Hey everyone, I wanted to share a full update on my experience using Valvoline Restore & Protect in my 2015 Prius (Gen 3), currently at 150,350 miles. I’ve been focused on long-term reliability and preventative maintenance, and this oil has delivered some real improvements. Background: Before switching, I was using Mobil 1 Extended Protection and averaging around 39–41 MPG. The engine had some cold start roughness and didn’t feel very smooth under load. At around 144,350 miles, I switched to Valvoline Restore & Protect 0W-20. I’ve now completed three full oil changes using R&P: First change: ~144,350 Second change: ~146,850 (short 2,500-mile flush interval) Third change: 150,350 (after a 3,500-mile run) Each change used a Valvoline oil filter, and I added BG44K after the second oil change. Driving Results: Current MPG (after 3rd R&P change): 46.1 MPG on a normal commute Previous average (on Mobil 1): 39–41 MPG Improved average during R&P use: 42–43 MPG Total MPG improvement: ~5 to 7 MPG Oil consumption trend: On Mobil 1: ~0.1–0.2 quarts every 3,000 miles After first R&P: reduced to ~0.1 quarts After second R&P: 0 quarts used over a 3,500-mile interval Engine behavior: Cold starts now completely smooth Quieter idle Stronger and more responsive throttle Overall smoother engine operation with no rattles or vibration Other Maintenance Completed: New KYB Strut-Plus front struts Moog sway bar links (front) Recently switched to Bosch QuietCast brakes Planning upcoming work: EGR cooler clean/swap PCV valve Intake manifold clean or replace Engine water pump replacement Final Thoughts: Valvoline Restore & Protect has been a worthwhile switch. Fuel economy is up, oil usage is gone, and the engine genuinely feels healthier. If your Gen 3 Prius is in the 120k–180k mile range and you’re chasing better efficiency or trying to delay oil burning and head gasket concerns, this might be worth testing out. Let me know if you’ve tried it too or have questions about the process or results.
Changing oil won't effect cold starts or rough idle or throttle response. It really won't effect your mpg either, unless you were using 40w or 50w or higher. Which you shouldn't be doing anyways... buttttt....... The bg products don't really work either. Will it effect oil burning????? Mayyyybbeeeeeeee If you've been changing your oil every 5000 miles, not very likely. You have low miles, for a Prius. And with synthetic oil (you have been using synthetic oil?), the engine is going to be very clean. Now if you've been using non synthetic oil, then changing oil will effect how clean the engine is and possibly your mpg. Probably best to still with Toyota OEM oil filters... Perhaps your driving habit's have change. The fuel you use, and are you putting cleaner in the fuel also? That will effect the mpg. I've been using seafoam 500 miles before oil change, and I had used the bg products, NO change. And I started using the valvoline retore and protect since March 2024 at 330,277 Miles. Changing oil at 5000 miles, give or take a few hundred miles using RP. I am currently at 372, 200 miles. So 8 oil changes. I think I'm burning more oil now. You say you've only been getting 40 mpg???? That's horrible. Unless you do a lot of city driving or drive very fast for highway driving. Current MPG (after 3rd R&P change): 46.1 MPG on a normal commute Previous average (on Mobil 1): 39–41 MPG Improved average during R&P use: 42–43 MPG Total MPG improvement: ~5 to 7 MPG 42-39 is "3" 43-42 is "2" That is not a 5-7 mpg improvement. Where are you getting 46mpg average from your information??
