Resistor smell new gen III
Discussion in 'Gen 3 Prius Technical Discussion' started by Bike-a-man, Oct 1, 2009.
  1. Bike-a-man
    Bike-a-man New Member
    Old Saybrook,CT
    Have not seen a reference to this one yet! First long trip we are going down a 5 mile very steep hill in the Smokey mts of NC. 3/4 of the way down the unmistakable smell of resistors frying in the morning wafts through the car. Traction battery ICON hits full for the first and only time! No residual issues since. Normal break in occurrence or should I have a chat with my dealer?
  2. spinkao
    spinkao New Member
    316
    78
    Czech Republic, EU
    Doesn't seem normal to me. I would definitely have the car checked. Might be all right (perhaps some manufacturing residual or debris somewhere burning off), but "amper smell" is never a good sign.
  3. Patrick Wong
    18,200
    6,497
    Sounds like the traction battery heated up more than normal due to your long descent which caused the battery to reach a "full" charge as reported by the icon. If you don't have a recurrence of the smell, I wouldn't worry.
    Did you happen to hear the battery fan running faster than normal?
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Were you using your brakes at all? New brakes in the process of setting often give off a similar smell. The prius uses its friction brakes a lot less than other cars but going down a steep hill it will use them.
    With that said, I wouldn't worry about it unless you notice your traction battery not holding a charge or something like that. Remember, those components are covered for 100K miles.
  5. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    What would you expect the dealer to do? If they take you seriously they will check for DTC's (diagnostic troubleshooting codes) in the ECU. Most probably they will dismiss it as normal without even seeing the car.
  6. a priori
    a priori Canonus Curiosus
    3,083
    408
    Chicagoland (West)
    Were you riding your brakes much of the time, or did you put the car in B mode?
    Did the ICE rev up?
    Did you hear the battery fan in back?
    I think Patrick may be correct on this (because he usually is!), but I also wanted to know what you heard at the same time.
  7. jayvee
    jayvee Member
    341
    89
    WA
    I have "maxed" the charge on the traction battery several times, with no noticeable odor. I would suspect that the odor was from your brakes, since I would expect your foot was on the brake pedal a good share of the time?
  8. hill
    8,718
    Patrick, to follow in Priori's inquiry ... doesn't the ICE spin up to dump excess battery charge in potential downhill recharge scenerios?
  9. qbee42
    3,079
    The electronics and battery can smell a bit when they are new. I suspect this is the first time they have heated up to this level, which would make this smell normal. It should be fine. Keep your nose open, and if it happens with regularity it could be a red flag, otherwise I wouldn't worry.
  10. Bike-a-man
    Old Saybrook,CT
    Yes to B mode very briefly. Yes while in B mode. did not hear batt fan. Some braking but not excessive.
    No DTC's present and all indciations normal. Thanks for all the feedback
  11. Patrick Wong
    18,200
    6,497
    Hi Gary,
    Yes, after the traction battery SOC gauge shows "full", then you may notice the gasoline engine reving up which results from MG1 spinning the engine to reduce battery charge.
  12. Tech_Guy
    Tech_Guy Class Clown
    868
    123
    Silicon Valley, CA --- Land of Fruits & Nuts
    Don't worry about it. You will get use to the smell after the fire.
    Keith
  13. richard schumacher
    7,664
    1,045
    United States
    It's almost certainly totally normal. Ya gotta love the new electronics smell :_>
