07 Prius won't start after repairs
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bartwilk, Mar 24, 2010.
  1. bartwilk
    bartwilk New Member
    Milton
    I'm working on a 07 Prius, it has been in a side impact accident.
    The car drove after the repairs the car won't start.
    I did some welding on the car and I only disconnected the small battery.
    I'm getting these codes when I scan the HV ECU
    P0A0D
    P0ADC
    P0AE7
    P0AE0
    And In the ABS-VSC ECU I'm geting these codes
    C1259
    C1310 with a sub code 156
    When I try to clear the codes they come back right away.
    Any body has any idea what could it be??
  2. linuxpenguin
    linuxpenguin Active Member
    352
    182
    All of these codes have to do with the high voltage battery system (First one is service plug failure, second two are contactor related and the last one is motor performance). The ABS DTCs are also related because it expects regenerative power.
    Is the service plug in? Have you inspected the battery box area around where the contactors are? You should also inspect the high voltage power cabling that runs along the drivers side of the vehicle.
    Andrew
  3. bartwilk
    bartwilk New Member
    Milton
    The plug is in, have checked every connection and the cables along the driver side are ok.
    What I've just noticed is that when I leave the ignition on the rear wiper comes on intermittent and the switch is off.
    Is it possible that i could fry the HV computer?
  4. Patrick Wong
    18,200
    6,491
    When you insert the orange interlock switch, you have to pivot the lever 90 degrees. Then you must slide the lever (either up or down, I forget which) to lock it in place. See if that helps.
  5. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    I'm sure I read somewhere in the past, that if your going to weld on the car your supposed to dissconnect the HV battery.
  6. bartwilk
    bartwilk New Member
    Milton
    I have finely found the problem.
    When I was spreading spot welds on the rocker panel I went through the panel around the dogleg and the drill cut 4 wires in the harness.
    I fixed the harness and now all is good after hours and hours.
    thanks for help
    miscrms likes this.
  7. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Lucky, I worked at a station and 1 particular lazy cameraman decided the camera pedestal steering ring made a great chair, until his weight broke the ring. They brought in Joe Welder who did not know squat about electronics, and promptly grounded the welder to the camera. After he finished welding the ring, the steering system now worked great, unfortunatly the arc FRIED the electronics in the camera.
    Guess who had to repair the system...... I never saw so many blown 2N3904's and 2N3906's, until I got to Hollywood and blowing up cameras with AC was a common occurance. I got so I could fix the system in about a day!!!
    Nice job on troubleshootong the system and finding the 4 broken wires. It could have been a lot worse!!
    Electronics and Welding really do not play together well!!
    miscrms likes this.
  8. buckettea
    buckettea New Member
    sydney
    I'm getting these codes after having the HV battery out:
    P0ADC-266
    P0AE7-224
    P0AE0-228
    not checked the engine ECU yet... I did get another one (something about DC inverter but i'm not sure which)
    i'm guessing it's something similar to the OP problem - just can't find any issues with wiring. hoping not to need to take the battery out again unless i have to. if the OP is still around, can you describe which wires you'd damaged? it might point me to the general area of where to look.
    EDIT: so I found what the codes mean (posted below). deducing i hadn't messed with the ECU, and the other common cause was the wiring harness I pulled the pack out again to check the wiring.
    Each pair was reading a voltage at the plug for the ECU, but I don't know if there is some other magic going on (like some shunt circuit) so ended up cleaning up all the terminals to see if it helped.
    Seems to have done the trick, codes are gone and have had the car 'ready' for about a day and took it for a 50km round trip.
    Trouble Code: P0AE7/224
    Hybrid Battery Precharge Contactor Control Circuit High
    Possible Causes:
    Wire harness or connector
    Hybrid vehicle converter (DC/DC converter)
    Hybrid vehicle control ECU
    Trouble Code: P0AE0/228
    Hybrid Battery Negative Contactor Control Circuit High
    Possible Causes:
    HV relay assembly
    Trouble Code: P0ADC/226
    Hybrid Battery Positive Contactor Control Circuit High
    Possible Causes:
    HV relay assembly
    #8 buckettea, Dec 23, 2014
    SFO likes this.
  9. Don To
    Don To New Member
    After replacing your hybrid battery, if the Battery isn't grounded these codes will show up. P0AE0, P0ADC, P0AE7.
    If the orange interlock switch isn't pushed all the way down after engaging it this code will show up. P0A0D.
    They may very well be intended for other DTC but they will show up in either of these senerios.
    kutcht1 likes this.
  10. bisco
    50,833
    did you drill through the harness as well?
  11. Southern81
    Southern81 Junior Member
    Lexington Ky
    I get these codes same 3 codes about once a week. Can anyone tell me where the hybrid battery is grounded at?
  12. dolj
    dolj Senior Member
    8,124
    4,137
    Wellington, New Zealand
    The battery should be grounded when it is bolted down. See the bolts circled in red in the attached diagram. There are another 5 on the other side. I believe you will get satisfactory grounding with at least 2 bolts torqued down, if you need to do some testing, before completely bolting it all down.
    kutcht1 likes this.
  13. Q*bertZ
    Q*bertZ Member
    155
    38
    greenville south Carolina
    2002 Prius
    This is what P0AE0 means. It happened to me. I rebuilt my '07 Prius battery and then messed up and put a bolt in a hole in the drivers side under the back seat. If you do this you will render the battery and all the repairs you just did on it useless, because that bolt will go right through the front relay in the HV battery and ruin the relay. Take the battery apart again and remove the front relay and look for a hole like this... picture included. you will need a new one.
