12V battery-11.9v engine off &13.7v with Hybrid battery 'only'running
Discussion in 'Gen 2 Prius Technical Discussion' started by ski.dive, Apr 11, 2019.
  1. ski.dive
    ski.dive Active Member
    957
    241
    Hutchinson Island,FL. Mt. Snow,VT
    OK , my12V is 6 years old, not giving me any issues.
    MY 12V battery, showing 11.9V with engine off'
    And 13.7V with the Hybrid Battery running and the GAS MOTOR OFF
  2. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    13.7 seems normal for a gen 2 in Ready.
    11.9 is of course, bad. (didn't you JUST have a thread on this?)
    edthefox5 likes this.
  3. ski.dive
    957
    241
    Jimbo-I just posted these readings, that I took.
  4. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
  5. ski.dive
    957
    241
    Jimbo, yes!!
    this one has the detailed number readings of the 12v, other said 6 year old battery only.
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    one of the things that is mentioned here over and over is that a "voltage reading", on it's own, is not a sure-fire way of determining the true health of a battery..................
  7. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    Any auto parts store should be able to test the 12v battery to get a true real world capacity.
    The SKS model battery is rated 325 CCA when new, but tests significantly higher when new. I would say if it is tested and shows under 275, I would get ready to replace it.
  8. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,798
    2017 Prius c
    You are being a little dense here.
    You already had one thread started to discuss your battery.
    You could have and should have put the voltage readings IN THAT THREAD TO KEEP ALL OF THE DISCUSSION TOGETHER.
    The first reading is the battery itself and 11.9 is a bit below half discharged. NOT GOOD.
    The second reading is really not the battery but the charging system.......and 13.7 is OK.
    As you suspected, you need a new battery.
  9. sam spade 2
    7,035
    2,798
    2017 Prius c
    It certainly CAN be.....if you take the conditions under which the reading was made into consideration.
