12.33 volts on 12-volt
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cyberpriusII, Nov 13, 2022.
  1. cyberpriusII
    cyberpriusII Prodigyplace says I'm Super Kris
    1,150
    1,682
    Iowa
    Guessing its time to replace??
    Car sat overnight. Cracked open the hood when I shut it down yesterday. Checked at front points without opening or awakening car about 12 hours later (this afternoon).
    BTW, car showing no issues.
    Kris
  2. dolj
    dolj Senior Member
    8,184
    4,167
    Wellington, New Zealand
    If you have a battery charger, you could try doing a full recharge and then repeat your test. If that doesn't yield better results, then maybe a new battery is in your future.
    What really matters, though, is what voltage is the battery pulled down to when you start the car, or when the brake accumulator pump runs.
    cyberpriusII likes this.
  3. cyberpriusII
    1,150
    1,682
    Iowa
    Thanks. Did not think about hooking up the charger. Will give that a try.
    Kris
  4. Mendel Leisk
    40,457
    I checked on a relative’s vehicle: they’re on vacation for 3 weeks, so about 10 days after their departure went over, hooked up my Solar BA5, a tester that does electronic load test of CCA.
    It read lowish 12.3 volts, same as yours, AND measured CCA over 800 (spec is 650), and gave a verdict of GOOD, not even GOOD BUT CHARGE, it’s next verdict option.
    Took it for a drive, for good measure, should help.
    Bottom line, don’t write-off a battery on voltage alone.
    I’d second the charging recommendation; we’re low annual miles, and I keep it on a CTEK 4.3 smart charger more-or-less constantly. Current battery over seven years old.
  5. bisco
    51,020
    get a lithium jump pack. handy with all your vehicles, last a long time, use the 12v until it won't start, get the most life out of it.
  6. cyberpriusII
    1,150
    1,682
    Iowa
    Lithium packs are great. Have them in all my cars. Only had to use one one time on my Subaru. I was at home at the time and surrounded by other 12-volt cars, as well as had a solid "real battery charger with jumpstart features" nearby.
    But decided to test my little $60 jump pack and it was somewhat quick and easy (the instructions, though straightforward, lost a bit from whomever translated from ??? to English).
    kris
  7. cyberpriusII
    1,150
    1,682
    Iowa
    And, yes, it is time for a new battery,,,,can't complain. YUSA (did I spell that right) makes the best!
  8. Frontporch
    Frontporch Active Member
    494
    107
    Nj
    Not sure how many resellers there are outside of toyota for the 12V. I broke down on the road and had the dealer do a quick battery check and they tested it with a handheld tester. Said it was OK, so that makes them honest. Battery still working well a year later. A good battery meant that something else was really wrong.
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,830
    Clearwater, Florida
    12.3 volts is fine at the front jump point. A perfect battery lives at 12.6 volts so your fine.
    Here's a better test: At night before you start the car turn on the headlights. The day you see them dim a little when you start the car then start looking for a new battery.
    Your a long ways off from that at 12.3 volts.
