Can't erase external HD!
Discussion in 'Fred's House of Pancakes' started by daniel, Oct 12, 2009.
  1. daniel
    14,487
    1,519
    Spokane, WA
    So when I was thinking I was going to have to take my computer in (my thread "Computer does not see modem") I decided to be extra careful by backing up my Documents folder onto the older external HD, even though everything is also backed up on the regular backup HD via Time Machine.
    That old HD had the backups made by Genie backup from the old Windows PC. I don't need those backups any more. So I wanted to erase them and free up the space.
    But it would not let me delete the old backups. Even logged into my admin account, it would not let me delete files from that HD. I tried to format, and got the error message that it could not unmount the drive (apparently it wanted to unmount the drive before formatting???) When I try to rmdir the directories it tells me they are read-only system.
    Any ideas what's going on?
    I opened a terminal and tried to chmod the permissions, but I don't seem to know the syntax.
    There's got to be a way to erase or reformat the drive???
  2. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Might be because the external drive was formatted FAT or NTFS for the Windows machine. I know NTFS causes issues if I try to mount such a drive for Ubuntu
  3. Dave_PH
    Dave_PH New Member
    2,416
    78
    Florida & DC
    Oh Crap. Get that porn off there before you bring it in
  4. a_gray_prius
    2,927
    783
    IL
    Wow man, for all the supposed superiority of Apple/OSX you seem to have a lot of problems.
    * used to be an Apple tech a long time ago
  5. daniel
    14,487
    1,519
    Spokane, WA
    So, what do you do if you have a former Windows HD and you want to wipe it for use on a different system?
    BTW, OS X can read the drive and copy files from it. The problem is that I have read-only permission, and even logging on with my admin account the drive won't let me delete files.
    I presume the backup program set the permissions so only it could delete files. But it's MY drive and I have a right to wipe it!!!
  6. daniel
    14,487
    1,519
    Spokane, WA
    Actually, I think these two are my only problems: ethernet died (that's kind of a biggie) and the old HD that I used for backups on the Windows PC won't let me wipe it for re-use now on the Mac.
    Compared with the unending mountain of problems I had with Windows, this is nothing! :D
  7. daniel
    14,487
    1,519
    Spokane, WA
    What a dirty mind you have. Must be that bunny fixation. :rolleyes:
  8. dogfriend
    7,512
    1,190
    Carmichael, CA
    Daniel,
    You should go into Applications >Utilities and launch Disk Utility. In the window on the left select your external drive. You want to Erase. Choose HFS+ as the file type. It should reformat to Mac HFS+.
    You can only read NTFS, so that is why you can't just delete the Windows (NTFS) files.
  9. daniel
    14,487
    1,519
    Spokane, WA
    WOW!!! That was easy!!! Thanks dogfriend!!! :D :cheer2: :D
  10. a_gray_prius
    2,927
    783
    IL
  11. daniel
    14,487
    1,519
    Spokane, WA
    And time machine runs all by itself, requiring no user intervention once it's been set up. It creates a layered backup, allowing you to go back by intervals of an hour, for a few days, then intervals of a day for a while, then progressively longer intervals.
    Nobody said OS X was perfect.
    If an OS is like a house, OS X is a comfortable house in the suburbs with three bathrooms, three bedrooms, a high-efficiency furnace, and a dog that sleeps quietly at your feet but will rip a burglar to shreds; Windows is like a tumbledown house in a horror movie, where the house itself wants to kill you and invites every psychopath in the neighborhood in to do the dirty work. The OS X house from time to time gets a rattle in the plumbing. The Windows house requires you to carry a baseball bat or a kitchen knife with you at all times to protect yourself, and you're unlikely to go very long without losing an occasional limb at least.
  12. qbee42
    3,080
    Be careful about logging into guest accounts with Snow Leopard. It's not common, but in a number of cases the primary account has been deleted, including all files and data. Apple is working on a fix, but it won't get your data back.
  13. dogfriend
    7,512
    1,190
    Carmichael, CA
    In the Windows house, as soon as you go to bed, someone is jimmying the back door lock and letting themselves in. :madgrin:
  14. dogfriend
    7,512
    1,190
    Carmichael, CA
    I have never tried the guest account feature and have no reason to. But its good to know about that - I haven't seen it mentioned anywhere before reading the post above.
    BTW, its not a bad idea to run OSX as a regular user, not as an admin user. That way you have to authenticate (provide an admin pw) for any software that you install (or any that tries to install itself). Also, having an extra account can help in troubleshooting because if you are having an issue, you can log into the other account and see if it occurs in the "clean" account. If it doesn't, you probably have a corrupted pref file in the regular user account.
  15. daniel
    14,487
    1,519
    Spokane, WA
    That's assuming you even have the back door lock, which does not come with the house, but has to be purchased separately along with a special fee-based subscription to allow you to re-lock it every week. And of course there are three back doors which each requires a different kind of lock, each with its own annual fee.
    Yeah, why would anyone anyone use a guest account anyway, unless it was a public computer where they wanted anyone to be able to log on???
    And of course you never log on as admin unless you are doing housekeeping that requires it.
    But I like the idea of having a separate regular user account.
  16. jayman
    13,439
    641
    Winnipeg Manitoba
    That ranks right up there with "oops"
    I've never enabled Guest on any personal machine of mine
  17. qbee42
    3,080
    You should never operate any computer as admin or super user on a regular basis. That's just asking for trouble. Even if you aren't dealing with malware, one wrong command can delete every file.
  18. daniel
    14,487
    1,519
    Spokane, WA
    That's what backups are for, and why including Time Machine in OS X was such a great idea. Though I agree about not operating as admin.
  19. a_gray_prius
    2,927
    783
    IL
    Apple Fanboy (not me) response: It's not a bug! It's a feature to allow users to delete all their data quickly!
  20. jayman
    13,439
    641
    Winnipeg Manitoba
    Yeah, that's it. We'll call it a "feature"
