Engine oil drain plug gasket stuck on oil pan, help!!!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 2009Prius, Oct 8, 2009.
  1. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Changing oil first time. Gasket stuck on oil pan. Tried finger nails to pry and flat blade screw driver to push on the gasket. Won't come off. (Don't want to damage the oil pan surface where the gasket sits either) Please help!
  2. Patrick Wong
    18,200
    6,500
    This will happen from time to time. What I do is to use a flat-blade screwdriver and a small hammer. Place the blade of the screwdriver on an edge of the gasket. Lightly tap the handle end of the screwdriver with the hammer, and the gasket will pop off.
    It is good that you noticed the gasket was stuck. A less careful person would leave the old gasket on and then replace the drain plug along with a new gasket. This would probably result in a leak.
  3. tochatihu
    tochatihu Senior Member
    9,765
    3,765
    Kunming Yunnan China
    2001 Prius
    putty knife may have a thinner tip
  4. dogfriend
    7,512
    1,190
    Carmichael, CA
    Straight edge razor blade is my tool of choice for this.
  5. philobeddoe
    philobeddoe ΜΟΛΩΝ ΛΑΒΕ
    575
    107
    Los Angeles
    i got a sweet kershaw that does the trick ...
    where are you ... maybe another member can swing by and lend a hand?
    +1 on Patrick Wong's post
    many may not have noticed, resulting in a hassle
  6. 2009Prius
    2,705
    512
    63
    Thank you! It worked! I also wrapped a piece of plastic around the tip of the blade to avoid scratching the sealing surface of the oil pan.
    Some other questions:
    What if the gasket stuck on the plug?
    Is it necessary to run the engine right away after the oil change or is it OK to wait until the next morning?
    Thanks!
  7. philobeddoe
    575
    107
    Los Angeles
    it's ok to wait until the next morning
    i like to run it right away, let it warm up
    check for leaks, pressure, etc.
    then let it settle back in and check the levels
    better to do it now ... than find out you have problem in the morning :thumb:
  8. dogfriend
    7,512
    1,190
    Carmichael, CA
    Agree, you can wait if you want. But don't forget to check one more time after it runs for a little while.
  9. uart
    uart Senior Member
    4,220
    1,211
    Australia
    It really is better to run the motor straight after an oil change. The reason is that it usually takes a just a little bit longer for the oil to start to circulate the very first time you run it after the change (and even more so if the filter was also changed). So it's best to start it up straight away while it's still a little warm and while there's more chance of having some old oil still clinging to surfaces. There's just less friction and better lubrication if you do it straight away.
    When I change oil (on a regular car) I like to :
    1. Run the motor for a about 5 minutes to circulate the oil and warm the motor (but not so the oil is hot enough to burn you, I let it cool for about 10min if motor was at full operating temperature).
    2. Change the oil.
    3. Immediately start the motor and idle for about 1/2 to 1 minute.
    4. Let it sit for 10 to 15 minutes and then recheck the oil level and add if necessary.
    I haven't changed to oil on the Prius yet but I think I'd still follow the same procedure, except that I'd need to drive it to get the ICE running rather than just idling.
  10. sambojoho
    sambojoho Proud conservative
    92
    Ohio
    Nah, don't need to drive it to get the engine running. Just turn car on, and press down on the accelerator with the car in park. The engine will fire up and run for as long as you hold down the pedal. At least that's how it works on my 06!
  11. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Ok that's handy to know sambojo, I'll have to try that some time.
  12. 2009Prius
    2,705
    512
    63
    This is what I was wondering about. If I leave the engine cold all night would there still be enough old oil coated on surfaces? I am sure there will be some oil coated on surfaces even for longer period of time since it is so difficult to wipe oil really clean from surfaces.
    Another thought: what is the difference between leaving the car in the garage for two weeks (without oil change) versus not starting the engine until two weeks after oil change? I can't really think of any. So maybe it doesn't matter that much whether one starts the engine right away after oil change?
    How about the transaxle oil change?
  13. 2009Prius
    2,705
    512
    63
    I was trying to avoid this so I don't get unnecessary reduction in lifetime MPG. :)
  14. Patrick Wong
    18,200
    6,500
    Its hard to imagine that the gasket would stick to the plug - but if it did, then place the tip of the screwdriver blade between the plug and the gasket, and lightly tap the end of the screwdriver to force the gasket off.
    The only reason to run the engine right away, is to make sure that you did the job right and didn't leave the drain plug or oil filter loose. You might forget to do those checks if some time elapses.
    Look for oil leaks after running the engine for a few minutes. Make sure that the fill cap is on tight and the dipstick is fully inserted; you don't want engine vacuum to leak from those openings.
    All DIYers should know how to invoke inspection mode, which forces the engine to idle while the shift selector is in P. This can be used for a variety of purposes. See for example my post #3 here:
    http://priuschat.com/forums/gen-ii-...gushing-fluid-sound-after-coolant-change.html
    Do not drive the car while inspection mode is on. If wheelslip should occur this may result in damage to MG1.
    An alternative approach is to depress the accelerator pedal while the car is in P to get the engine to run, then shift into N (however, this is not for Classic owners). This is quite easy, but a disadvantage of the latter process is that the traction battery does not have the opportunity to be charged by MG1 while the gasoline engine is running. This would be a problem if you leave the car like this for a prolonged period.
    2 people like this.
  15. philobeddoe
    575
    107
    Los Angeles
    great post Patrick :thumb: and thanks again for the link to "inspection mode"
    2009Prius ... be careful not to overanalyze this
    if you are going to DIY the oil change, start the car and let it idle long enough to warm up, that is more than 1/2 to 1 minute
    this will allow you to inspect the filter, and be sure you're not losing oil around the gasket seal, be sure you're not losing oil at the drain plug (torqued to 28 lbs), or not suffering from any other oil system failures
    then in the morning, you can start your car and head off to work without worry
    other questions about the car sitting overnight with the old versus the new oil are largely irrelevant
    plenty of people who store vehicles - cars, boats, motorcycles, etc - over long periods first remove the fluids, but this is a topic for another thread
    this is a simple oil change, so keep it simple :thumb:
    2 people like this.
  16. uart
    uart Senior Member
    4,220
    1,211
    Australia
    There is a difference. After the oil and filter are changed it really can take quite a few extra seconds for the oil to circulate as compared to a normal cold start. I makes sense to do this while the engine is still warm and there's maximum residual lubrication. Plus when the engine is cold the clearances are less and the friction is more. Why would you want to have maximum friction and minimum lubrication at the same time when you can just get the filter primed and the oil circulating while the engine is still partially warm.
    Forget about the tiny impact on your lifetime MPG, do what's best for your engine not your bragging rights.
  17. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    With my '04, I would just floor and release the gas pedal. The gas motor instantly starts, and runs long enough to allow you to give a quick visual for leaks, etc
    If you have ever worked on the old Ford 289/302 (Five litre) V8's, or ESPECIALLY the Ford 300 inline 6, they had a nasty habit of getting an airlocked oil pump if you left the oil pan dry too long
    You then had to pull the oil filter off, use a squirter can full of motor oil to prime the oil pump, and try again. This could take quite a few tries before you actually got oil pressure again
    Sometimes you had to pull the distributor and use a priming tool hooked up to an electric drill to prime the oil pump
  18. jayman
    13,439
    641
    Winnipeg Manitoba
    That never happened to my Prius, but it happens all the time with my FJ. A gasket scraper is a good tool to keep around, its very easy to pop the old gasket off with no damage to the pan itself
  19. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Thanks for backing up what I had to say jayman. I don't know if this can be a problem or not on the Prius (and I said in my post that this was from experience with other cars) but I've certainly seen delays of up to five seconds in oil circulation after oil and filter replacements.
  20. philobeddoe
    575
    107
    Los Angeles
    ok fellas, i think you're making this overly complex for our friend here
    i've worked on plenty of old Fords and Chevy motors as well
    in fact, most of my old and not so old Ford trucks all suffered from rear main seal leaks at high mileage, no matter how well the vehicle was maintained
    so should we be advising 2009Prius to check for a rear main seal leak on the 2009 Prius ... i don't think so
    2009Prius has all the relevant and necessary information for a DIY oil change
    ... drain the oil and remove the old filter, lube new filter gasket and install, insert drain plug and torque to 28lbs, refill with new 5w30 or 0w30 oil, reinstall oil cap
    run car for five to ten minutes, check oil filter base for leaks while car is running
    turn car off
    allow ten minutes for drain back
    check oil level at dipstick, check drain plug and oil filter for leaks
    go back to normal life
    drive the car ... be happy ... all is well
