65k miles, recommended maitenance?
Discussion in 'Gen 2 Prius Technical Discussion' started by fossilfuel, Oct 12, 2009.
  1. fossilfuel
    fossilfuel New Member
    25
    Manhattan Beach, CA
    Have been doing oil/filter/rotations every 5k miles (intermittent cabin and engine filters when dirty). Replaced tires at 40k. Havent had any issues with the car so far.
    What are some must check/replace items that I am missing? I try to stay away from Toyota dealerships due to cost, but now that I am at 65k miles, wonder if its worth doing a full overhaul to see what needs changed/replaced. I have to assume my break pads should be looked at soon.
    Thanks for your advice!
  2. fossilfuel
    25
    Manhattan Beach, CA
    Mechanic recommended Transmission service (flush)? Other than oil/filters/rotations, what else needs to be done?
  3. MJFrog
    MJFrog Active Member
    780
    267
    NE Oklahoma
    2018 Nissan LEAF
  4. dcoyne78
    dcoyne78 New Member
    135
    I would recommend changing out the PCV valve as well as a transmission/differential fluid change, hopefully you have changed the air filter, if not every 15k miles is a good idea.
  5. richard schumacher
    7,664
    1,046
    United States
    The galaxee list referenced above is in addition to the standard items shown in the Scheduled Maintenance Guide that came with the car, also shown here:
    Toyota Parts and Service
    Anything else is pretty much a boat payment for the dealer.
