Another dog question
Discussion in 'Gen 3 Prius Main Forum' started by Basildane, Oct 5, 2009.
  1. Basildane
    Basildane Junior Member
    46
    I know this has been discussed, but I have a variation on the dog question. Does anyone know if a full sized German Shepard can fit comfortably for reasonably short trips in the rear of a Gen II or Gen III Prius? Not the back seat, as it is full of kids.
    I could remove the back tray and put a soft bed back there. We used to use a Tahoe for such things, but now its 2 Prius' and no truck.
  2. hyo silver
    hyo silver Awaaaaay
    15,261
    1,601
    off into the sunset
    He/she/it would likely fit lying down, but probably not standing up. Removing the tray would give more vertical room, but may not be as comfortable for the dog to curl up in.
    If you've got the car and the dog, give it a try.
  3. Basildane
    46
    Naturally I would try it if I could. The dog is in the Czech Republic right now.
  4. blue bird
    blue bird New Member
    Belfair, WA
    Hmmm, I think the dog may be ok for short trips, but not long ones. My dog is a small brittany (40 lbs) and she just comfortably stands up back there.
    Good luck!
  5. pdth
    pdth Member
    95
    32
    Castle Pines North, CO
    So the dog will have to make a commercial airplane flight? I'd say the back of a Prius will seem extra generous, compared to the amount of room we usually get on airline flights!
  6. macdonald
    macdonald New Member
    34
    Arkansas
    My daughter has a 100-pound German Shepherd. I don't want him in my Prius!
  7. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    Should be no problem. Dogs are shipped in crates. There is a lot more room in the back of a Prius than any dog crate I've ever seen.
  8. GreenWithEnvy
    GreenWithEnvy New Member
    81
    SE Wisconsin
    He would fit but he most likely would not like it.
  9. Basildane
    46
    Our Dane is almost 200 lbs. Not gonna happen!
  10. dc202
    dc202 Member
    230
    22
    Pacific Northwest
    Your GSD may fit but won't be comfortable. I would not recommend it for anything other than a quick trip.
  11. jburns
    829
    111
    Archdale, NC
    From the looks of that picture, if you put the car in neutral he could push it. Think of the mileage you would get.
  12. Fstr911
    Fstr911 Member
    235
    55
    LOL!!! jburns.... That was a great response to that big lovable Great Dane post!
  13. ilusnforc
    ilusnforc Member
    404
    San Antonio, TX
    I've only ever put my Afghan (60 lbs but tall lean dogs) in the back seat of my '06. I once had the Afghan in the back seat and a Chihuahua mix in the rear hatch to seperate them, and I've had two Afghans in the back with the seats folded down and they were quite comfortable. I also had thought about taking the floor out of the hatch and set a bed into the hole but decided I wanted the floor back in as I was going to be camping in the car overnight and wanted the floor in the hatch to sleep on and had no room to keep the floor in the car while traveling. I'm sure the dog should be able to lay down back there just fine, but standing up will be a problem.
  14. nineinchnail1024
    nineinchnail1024 New Member
    280
    40
    New Orleans
    If it helps, my 80lb. boxer has gone on long trips in the hatch of my old '05 as well as my '10. She sleeps like a baby and has room to stand up and reposition herself.
  15. paulemus
    paulemus New Member
    93
    San Diego
    Here's a trick for leaving your dog in the car on a hot day: Leave the power on with Air Conditioning running. Set parking brake and turn off lights. Roll down driver's window. Get out of car and reach in to lock all doors. Flip the window back up while quickly removing arm out of window. The A/C runs mostly on battery and the car is locked. To get back in, use the hard key slipped out of key fob. (You can put a note to explain to concerned bypassers, but a cop told me that if the dog doesn't look in distress, they won't break in. And my dog looks quite comfortable, thank you!)
    Lightning Racer likes this.
  16. ilusnforc
    ilusnforc Member
    404
    San Antonio, TX
    Or you can just use the hardkey in the fob to lock the doors, turn the opposite direction of unlocking and it will lock all doors.
  17. sendconroymail
    sendconroymail One Mean SOB
    256
    Lol. Your dog has a gleam in his eye. The back of the Prius is pretty sexy.
