Umm... how did the dome light fuse blow??
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tideland Prius, Nov 10, 2009.
  1. Tideland Prius
    16,547
    So... i was in the garage this evening. I had the hatch open and I was cleaning the interior and tidying things up. I also had the front passenger door opened. It couldn't have been more than 10 mins.
    At first I thought it was the battery saver function but then I noticed that I couldn't even turn the maplights on. I tried turning the car on (READY) and still nothing. No dome, door sill, door courtesy, trunk or footwell lighting. i checked the manual and surprise surprise they were all connected by the same fuse. In addition, the mirror and the garage door opener wouldn't work which meant I was stuck in the basement unless someone was entering/exiting the garage and I squeezed by after them. My friend has the garage door opener since his car doesn't have Homelink and he won't be back til later this evening.
    So.... any idea how the fuse blew? I'm sure I've left the hatch and front door opened for longer than that (I've tidied up the interior more than once). Of course, I'm assuming it's the fuse. I couldn't get the fuse out from fuse box to inspect it but all the things that were listed in Fuse 29 weren't working so it seemed like a reasonable guess.
    Oh and the Slip Indicator is permanently on (I have no Hill Start Assist).
    So, any idea how to fix it (at least temporarily)?? I won't be able to visit the dealer til Sat.
  2. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    Have your friend pick up a new fuse and replace it. I am sure that sounds like your issue?? Maybe all the doors and lights on just happened to blow the fuse for whatever reason...10 mins...not the general time to have all doors and hatch open etc...but a fuse is small price if that's all it is....:)
  3. Tideland Prius
    16,547
    Yeah.. it was the fuse. All's well now. Thanks!
  4. qbee42
    3,079
    Perhaps you had a questionable fuse. Keep a spare just in case.
  5. EZW1
    EZW1 Active Member
    722
    81
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    Often fuses will blow from old age - especially if they are used heavily. A fuse is a piece of metal designed to melt when the current drawn through them exceeds a certain level for a period of time. For example, if you draw 100 amps through a 10 amp fuse it will immediately blow. If you draw 12 amps through a 10 amp fuse, it will blow after a few minutes. If you draw 10 amps through a 10 amp fuse it will blow after quite a period of time. Get the idea?
    Your dome fuse was likely used near its rated limit over a period of time and just gave up the ghost due to its age. This does not mean you have an electrical problem, just a tired fuse.
  6. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    Manufacturing tolerances being what they are, once in a while you just get a bad fuse, you replace it, and the new one never blows.
    All cars that I have had that were made in the last several years have spare fuses in the fuse block along with a fuse puller, doesn't the Prius?
  7. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Oddly though, at least two other owners have reported fuses blowing for no obvious reason. Same symptom, the slip indicator coming on.
    hmmm
  8. qbee42
    3,079
    It could be that this circuit runs close to the edge when all of the interior lighting is in operation.
  9. Tideland Prius
    16,547
    My car is 2½ months old. Hardly old age :) (assuming the fuses are new)
    I think I've figured out why. It must've been when I installed the door courtesy LED light. I decided to install some LEDs since I was downstairs cleaning the inside of the car anyway. I'm surprised that will short the circuit. Lesson learned.
    I've got a couple. See my response to spiderman above
  10. GuamKelly
    GuamKelly Member
    274
    68
    Ipan, Guam
    Glad i saw this thread. It never would have occurred to me that something as simple as a dome light fuse would disable a car -- ANY car! I'll make sure I locate it, replace with new, AND carry a spare. What a bummer it would be to be out and about, and without a spare when it failed, huh?
  11. Tideland Prius
    16,547
    Indeed. I couldn't get out of my garage because Homelink wouldn't work (and my roommate has the remote since his car doesn't have Homelink)
  12. kbeck
    kbeck Active Member
    420
    275
    Metuchen, NJ
    Interesting. There have been some comments below, but I'll try and give a bit more definitive answer. I think I can do this because, well, I happen to design fuses into electronic equipment from time to time.
    First things first: Fuses have lifetimes, much like light bulbs, and for pretty much the same reason: Metal fatigue. For a fuse to work it has to warm up to the point of melting when you hit its over current specification. Now, suppose that your "normal" load is 1A. Typically, a 10A fuse would be used in this case. The idea is that if there's a short, there'd likely be 10X the current and said fuse would blow. But, if a 100A fuse was used instead, a fault typically wouldn't go up to 100A, the fuse wouldn't blow, the spot where the short was would get hot, and Fires Would Be Us.
    Given that metal is metal, if a strip of metal is carrying 1/10 the current necessary to melt the thing, said metal will get warm. That means that every time the current is turned on and off the metal will flex while it expands and contracts; hence, over time, all fuses will tend to blow. That goes for circuit breakers, too.
    The other interesting thing about the math is that the smaller the fuse, the hotter it runs at that 0.1X current point. A 10A fuse running at 1A runs at a certain temperature; a 0.1A fuse running at 0.01 A runs much hotter that that 10A fuse running at 1A. Therefore, smaller fuses tend to last a shorter period of time. I suppose that the 0.1A fuse, being thinner, is naturally more flexible than a thicker, stiffer 10A fuse, so maybe it's not quite as direct, but there you are.
    So, in no particular order:
    1. Just like if one tests the lifetime of a case of 100W light bulbs, one quickly finds out that the (say) 2000 hour time for the light bulbs is an average. There will be some short-timers in there.
    2. Raising the current draw on a fuse makes it run hotter. The heat-current relationship is not linear, so doubling the current, while still being less than the limit for said fuse, is going to make that fuse last a lot shorter.
    3. Early death in fuses is a given, just like in any electronic device. Look up the phrase, "Bathtub Reliability Curve." Some things die just out of the box: It's the reason that car manufacturers have warranties.
    Regards,
    KBeck.
    3 people like this.
  13. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Fascinating. I was in Electronics for years and now I understand the stern warning on overfusing. 10X Wow!
  14. Tideland Prius
    16,547
    @kbeck: Thanks for the info! Well the cause of the blown fuse was my own fault. I blew it while installing the door courtesy light.
