13. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    I put the car in a test chamber wind tunnel at JPL. We did a quick run at both 30 and 60mph velocities (car suspended by an eye bolt to the center beam of the roof - measuring displacement), and found the mud flaps cause the car to actually move forward. The net result is a positive influence on mileage.
    While it isn't directly quantifiable, we estimate a 12% improvement on mileage. That translates to a 6MPG improvement on a daily driver who averages 50MPG!!!!
    When we get more lab time, we're going to try the shark fin antenna next...
  14. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I installed my this weekend and I am down about 1-2 mpg it seems. This could be because of the colder temps we are now having (29F this morning). Hard to tell.
  15. el723
    el723 New Member
    PA
    Seriously? That's awesome!
  16. Star gazer
    43
    Maryland
    Thank you! Makes me feel a lot better. Will be ordering them. :D
  17. radioprius1
    radioprius1 Climate Conspirisist
    1,355
    155
    Iceland
    I sincerely hope you are joking. I call 100% BS. You are out of your mind if you think you are going to see a 12% improvement on gas mileage by adding mudflaps to your car.
    Further, I call BS on the validity of your wind tunnel tests. Our cars are not suspended by their roofs when we drive on the roads.
    ... (SARCASM) Can't wait to see the 30% MPG improvement from adding the shark fin antenna. How many MPG did your radio add? (/SARCASM)
  18. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Furthermore if you use this method, you won't have to take your tires off.
  19. rrolff
    1,610
    246
    So Cal
    Just got the raw data on the shark fin antenna tests. The scenario was similar - car suspended by an eye-bolt approximately 4" above the ground.
    We chose a BMW shark fin antenna - hypothesis being BMW is known for speed, and probably have a solid design.
    At no time did we test signal strength or antenna performance. So buyer beware...
    Initial data puts the aerodynamic shark fin as a net+ in mileage - though nowhere near the increase that mud flaps add.
    We do calculate a 1.467% increase - which should be good enough for 3/4 of a mile/gallon.
    Interestingly, the antenna had the added benefit of 3.1416% vertical stability (measured at 90MPH).
    Next up (as lab time permits), body side moldings.
  20. rrolff
    1,610
    246
    So Cal
    Sarcasm aside, I doubt the radio added anything to the Prius mileage. That test will also require a different lab setup (which would take even more engineering hours to design and setup).
    Now that I have the eye-bolt in my roof, the wind tests seem to make the most sense. I'm putting in a pulley system lift in my garage in a few weeks (once the heavy duty parts arrive) - that way I can work on the under-side with ease... Would've come in handy for putting on my mud flaps...
