Prius - A mobile air filter?
Discussion in 'Gen 2 Prius Main Forum' started by PhilCase, Jun 22, 2005.
  1. PhilCase
    PhilCase New Member
    43
    Springfield, MO
    OK, I've read quite a bit about how clean the Prius emissions are, including the suicide thread elsewhere on this forum.
    So the other day was talking to a friend of mine who lives in LA, and we got to talking about how clean the Prius runs and he made an observation that may or may not be valid.... So I toss it out here for banter:
    He observed that as clean as the Prius operates, that in heavy freeway traffic in LA it's possible that the Prius might actually be spitting out air cleaner than it's taking in, given some of their air quality issues.
    Anyone have and data or opinions on this front?
    Phil
  2. oly_57mpg
    oly_57mpg New Member
    360
    Olympia, Portland, Seattle...
    A + B != A (for all positive values).
    There is still 'combustion' carbon dioxide and monoxide are still produced.
    The 'air' that the Prius burns is still full of the same contaminates.
  3. richard schumacher
    7,664
    1,042
    United States
    It can certainly burn incoming particulates and CO. NOx, I don't know. And of course it will make more CO2 and water vapor.
  4. KTPhil
    KTPhil Active Member
    1,379
    I'm not so sure. An average hydrocarbon street reading on a smoggy day can be in the tens of PPM. Out of a cat-equipped car, it can be in the single digits.
    Combustion is not merely additive, especially when a catalyst in involved.
  5. oly_57mpg
    360
    Ohhh, damn that catalytic converter.
    I plain-out forgot about it! Stupid 27 year old invention! It's older than I am! It's Prihistoric!
    Humm... I still see very little change in the equation.
    Let's say you are driving the Prius in an area where there is a high concentration of smog (Nitrogen oxide (NOx)) at street level. Most likely this occurs in heavy, stop and go, traffic. During those times, the ICE on the Prius doesn't run as often; nothing is being burned and forced through the 'cat'. In traffic, the Prius doesn't run enough to cause a significant change in street level Nitrogen oxide levels.
    Considering that every vehicle has a cat on it... The smog that is present at street level has already been through a cat. Most of the smog in a city is produced by industrial equipment; not cars.
  6. altaskier
    altaskier New Member
    157
    Long Island, New York
    The Prius may use half the gas and thus emit half as much CO, CO2, NOx, etc. (Maybe even a tad less than a half as much because the gas motor is more frequently run at peak efficiency/lower emission conditions with the motor/generator picking up the slack/absorbing the excess). However, it still emits those things as it burns gas; it does not burn CO, CO2, or NOx! Therefore it is inevitable that it adds to their concentration of pollutants in the air. It is by no means an air filter!
    I love my Prius, and am glad that it is less environmentally hostile. However, it would be dishonest to say that we are saving the earth by driving Prii - we're just trashing it less.
  7. Tideland Prius
    16,430
    It may. I know the Volvo S40 (or S60/V70) does "clean" the air as it drives, so to speak, because of it's charcoal electrostatic particulate cabin filter that traps particulates and dust (among other things). It'll also depend how dirty the air is in the first place :)
  8. oly_57mpg
    360
    <div class='quotetop'>QUOTE(Tideland Prius\";p=\"100886)</div>
    The v50's radiator has a coating that "cleans" the air by acting as a catalyst with ozone...
    http://www.volvocars.com/AboutVolvo/Enviro...t/CleanOutside/
    Sounds like a PR gimic.
  9. altaskier
    157
    It may remove some of the particulates from inside the cabin. However, the cabin volume is small, and the air exchange rate is modest, compared to the immense volume of air outside the car.
    If you really wanted to capture all the important emissions (like COx and NOx) from your own tailpipe much less the tailpipe of others, you would need to capture and store hundreds of pounds per year. That's obviously not taking place in any car, even one as "green" as the Prius or the Honda Insight or...
