150k on spark plugs experience?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by whodat, May 15, 2010.
  1. whodat
    whodat Member
    117
    Aptos, CA
    Anyone changed their spark plugs at 150K (as recommended by Toyota for CA)?
    I'm at 120k and wondering if the plugs might be frozen/welded into the engine.
    Thanks
    Dave
  2. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    i changed out my plugs around 97k miles.. it was rather easy.... i was thinking about seizing too.. yet had not difficulties.
  3. tochatihu
    tochatihu Senior Member
    9,452
    3,654
    Kunming Yunnan China
    2001 Prius
    whodat, it may be actually the case in California that you are supposed to replace spark plugs at 100k miles. This is my recollection.
    Anyway, I would not wait much longer for that, either. If you DIY, use the correct iridium replacements (2 choices) and make sure your plug wrench is well-seated before torqueing them out. Mine made rather horrifying sounds as they unwound from the aluminun cylinder head. New plugs should get anti-sieze on their threads.
    Photograph the electrodes of the old ones close up if possible please. I have an interest in electrode erosion.
  4. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    If they've been in there that long, once you crack them and they
    start turning, work them gently back and forth and go SLOWLY
    in a net loosening direction as you do that to remove them.
    Hopefully they haven't bound to the head metal tight enough to
    cause damage. The forums have advised removing all the plugs
    earlyish in the game and getting some anti-seize on the threads,
    but if that's never been done then high caution is in order.
    We could only wish Toyota had anti-seized them at the factory...
    _H*
  5. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    Is there a torque spec for the plugs? Would anti-seize cause over torquing? Thanks!
  6. Patrick Wong
    18,200
    6,490
    13 ft.-lb. If you use anti-seize lube, apply a small dab on the spark plug threads. I would not worry about over torquing.
    I question the 150K mile change spec in CA since the iridium plugs are the same in all Prius and the service interval spec is 120K miles elsewhere. The Denso website suggests the original equipment iridium spark plugs are good for up to 120K miles.
    http://www.densoiridium.com/faq.php
    My guess is the extended CA spec is for regulatory reasons, not technical reasons.
    If Dave is concerned about waiting until 150K miles, nothing prevents him from changing the plugs now (I changed my plugs at 100K miles).
  7. whodat
    whodat Member
    117
    Aptos, CA
    Spark plug service - 2006 Prius Scheduled Maintenance Guide book page 19, PZEV Prius in California, New York, Massachusetts, Maine and Vermont replacement interval is 150,000 miles.
    I also verified this information on the Toyota web site.
    This is why I am asking about this recommendation from Toyota
  8. tochatihu
    9,452
    3,654
    2001 Prius
    You will find that a few cranky old PC-ers are selective on which of Toyota's recommendations should be followed exactly. T. does not see much reason to change transaxle fluid either. That is another story, of course, but perhaps you would consider doing it after wrestling with the sparklers?
  9. whodat
    whodat Member
    117
    Aptos, CA
    Actually I had the transaxle fluid changed at 60K. The dealer thought I was crazy. :)
    Dave
  10. hobbit
    4,089
    468
    Bahstahn
    Y'all [particulary DAS] saw my pictures of variously worn vs. new
    electrodes, right?
    _H*
  11. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    I'm at 152,000 right now on the original plugs. I'll probably change them at the next service for another 150K miles.
  12. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,000
    Fort Lee, NJ
    I changed mine at 113k miles and I wish I waited until 150k miles. They were still in great condition.
  13. Patrick Wong
    18,200
    6,490
    Did you measure the gap of the used plugs? Regardless of physical appearance, 1 - 1.1 mm is the spec and they should be replaced at 1.2 mm.
  14. usbseawolf2000
    14,487
    3,000
    Fort Lee, NJ
    I still have them... when I get the tool to measure them, I'll post the results.
