żółty trójkąt !!! mruga ! i blokada auta
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by krisklaczus, Oct 31, 2019.
  1. krisklaczus
    krisklaczus New Member
    Zgorzelec
    Ładowałem baterie GV na postoju , bo miala tylko dwie kreski , bieg D i gas do dechy , naładowało do czwartej kreski i koniec , wyłonczyło sie ładowanie na pulpicie monitoringu , ja dalej z 5 min jeszcze trzynałem noge na gaie. Po tej operacji zółty migający trojkąt !!! i wszystkie kontrolki swiecą siągle !! pomocy , ci robic robic ?
  2. Attila Fekete
    Attila Fekete Member
    164
    59
    Budapest, Hungary
    Using English will help you to get answer.
    Anyhow, reading the error codes with Techstream would be needed.
    51,021
    or at least google translator:cool:
  4. Attila Fekete
    164
    59
    Budapest, Hungary
    Google translator is a piece of sh... - explicitly when one of the languages is Hungaian - but that’s what I have used too. :)
    I wonder what it really means:
    Używanie angielskiego pomoże ci uzyskać odpowiedź.
    W każdym razie konieczne byłoby odczytanie kodów błędów za pomocą Techstream.
  5. Tideland Prius
    16,428
    Hmm, his location puts him in Poland. I guess it's written in Polish?
  6. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    Google translate makes this out of it:
    No idea what throwing the legs on the gaie means but I do suspect that this is not the way to get hour HV battery to a normal charge. Either let it sit idle and it will probably shut off at 4 bars or drive it.
    If the triangle persists after some cooling down and a restart, take it to a dealership to have the errorcodes read.
  7. Dimitrij
    Dimitrij Active Member
    405
    202
    Virginia
    He probably thought that if he posted in Polish someone would reply also in Polish, to avoid using online translators.
