1. losbadgt
    losbadgt New Member
    Four Touring
    So I was watching a video on how to check the voltage for the 12v battery. And I notice that it reads 12 and then under load it reads 11.9 and 11.8. No dims on my lights or dash lights everything is great. Should I change it already?
    51,041
    yes, even though it's working fine, t could potentially leave you stranded at any time.
    what do you mean, 'already', is it not 8 years old?
  3. S Keith
    S Keith Senior Member
    799
    329
    AZ
    2003 Prius
    There's a natural voltage drop with load.
    To get your unloaded voltage, After your last drive of the day, park the car and pop the hood.
    In the morning, or about 12 hours later, check the voltage at the jump start connection points under the hood. 12.4V is about 70%. 12.65V or higher is fully charged. If it's more than a few years old and not showing fully charged, my inclination is to replace it.
    Note that the only 100% sure fire way of confirming the health of a battery is with a load tester. Most auto parts stores will do this for free if you take it in.
  4. losbadgt
    losbadgt New Member
    Four Touring
    It looks like it was changed 3 years ago. But I just wonder if it was a good idea to change it
  5. bisco
    51,041
    if you test it as s keith mentions above, and find it's lower than 12.4, try charging it. if it won't hold 12.4 or above, i would plan on replacing it. what kind is it? have you discharged it at all, or left it sitting without driving much? 3 years isn't very old.
