10K MPG Check: Not impressed
Discussion in 'Gen 3 Prius Main Forum' started by Coastie, Oct 9, 2009.
  1. Coastie
    Coastie New Member
    El Dorado Hills, Ca
    Passed the 10k point a few days ago. So far, the MPG is essentially the same as what my Gen II Prius gets (2004 with 103k miles).
    Here's the data:
    1. The trip ODO average MPG for the 10,000 miles= 46.4
    2. Actual computation of MPG for the 10,000 miles= 44.4
    3. Fuel costs= $623.33.
    Conclusions:
    1. Apparently, the reports that the trip ODO MPG is off to the high side are true.
    2. The advertised improved mileage for the Gen III is exaggerated (though 44.4 is still impressive).
    I realize the engine in the Gen III is larger than the Gen II's, so achieving the same mileage with a larger engine is an improvement.
    Regarding my driving style: I don't go to extremes to eke out extra miles per tank. I drive the Prius like a car. I live in a hilly region which often requires a lot of time in the red zone.
    I still love the Gen III, but I've shelved my dreams of 50 MPG.
  2. Salsawonder
    Salsawonder New Member
    1,897
    47
    La Mesa California
    I live in a hilly area with a short commute. It is not reasonable to think the car is going to deal with these areas in the same manner it does flatter areas. I easily get low to mid fifties on road trips with varied terrain and at speeds from town 25mph to 75+.
  3. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    We have Prius v's as well, so the 17" rims and their tires are hurting us as well. If you had a Prius II-IV you would see an improvement over the GenII.
    My dad has a Prius III and when I drive it, I can easily get better MPG's than I did in my 2006...
  4. codybigdog123
    codybigdog123 Got Mad and Left in a Tizzy
    239
    29
    Chicago, Il
    There's an entire thread devoted to measured versus the computer version of MPG on the Prius. Based on all the people who have posted their data, there seems to be between a 2%-5% difference, with the computer reading higher (better) mgas mileage, than what's actually measured when you fill up your tank. So that's nominally a 2 to 3 mpg higher reading.
    That said...many of us easily get over 55mpg on their comutes. My comute is 28 miles each way, and my computer shows that i've been averaging about 32 miles/hour during my comute (because of traffic). I went an entire week, with my mpg over 60. This week, as I tried to increase my speed, I avergaed 58mpg. Still well above the EPA numbers.
    Different strokes, for different folks. Personally, if i drove conservatively (to get better gas mileage), and I did not get at least the EPA number of 50mpg, I would have things checked out. Good luck.
  5. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    i get and average of 53 for the last 8,000 miles, the computer on the car says 56.5. i drive mostly highway going 65-96mph I flow with traffic.
  6. Manolo1
    Manolo1 New Member
    150
    South Florida
    Your dreams were unrealistic based on your driving habits.
    I bought my Prius planning to continue driving exactly as I have been doing all along and was originally happy to get 40 mpg. I am averaging 42 so I am very happy.
    (exactly double what I was getting before...)
  7. nineinchnail1024
    nineinchnail1024 New Member
    280
    40
    New Orleans
    I think it has more to do with your most common driving routes than habits. I average 53mpg on the computer and I don't even attempt to hypermile, ever. But my routes to work, local shopping, and my family's houses are all very mpg friendly.
  8. bps
    bps Active Member
    304
    119
    I'm sorry to hear that. I have 2,850 miles on my Gen III with a 59.2 avg (computer, not actual).
    Bryan
  9. tekgirl
    tekgirl New Member
    29
    Northern NJ
    I am only averaging 42 mpg and am wondering if something is wrong. My driving is a mix of highway/local and a friend who travels the same route is getting over 50 with her Gen 2.
    I have a Gen V, which is loaded but I was getting better gas mileage when it was new. It now has a little over 3000 miles. Can anyone shed some light on this?
    Thanks
  10. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    Warm season is clearly better for me... 53.8 verses 51.3
    Cold season is what I'm expecting to really see a difference with. This morning was the first frost. That hinted at good things to come.
  11. Blind Guy
    Blind Guy New Member
    352
    194
    Springfield Missouri
    * Realistically, that figure may not be attainable in your particular circumstance.
    David (aka Blind Guy)
  12. tekgirl
    tekgirl New Member
    29
    Northern NJ
    I am taking it to the dealer next week and will try to figure out what the issue is. I realize that 42mpg is better than 20, but I was expecting a bit more :confused:
  13. john1701a
    12,818
    5,303
    58
    What kind of checks have you done?
    Try this: Verify tires are at an absolute minimum of 33 PSI cold. Get out onto the highway. Set the cruise. Reset a trip meter.
    At 60 MPH, you should see dramatically higher MPG average. If so, there's probably nothing wrong and it's just your routine driving causing the lower MPG.
  14. bwilson4web
    16,217
    Normally we find a Gaussian distribution in any population:
    Column 1 Column 2 Column 3 Column 4
    0 MPG EPA ZVW30 (47) PC ZVW30 (121) 07-09 NHW20 (284)
    1 32.5 0% 2% 1%
    2 37.5 2% 0% 6%
    3 42.5 4% 6% 23%
    4 47.5 23% 24% 36%
    5 52.5 38% 40% 26%
    6 57.5 28% 22% 5%
    7 62.5 4% 5% 2%
    8 67.5 0% 1% 1%
    About a 1/3 achieve 52.5 MPG. About 1/3d are lower and 1/3d are higher. But we've only had the 2010 Prius in our hands for less than a year and the North American ones have yet to go through winter.
    It is entirely possible that after a year, the ZVW30 and NHW20 will have similar milage. Winter is the season we'll learn the effectiveness of the exhaust heat recovery system. Wayne has already published some preliminary data and I'm hoping we'll see an update when the ambient temperatures are closer to 32F/0C.
  15. tekgirl
    tekgirl New Member
    29
    Northern NJ
    Thanks - I'll give it a try...when I first started driving the car, I was getting over 51 mpg and my driving/route has not changed. haven't really done any "checks" per se - I wanted to do some reading here first and see what others are getting as far as mpg.
  16. bwilson4web
    16,217
    Studies with the NHW11 and NHW20 have revealed:
    • battery efficiency - is at a peak for the first 3-4 months and then reaches a plateau for the life of the car. We've seen a short term improvement, 3-4 months, in mileage after traction battery replacement.
    • transaxle oil - although still under study, it looks like an early replacement returns transaxle rolling drag to like new status. We just don't know how long this effect lasts, which is why it is still under study.
    • bumper air inlet blocking - improves warm-up in the earlier cars and reduces cooling drag at lower temperatures.
    The car is so efficient that most user modifications and maintenance are in the 1-5% range ... well within the MPG noise. It takes careful attention to detail to quantify these effects.
  17. globalcivilian
    globalcivilian Junior Member
    Cary
    I've only had mine about 2 weeks, but find I'm getting 2 mpgs more this week than last. I think it's because I've discovered how to drive it more to still in the Hybrid Eco area.
    How long have you been driving yours? Are you keeping it in the Eco and then releasing the pedal to get it into the Hybrid Eco Area once you achieve the speed that you want? Have you checked your tire pressure to make sure it has not dropped significantly? I have mine at 35 front and 33 rear. I think the model's V have a different recommended psi though..
  18. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    How are 17" rims hurting if the tire diameter is the same?
  19. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    The 17" rims are heavier and the tires that go on also hurt fuel mileage over the 15"s...
  20. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    I live in WV (hills) and am getting just barely a little better than you. However even at 45 mpg, I "am" impressed :) It's not what I had hoped for but with the low profile wide tires and a lot of highway driving making up most of our miles I'm satisfied. Had we not gotten the "V" we both may have a little better results. I do find that driving the back roads at 50 mph I can indeed get 55mpg. I just don't have the time to do that most of the time.
