Gas mileage
Discussion in 'Gen 2 Prius Main Forum' started by aclone, Jun 17, 2005.
  1. aclone
    aclone New Member
    Hello,
    I purchased a new 2005 black prius package 6 aproximately 3 months ago. It currently has 780 miles on it. I have tried many different driving techniques..feathering, slow acceleration, never gunning the accelerator and I still am only averaging 40 mpg. I am currently on my 3rd tank of gas and I would really appreciate advice on what the problem could be.
    I wanted to add that I did add the 17" rims with Pirelli tires but based on the research I have done regarding the larger wheels, it should only affect the mileage by 2 to 3 mpg.
    My personal opinion is that the ICE is running too much as it seems to never shut off even at very low speeds. It runs at 5-6 mph and up.
    Thank you for your help and thank you for having such a cool board. I have really enjoyed lurking for the past few months.
  2. Tideland Prius
    16,548
    Did you check out Evan's KB article?
    Also, scan/browse through other similar threads in the Fuel Economy section. Lots of other people are in the same boat you are. Hopefully Evan's article can shine some light on your situation.
    Here are some of my thoughts
    I would think the rims AND tyres would add to about 5mpg. Yes, not only the size but also the tread that will matter. Also, you're still in the break-in period so give it some time. My 'low' mileage was probably masked by winter weather since I got mine at the end of October and is probably why I never complained. I've been getting low 40s (and note I'm in Vancouver so it almost never gets cold) til March when I got my first 50mpg tank. After that, I've been getting high 40s and low 50s.
  3. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Tire pressure makes a difference. Faster acceleration up to speed then drive at the speed limit or below. I use the cruse control a lot because I have two numb feet from a back problem and surgery. The feathering thing takes too much concentration and watching the road suffers. Watching the road and anticipating is really important. Coasting and gliding to a stop. You will learn the points to cut the throttle for every stop you have on your commute. I think the flattest rout is better if you have a choice and the milage is better. Give people in front of you space so you can react and change speeds slowly. You may even be able to avoid braking when they do to turn etc. Every time you slow down and accelerate you loose. Read Evans article. Things do get better. You will get better milage than I ever can. It is warmer in Florida and yes much flatter, and yes that is why I live here and not there.
  4. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    <div class='quotetop'>QUOTE(aclone\";p=\"99517)</div>
    I see the 780 miles in 3 months as significant. That averages 8.5 miles per day. If you would observe your consumption screen you will see that most of the time you are getting 25-35 MPG during the first five minutes, then the mileage goes up. With short trips most of your driving is in the initial warm up the engine period where you are getting poor mileage.
    But with three fillups in 3 months, you are spending far less for gas than those who drive long enough to get 50+ MPG.
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    I'm with jfshultz...first thing I noticed was the very low mileage for 3 months of ownership...that's about 1/2 of what I log per month.
    I suspect all your trips are very short and you're never getting out of the initial warm-up stage...when the gas mileage is very low.
    Read the knowledge base article in the FAQs and see if you still have questions.
  6. aclone
    aclone New Member
    What you're saying about the car not really having the chance to warm up and thus keeping the mileage down sounds exactly right. I am fortunate enough to have a 1 mile commute to work and the rest of the mileage has just been short trips around town.
    jfschultz , you are indeed right that I am still getting exemplary gas mileage compared to what the average car owner gets. Even if I didn't, I wouldn't really care. I love the car too much! I never in a million years thought I would own such a technologically awesome car!
    Thanks for the advice everyone, you're wonderful! :p
  7. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    WOW, 780 miles in 3 months??? Amazing!! I've managed to log almost 2300 miles since mid March. The more you use the car, the more it breaks in. Heck, you've barely passed the 600 mile car break in period!
    It should improve with time and longer trips. :)
  8. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    It won't improve much with those short trips. High speed driving will also lower your mileage, but not as bad as short trips less than 10 minutes would.
    At 1 mile commute, you might be able to get an EV switch and defer some of your warmup to the next trip, as long as you can drive under 34MPH and not accelerate too hard the whole time.
  9. Cully
    Cully New Member
    Colorado
    I don't want to sound like a wise guy but if you live 1 mile from work, get a bike or one of those Segway scooters. Your MPG might not improve but there is a good chance you might only have to fill up 2 or 3 times a year. I just got my Prius 2 weeks ago so of course I'm looking for any excuse I can to drive the thing. Averaged 48 on my first tank and the second is looking even better. Right after you fill up next time, reset the consumption meter and go for a 20 or 30 mile drive, you might see a difference.
    Matt
  10. Jared
    Jared Member
    209
    Long Island
    I drive about 2,000 miles a month commuting between Long Island and NYC. At this rate I will run up against the 3 year/36,000 warranty in a year and a half. That's why I had to get a fuel efficient car. So far I average 48 to 49 miles per gallon. Not that much more than an Echo, but much better than the midsize Camry, which is the real comparitor. I fully expect that I will recoup the additional cost of the Prius in gas savings over the 10 to 15 years I will own it. I also expect gas will be much more expensive in the future, perhaps in the $5.00 to $10.00 range. Plug-in hybrids that can get over 100 mpg will be the answer to high gas prices, and there will have to be massive investment in renewable sources of electricity like offshore wind turbines as oil begins to run out.
