12V Battery Keeping Charged when stored
Discussion in 'Gen 2 Prius Technical Discussion' started by bear15, Mar 9, 2008.
  1. bear15
    bear15 Member
    168
    35
    Suburban Chicago
    Any suggestions on keeping the 12 volt battery charged when it is not used for a few weeks so I don't have to jump it?
  2. Jack66
    Jack66 Kinda Jovial Member
    766
    Stafford, Virginia
    Most common method I know is a trickle charger. It provides a small but constant charge. There are even solar trickle chargers. I've seen people use the solar trickle chargers when they were leaving their car in one spot for a few months so it would be ready when they got back -- fluids, seals and gaskets are a different problem but you shouldn't be gone long enough to worry about them.
  3. Patrick Wong
    18,200
    6,490
    A few alternatives come to mind:
    1. Use a battery tender
    2. Charge the battery fully with a regular charger, then disconnect it per #3 below.
    3. Disconnect the negative battery terminal, or disconnect the positive lead under the red jump terminal cover at the main relay/fuse box near the inverter
  4. sweetguy
    sweetguy Junior Member
    85
    Maine
    Another suggestion -- shut off the smart key system before storing the car. The switch is under the dash to the right of the driver.
  5. A-Prius Owner
    A-Prius Owner Junior Member
    17
    2001 Prius
    I think the Patco charger is a good one and doesn't drain your battery if left disconected from the AC when the battery hookup cables are connected, alot of other chargers will.
    Some negatives are you have to connect the battery hookup cables prior to plugging it into AC and it's a little heavy.
    http://dkc3.digikey.com/PDF/T081/2219.pdf
    Patco 150 1.5 amp 12 volt Digikey part# PATC-03-ND and Battery hookup spring clamp PATC-07-ND or you could save some money and make a hookup cable with a soldering iron, Battery hookup spring clamps and wire.
  6. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    A trickle charger can destroy a battery if left connected 24x7. They will supply current whether the battery needs it or not
    There are battery tenders that are "smart" and can be left connected 24x7. I use this model
     12 Volt-1 Amp  Charger and Maintainer
  7. darelldd
    6,057
    389
    Northern CA
    While this is prudent, it will not reduce the parasitic draw on the battery significantly. The SKS system draws very little in the grand scheme of things.
  8. bear15
    bear15 Member
    168
    35
    Suburban Chicago
    Thanks to everyone for your very helpful information.
    Is anyone using the mini solar panel version?
  9. Jack66
    766
    Stafford, Virginia
  10. David Beale
    David Beale Senior Member
    5,963
    1,985
    Edmonton Alberta
    Be aware unless you modify your Prius, you won't have any luck charging with a solar panel through the cig. lighter or accessory power plug when the car is off. You will have to do your own wiring to accomplish that.
    Your battery should not loose much charge in a few weeks. If you are storing the car for two months or more, then yes, you should do something to keep the 12V battery charged. Either disconnect the -ve lead or get a battery tender. The tender can be connected at the front underhood boost point, BTW.
    I purchased the Battery Tender Plus listed here:
    Batterytender.com - Home of All Your Charging Needs 2008 Catalog
    If your battery is loosing charge in just a few weeks, then the battery is bad. It may have been damaged by allowing it to fully discharge during shipping to the US, or when it sat at the dealership.
