UK Vs. US MPG
Discussion in 'Gen 3 Prius Main Forum' started by floppyarms, Oct 9, 2009.
  1. floppyarms
    floppyarms New Member
    40
    Herts, UK
    Sorry if this has been covered before, i think the forum search is buggered for me (typing in 'mpg' returned no results???)
    Some comments in PC have had me thinking and a quick google around explained that there is a difference between a UK MPG and US MPG:
    1 UK Imperial gallon = 4.55 litres
    1 US Liquid Gallon = 3.79 litres
    But as the Prius is make is Japan i wondered if there is an international standard or whether we really are barking up the wrong tree when trying to compare MPG's as a global community???
    *scratches head*
    Floppy.
  2. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    The US gallon is 32 oz and the imperial is 40 oz. I -think- the ounces are also different, but as those are obsolete measurements I can't be sure.
    Use Online Conversion - Fuel Consumption Conversion to convert. It does everything.
    I like l/100 km as an international standard, but as we all know, the nice thing about standards is there are so many to choose from!
  3. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    Ummmm - Not on this planet...
    32oz is (4) 8 oz cups, (2) 16 oz pints, (1) quart, (1/2) of a 1/2 gallon, and (1/4) of a gallon. A US gallon is exactly 128 oz
  4. rrolff
    1,610
    246
    So Cal
    Unit Conversions has a decent US - Imp converter.
    That said, I would be interested to know if they have less smog etc - creating better mileage.
    The UK Prius site Toyota Prius Interior, Exterior & Colours | Prius | Toyota UK mentions 72.4 MPG!!! That equates to 60.3 MPG!!! It would be interesting if there are some smog/performance things they get away with over there - that we don't.
    Especially since some states (CA for one) have exempted the Prius from any smog testing :rolleyes:
  5. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    Besides the difference in what constitutes a Gallon, the US EPA test and the EU Directive 93/116/EC test are different tests and would always get different results.
  6. rrolff
    1,610
    246
    So Cal
    I fully understand that - the question does remain - do we get worse, better, or the same mileage - all things equal...
  7. floppyarms
    40
    Herts, UK
    OK, so the way i see it 50mpg in the US is approx 60mpg in the UK.
    US - UK
    50 - 60
    55 - 66
    60 - 72
    65 - 78
    70 - 84
    I was wondering why 50pmg was so much to rave about when i have been getting that for quite some time in my diesel Peugoet 407. But 60mpg as a base point is much more like it. The UK toyota website lists 72mpg which would be 60(ish) in the US.
    Confused!
  8. Mark57
    2,945
    2,738
    OK
    The search function does not work on 3 letter words or shorter. One of the mods posted this factoid in a thread reply in the last few weeks, but I can't find it now and the FAQ on searching does not mention it.
  9. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    The Imperial gallon is 20% larger than the US gallon.
    US and UK are the only countries that use miles-per-gallon (mpg). Japan uses kilometres-per-litre (km/L). The rest of the world uses litres-per-100-kilometres (L/100km). The US/UK/Japan scheme is good for measuring range on a tank, but the rest-of-the-world approach is better for working out cost for a given distance.
    The UK unit is stupid because we buy fuel in litres, not gallons.
    The EU driving cycle is much less rigorous than the US and tends to underestimate fuel consumption; the US tests if anything overestimate consumption, since the 2008 model year revamp. The Japanese 10-15 mode driving cycle is woefully inadequate, it gives translated figures of something like 96mpg as I recall, but even their new one is weaker than the EU. Or, possibly, more representative of driving in Japan. The EU tests are done in metric, rounded to 0.1L/100km, and then translated to miles and gallons for the UK market. As a result you will never see a value in the UK between 70.6 and 72.4mpg, which are 3.9L/100km and 3.8L/100km respectively.
    To compare how the tests are done see these sites:
    VCAcarfueldata.org.uk - Fuel Consumption Testing Scheme
    Fuel Economy Test Schedules
    Note that the test conditions are similar but the driving cycles utterly different, and that the US now includes air-conditioning, cold weather and high-speed driving in their numbers.
    The Gen 3 Prius is mechanically identical across all three markets with all the same emission-control technology, including exhaust heat capture and exhaust gas recirculation. The difference is the measurement.
    You should not convert results of these different tests to other units and compare, because you're not comparing like with like. Comparing another driver's results is fine if you have similar driving conditions and speeds, but don't necessarily expect to match or beat someone else with different conditions.
  10. ronhowell
    ronhowell Active Member
    681
    32
    Cypress, CA.
    Thank you Mike ... a little overkill perhaps, but always good to read your comments, which besides being literate in the English language, a rarity in today's world, are rational and informative.
  11. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    Yea, our system is not confusing. 32 oz of gas would be 2 pounds. (Isn't there 16 oz in 1 pound?). So 128 oz would be 8 pounds. That makes gasoline heavier then water because I thought it weighed 7.48 pounds per gallon.
    (PS: Kids, pay no attention to this or you'll flunk math.)
  12. kevinwhite
    kevinwhite Active Member
    333
    200
    Los Gatos Ca
    The values should be in Fluid ounces (fl oz) - this is the volume occupied by one oz of water (approximately).
    However the US fluid oz weighs about 29gm where the UK one is about 28.4 gms.
    So a US gallon of gasoline weighs about 6lbs, an Imperial gallon of gas (of course it is petrol really) weighs 7.2lbs.
    [ame=http://en.wikipedia.org/wiki/Imperial_units]Imperial units - Wikipedia, the free encyclopedia[/ame]
    Kevin
  13. archermoo
    archermoo New Member
    118
    Pittsburg, CA
    According to the USGS water weighs 8.33 pounds per gallon. Remember "A Pint's a pound the world around". :)
  14. rrolff
    1,610
    246
    So Cal
    How off we can get! Please read through the thread - we are talkin UK...:eek:
    32oz of gasoline would equate to close to a liter - which costs around £1.00/liter.
    So 32oz = 1 pound, 1 gallon~4 liters, and around 4 pounds (yes I am rounding).
    Now please go get a clue :cool:
  15. ronhowell
    681
    32
    Cypress, CA.
    Confusing/not confusing!? Is the US ever going to get in step with the rest of the world and convert to the metric system, rather than continue with this antiquated set of measures inherited from ancient English monarchs? Life would be so much simpler, though the mental changes and cost would be considerable.
  16. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    I have a 100 year plan to convert to Metric: Teach our children a sane way and wait for us old fogeys to die off.
    Thats quicker than all other plans, we have tried.
  17. OvertheHill
    OvertheHill New Member
    Manchester, UK
    I was taught metric measurements in school from an early age. My dad used imperial so I have grown up with a strange mix:
    - I measure speed in mph
    - I measure temperature in celsius
    - I measure short distances in cm, metres
    - I measure long distance in miles
    - I measure height in feet
    - I measure volume in litres
    So I put petrol in my car in litres but understand mpg!
