2010 Prius Grill Blocking strategy
Discussion in 'Gen 3 Prius Accessories and Modifications' started by ken1784, May 31, 2009.
  1. MSantos
    MSantos EcoAccelerometry
    588
    257
    Canada, Winnipeg
    2024 Prius Prime
    XSE Premium
    Provided that the tables establish the conditions under which they were created then I would consider them reasonably reliable. Perhaps the most important criteria to consider when reviewing those tables is the "distance driven" factor.
    However, a fully blocked grille at -20C should not be a problem regardless of how long your commutes are. Things get a bit more delicate when approaching 0C (freezing point).
    Cheers;
    MSantos
  2. Philosophe
    Philosophe 2010 Prius owner
    437
    72
    Montréal, Québec (Canada)
    Another quick question: How will they survive going through a non touch automatic car wash?
    Also, are the tie-wrap mandatory or just a nice additional safety?
    Thank you!
  3. john1701a
    john1701a Prius Guru
    12,805
    5,291
    57
    Tie-Wraps are totally unnecessary; in fact pointless, if you use the squeeze install method with 1/2" foam.
    Mine never moved that way, the entire winter. Then when it came time to remove the foam, there was a lot of tearing involved. It most definitely won't let go on its own.
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Well, the pipe insulation I used does not have the adhesive on the seams so the ties were necessary. I don't think I would like to have to clean up the mess when using the adhesive.
    I suppose the 1/2" stuff would look better but after the first snow around here nobody will be able to tell that it is a Prius much less that I am using 3/4" pipe insulation.:rolleyes:
    Anyway, I have no doubt that the insulation will survive the cash wash.
    Peter
  5. Philosophe
    437
    72
    Hum... :confused:
    I just bought 3/4" foam. Which one fits best: 1/2" or 3/4"? Do you fit both the same way or do they wrap the grille in a different manner (whole 1/2" tube in one slot and 3/4" tube covering two rows of slots?) I certainly do not want to glue them to the grille...
    I followed the recommendation in this post and on CleanMPG "A Hybrid Owner’s winter survival guide" and went with 3/4" (not yet tried to install, I should do this on Sunday).
    I just want to know if I go exchange them for 1/2" tomorrow...
  6. john1701a
    12,805
    5,291
    57
    You've got photos of both. 3/4" spans 2 slots. 1/2" is 1 per slot.
    I personally find the 1/2" much nicer looking. So, the fact that they don't ever slip (held in place using nothing but pressure from being squeezed) is a side benefit.
    You're choice. It's nice having options.
  7. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    well based on recommendations, i have decided to go 75% block on top, but only for part of winter. right now, we frequently get temps in 50-60's. soon, it will be 40's. when that happens i am going back to 100% grill block, top and bottom.
  8. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Either way, your choice. Just make sure not to use the type with adhesive in the seams. Again, I am 99% sure you won't have a problem with the car wash. Let us know how it goes.
  9. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    i been using either ½ " or 1" split in half for years. no issues. car wash hardly touches em. once a week or so, i push the ends in a bit but only to make it look nicer. the ends are already blocked off. tapering them a bit helps keeps them in place
  10. GreenGuy33
    GreenGuy33 Active Member
    534
    29
    Rhode Island
    That looks great!!! It looks easy, clean and effective.That will be my first project when I get my Prius.
  11. GreenGuy33
    534
    29
    Rhode Island
    Are there any New England "grill blockers" out there? I'm wondering if you block just the lower section?
    I am thinking that when I get my Prius, I invest in a Scanguage.:thumb:
  12. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    with scangauge, u have little to worry about. general rule of thumb, if 45º or cooler, u are ok. i set mine at 60º but do little major freeway travel so i can go a little "hot" without issues. even with temps in 60º have never seen temps over 208º that was with 2006.
    on 2010, never above 201º but very little experience on this since blocking has only been on a month. i do 100% bottom, 75% top
    **edit** FYI, for driving around town in 2010, speeds 30-40 mph... i think top temp i have seen in past few weeks has been maybe 190 or so.... on work commutes, 7 miles, temp usually only gets to the low 180's sometimes. on colder days, the 170's and that is with the grill blocked. probably would be lower with no blocking
    2 people like this.
  13. barbaram
    barbaram Active Member
    912
    70
    Trenton, NJ
    I just blocked the lower grill. temps vary here now from 30's to 60's. It helps
    2 people like this.
  14. GreenGuy33
    534
    29
    Rhode Island
    Has anyone calculated to fuel economy using the grill blockers? How much better if fuel economy?
  15. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    no real numbers to post. it all depends. on short trips of say 10 miles or less, 5 mpg or more. reason is, grill blocking greatly affects the warmup time.
    if that 10 miles in done during sub freezing weather at 35 mph or less, it could be 10 mpg. if that 10 miles is 2 miles city streets, 8 miles highway, might only be. 3-4 mpg.
    same scenario except its 30 miles on the freeway, the difference might only be 1-2 mpg. so it all depends.
    when temps hit the teens and 20's, grill blocking may mean the difference between a warm driver or cold hands the entire trip if short enough. in mild weather, like 40's and 50's, its not going to matter as much.
    but bear in mind... it does make a difference. the more extreme the weather, the more it matters.
    the shorter the trip, the more it matters.
    3 people like this.
  16. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    ** Moved to Modifications Forum and made Sticky **
    Great topic, but moved to appropriate forum and made sticky (since everyone looks for it).
  17. Earman
    Earman CDN Prius III Technology Blue
    78
    Vancouver, BC, Canada
    I just blocked a portion of the lower grill. As the temperature here in Vancouver is not very low I did not want to block the whole grill. However, I do 99% of city driving and short trips so I wanted the engine to warm-up as soon as possible...
    I purchased only 1 length of 1/2" foam at Home Depot and blocked 2 vents completely and 1 vent partially. I may have to increase the cuts for the fins a little bit more at is still bumping a bit over the fins. Overall an easy mod and I am happy with it so far.
    During install, I noticed that the grill tended to move backwards when I pushed on the left side. Not a lot, but still noticeable. Is this normal or is there something lose?
  18. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    When I did mine, the grill had some give to it when I pushed the foam in there but I wouldn't say it moved.
  19. Wavey
    Wavey New Member
    Alaska
    So I just did my grill. About 80-85% lower and maybe the same on the upper. I couldn't get a perfect seal on the lower or it would have been 100%. I thought about doing 100% upper - anyone know of a problem with that? Up here in Alaska we generally don't see above freezing temps from Oct. until March save for a couple of days here and there. Heck, I'll bet dual 100% blockage wouldn't hurt anything around here during that span. Thoughts?
  20. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I doubt it would hurt either but until I get a Scanguage II (monitors coolant temp among many other things), I won't block the upper. Behind the upper is the inverter radiator. That is the big unknown for me.
    Does anyone know if the inverter coolant has a sensor (and that can be read from the Scanguage)?
