Where can i get an outdoor 'car cover' for my prius
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Oct 1, 2009.
  1. ski.dive
    ski.dive Active Member
    964
    242
    Hutchinson Island,FL. Mt. Snow,VT
    Where can i get an outdoor 'car cover' for my prius.
    I travel alot and my prius stays out in the elements.
  2. Doc Willie
    1,717
    144
    Out there, somewhere
    Places like AutoZone and Advance Auto Parts have them. You don't need one especially made for the Prius. I got a generic one, add a bungee cord underneath to snug it up, and it fits just fine.
  3. macmaster05
    macmaster05 Senor Member
    4,050
    730
    Don't you have to be careful about the antenna though?
  4. dogfriend
    7,512
    1,189
    Carmichael, CA
  5. Stev0
    7,201
    1,074
    Northampton, MA
    2022 Prius Prime
  6. Doc Willie
    1,717
    144
    The one I got has a vent where the antenna would be. Since I have the sharkfin it is not an issue.
    It is something worth checking out when you get the cover, though. Or you can just unscrew the antenna if you don't mind the hassle.
  7. blippo
    blippo New Member
    255
    VA
    I have a Coverking Silverguard Plus for my 2009. Very satisfied with it. For the antenna they have it shaped to cover it.
  8. a_gray_prius
    2,927
    783
    IL
    In case it hasn't been mentioned to you: You realize you should never put a dirty car under a cover? The wind will blow the cover around and rub the whatever is stuck to your car (which will act as an abrasive) into your paint, causing paint damage.
  9. swi66
    swi66 Member
    193
    Gasport, NY
    I myself don't beleive in outdoor covers.
    As mentioned above, wind can whip the cover around and scratch the paint.
    And what do you do if it rains and the cover is soaked?
    roll it up and take it with you?
