12V battery at 12.5 volts. Should I worry about sulfation?
Discussion in 'Prime Main Forum (2017-2022)' started by frederw1701, Jan 13, 2025.
  1. frederw1701
    frederw1701 Junior Member
    43
    WA
    2018 Prius Prime
    Measured with car off, meter leads on terminals.
    The charts I see online say that's not a full charge, and looking at 12V battery discussions here a lot of people have said the car undercharges them.
    Uncontrolled variable: My garage was cold when I measured it.
    The battery is six years old and therefore should be babied until I replace it. Is it crazy to hook it to a Battery Tender?
  2. Mendel Leisk
    40,230
    Crazy not to.
    That said, 6 years old and 12.5 volts, it might be on the way out. An electronic load tester will give a better idea. I'm using a Solar BA5 for that (current iteration is BA9). You connect it directly to the battery posts, set a few variables and run the test. It'll tell you the as-tested Cold Cranking Amps, and give a verdict: Pass, Pass-but-Recharge, or Fail.
    Prodigyplace likes this.
  3. frederw1701
    43
    WA
    2018 Prius Prime
    Understood, it's near end of life. Does a CCA test produce data relevant for a Prius 12V battery?
    I respect your advice. It just feels weird to hook a battery to a float charger when I drive the car every day.
  4. Trollbait
    12,227
    Another option is to hook up a charger once a week instead of daily to a float charger.
  5. Mendel Leisk
    40,230
    Yeah then it's overkill. We're using ours sometimes as little as once a week, albeit good drives usually, so my perspective is coloured by that.
    Batteries are batteries. Just because Prius doesn't crank the engine, it doesn't negate the significance of low Cold Cranking Amps. A battery in good shape will invariably have tested CCA higher than spec.When your battery has lowish volts and CCA less than spec, it's time to replace.
  6. Gokhan
    Gokhan Senior Member
    5,541
    2,174
    Paramount CA
    Your Gen 3 does not have a BMS. The SOC the Gen 4 and Gen 5 BMS keeps the 12-V battery at is actually as low as 75%, which is 12.35 V for a flooded cell and 12.58 V for an AGM cell.
    You are right about the importance of occasionally using a battery maintainer (not a battery tender) in Gen 4 and Gen 5.
    Also, Gen 2 and Gen 3 have AGM batteries, which have a voltage about 0.25 V higher than the OEM flooded-cell battery has in Gen 4 and Gen 5.
    #6 Gokhan, Jan 14, 2025
  7. Gokhan
    5,541
    2,174
    Paramount CA
    I don't know how accurate your measurement was and if the battery was rested for at least 16 hours, but if both are true, 12.50 V is 87.5% for a flooded cell, which is very good for Gen 4 and Gen 5. One caveat: Sulfated batteries (degraded due to sulfation) may have an artificially raised open-circuit voltage, which would not correspond to a good charge capacity.
    The Gen 4 and Gen 5 battery-management system (BMS) is very miserly and likes to keep the 12-V-battery SOC at as low as 75% (12.35 V for a flooded cell and 12.58 V for an AGM cell).
    Yes, occasionally using a good battery maintainer like Noco Genuis or such (not a battery tender) in Gen 4 and Gen 5 is a great idea to bring the SOC to 100% and reduce sulfation, as the BMS hardly ever charges to a 100% SOC.
    #7 Gokhan, Jan 14, 2025
  8. BiomedO1
    BiomedO1 Senior Member
    2,568
    1,380
    SacTown, Ca
    I wouldn't worry about it; especially since it's a daily driver. I check my battery quarterly or semiannually; whenever I reminder to. A couple of times I've found it down to 11.75 Vdc. It still got the car into 'ready mode' without assistance. I put a charger on it @ 6A for a couple of hours and it's back up to 12.75vdc. The rumor is that a gen4 will go into ready mode, all the way down to 10.75vdc. Just check your electrolyte levels every year and you should be good. I normally get at least 10 years out of my batteries by just maintaining them properly. Don't know about this Prime yet, it's only been 4 years on this OEM battery - but I haven't been stranded yet....:p
  9. Mr.Vanvandenburg
    1,310
    534
    2020 Prius Prime
    For what it’s worth my 20 Prime has charged several days to 100% recently, if the night temps drop into the forties. Miles and hours had nothing to do with it.
    Other times it charges nothing on a three hour trip. The only way I can see to reliably ward off dead battery is a battery monitor. And to keep the 12 volt healthy as much as possible.
    Gokhan likes this.
  10. BiomedO1
    2,568
    1,380
    SacTown, Ca
  11. Gokhan
    5,541
    2,174
    Paramount CA
  12. Mr.Vanvandenburg
    1,310
    534
    2020 Prius Prime
    The Ancel bm200 works fine, have two plus a bm2. I bought on price. Next stop maybe hall effect to measure amps, if I want to waste money for that amps reading. Not really going to change much what the car does. I think Toyota needs to reprogram the charging.
  13. Gokhan
    5,541
    2,174
    Paramount CA
    I wouldn't bother much with the current, as you can guestimate it, but it could be fun, albeit more obsession.
  14. Mr.Vanvandenburg
    1,310
    534
    2020 Prius Prime
    Car charging again today like a champ. Cold night for my area, forties. This afternoon, evening, it will be a wimp at it. If it would charge like it does when it’s a champ it would be normal.
    Gokhan likes this.
  15. frederw1701
    43
    WA
    2018 Prius Prime
    I'm confused, which often means I'm about to learn something.
    I thought "battery tender" was just the trademark for one brand of battery maintainer? Or are you saying it's not a good one?
    BTW I finally remembered that the antitheft system reports the battery charge 12.5 right now, cold garage, car not yet driven today.
    Gokhan likes this.
  16. frederw1701
    43
    WA
    2018 Prius Prime
  17. Gokhan
    5,541
    2,174
    Paramount CA
    What I meant was that use a smart charger/maintainer, not a trickle charger.
  18. Mendel Leisk
    40,230
    That system may be imposing an additional load on the car when it’s sitting. A phantom load test is relatively easy to do. In a nutshell: place ammeter in series between car body and neg post, let car sit, off, for at least half an hour, all doors closed, fobs well away, and measure. Should be around 20 milliamperes.
  19. Gokhan
    5,541
    2,174
    Paramount CA
    It is more than 20 mA in Gen 4 and Gen 5, which are a lot more advanced than your Gen 3.
    These are my observations in my 2021 Prius Prime Limited:
    I got a more accurate number on the parasitic drain:
    • It is a 0.03-V drop in 24 hours for the 50-Ah AGM battery,
    • which is a 2.1% SOC drop in 24 hours,
    • corresponding to an average current of 45 mA.
    It seems typical for a modern car. I doubt it makes a difference with our without Toyota Connect subscription.
    Considering that the battery can already be at as low as a 70% SOC, you do not want to leave the car undriven without a battery maintainer for longer than two weeks.
    Note that even if you do not drive the car and do not have a battery maintainer, you can turn it on to the READY mode for half hour or, even better, for one hour once a week to recharge the battery. It will unlikely go over an 85% SOC, but it will prevent a battery failure and/or serious battery degradation.
    https://priuschat.com/threads/agm-battery-for-gen-4-gen-5-prius-prius-prime-and-observations-on-the-12-v-charging-system.251158/page-11#post-3504966
  20. frederw1701
    43
    WA
    2018 Prius Prime
    It's a Stargard, and information about the Stargard current draw is bizarrely missing from Googlespace. So here it is, from their support people. Tracking mode, "<70 mA", no mention how much less. Sleep mode, <15 mA, and low power sleep mode <2mA.
    I'm confused again. Ammeter in series between negative battery post and car body, why does that work when the negative post is bonded to the car body? Good point about the fobs, I would not have thought of that.
