Curious
Discussion in 'Gen 3 Prius Main Forum' started by hotbrass, Oct 13, 2009.
  1. hotbrass
    hotbrass New Member
    312
    35
    Cowtown
    I was sitting in park with power on reading my mail in the USPS parking lot.
    I pushed on the accelerator and the ICE started. When I let off the accelerator the ICE stopped. Did it several times just to make sure it wasnt simply trying make up for a current draw.
    Is there a reason the ICE will start in park when the accelerator is pushed. I would have thought that the car would be smart enough to know that the ICE was not needed.
    Just curious.:confused:
  2. a priori
    a priori Canonus Curiosus
    3,083
    408
    Chicagoland (West)
    It may just be smart enough to figure that the driver would be smart enough to push the accelerator only because he/she anticipated a power demand! :D
    After all (and more seriously, this time), what possible benefit may be had by pressing the accelerator pedal when in Park?
  3. hotbrass
    hotbrass New Member
    312
    35
    Cowtown
    None?
    So why would the ICE start if there is no benefit?
  4. eglmainz
    eglmainz New Member
    887
    141
    Chicagoland, IL
    I understand that this feature is there so that if you are troubleshooting something, you are able to turn the car on as needed. I did not search through all the threads again for this, but I know that I read it on the blog, and then tested this in my car a while ago.
    It works, I'm just not sure why. (I think it was initially posted under most obscure Prius facts, or something like that).
  5. hotbrass
    hotbrass New Member
    312
    35
    Cowtown
    Makes as much sense as anything I can think of.
    Thanks EGLMAINZ!
  6. fuzzy1
    10,391
    (1) forced battery recharge;
    (2) forced warmup;
    (3) test for presence of fuel in tank;
    (4) test whether engine works;
    I vote with a_priori ... Prius decides that you pushed the gas pedal for a reason, not necessarily known to it, so at some point it will respond.
  7. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    I think this is a feature to force charge the HV battery.
    It can also be used during coolant change to get rid of the bubbles.
  8. eglmainz
    eglmainz New Member
    887
    141
    Chicagoland, IL
    While this is also what I think happens, the limited amount of testing I did (5 minute engine run with 3 bars battery SOC) showed that it did not in fact recharge the battery noticeably.
    Does anyone know for certain if the electric connection from the MG to the batteries is open when the car is in park? It has been confirmed that it is disengaged in ‘N’ and engaged in ‘D’. I would assume that it is also engaged during ‘P’ and ‘R’, but would like to know what the status is in ‘P’.
  9. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    i think it's a communist plot
  10. pinzvidz
    pinzvidz Junior Member
    72
    Australia
    Ppl there's a "maintenance mode" for running engine work (i.e. bleeding coolant, checking ignition timing etc.)
    With power off, foot off brake pedal
    Press power button twice (to ign on state)
    Press accelerator pedal twice
    Shift to Neutral
    Shift to Park
    Press power button (goes to ready state) engine will start and keep running
    Maintenance mode will be displayed in the MFD, VSC light will be on for duration of mode.
    Power off to cancel MM.
    Rizzphoto likes this.
  11. hotbrass
    hotbrass New Member
    312
    35
    Cowtown
    You left out the third step, slaughter a lamb at midnight on the second full moon of the month.
    Where do they get these programmers. Must be Japanese!
  12. pinzvidz
    72
    Australia
    That's nothing. You should see some of the crazy tap dancing on brake and accelerator pedal/door opening and closing performances when it comes to programming new immobiliser keys on various non SKS Toyota vehicles.
  13. qbee42
    3,079
    Just like playing a Wurlitzer Theater Organ, only harder.
  14. Mark100k
    Mark100k Dipwad Member
    Sunnyvale
    I heard there was an issue with smog testing of prior generations. The ICE shuts off which makes it impossible to test. Maybe this is the fix, as it allows the engine to be run when in park.
