'04-'05 front strut compatibility question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by BerkshirePrius, May 9, 2007.
  1. BerkshirePrius
    BerkshirePrius New Member
    121
    Berkshire, NY
    Anyone here know if the part numbers or the struts are the same from 2004 to 2005? I want to replace my front struts in my '05 and can get a good deal on '04 struts. The seller was not sure if they are compatible. Thanx. :)
  2. NuShrike
    NuShrike Active Member
    1,378
    <div class='quotetop'>QUOTE(Al S. @ May 9 2007, 04:41 AM) [snapback]438171[/snapback]</div>
    They haven't changed for the 2004-2005 years, nor in mounting for '06 to '07 yet either.
    If you can, it's better if you can get the '06 - '07 struts because of improved stiffening.
    http://www.sigmaautomotive.com/jdm/prius/prius0405.php , search for "OE Struts & Shocks".
