175 width tyres
Discussion in 'Gen 3 Prius Fuel Economy' started by edwardob, Apr 9, 2013.
  1. edwardob
    edwardob Member
    227
    33
    ireland
    would 175 width tyres do for prius 2010
    got offer nice alloys with 175/65/14 good tyres
  2. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    That tire would be WAY too small for a Prius, especially a GenIII. Not only would the diameter be too small by a whopping 2" the load rating is much too low for the weight of the Prius. You need an 88 load rating or higher except in the case of the low profile 215/45/17s which are 87 but compensate with more robust construction.
    What does all that mean?
    You'll suffer very sloppy handling, braking distance would increase, mpg would decrease, tire blowout is increased greatly, emergency handling suffers as would highway straight line stability. I.e. don't do it.
    edwardob and xpcman like this.
  3. danvee
    danvee Blizzard Brigadier
    326
    53
    38
    New Jersey
    Plus, a 14" wheel, even if hub, offset and bolt pattern were correct, might not even clear the brake discs...
  4. edwardob
    edwardob Member
    227
    33
    ireland
    thanks not sure how all this works!
    205/55 R16 be ok?
    205/55R15 be ok?
  5. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    205/55/16 = Yes
    205/55/15 = NO
    I hope you're not doing this because you are trying to source cheap tires. Cheap non-LRR tires may cost you more in the long run vs. a good LRR tire.
  6. edwardob
    edwardob Member
    227
    33
    ireland
    actually i have access to different wheels tyres for near to nothing...so i can take advantage
    and i not sure what prius can take/handle
  7. andreyco
    andreyco Member
    91
    27
    edwardob likes this.
  8. edwardob
    edwardob Member
    227
    33
    ireland
    wwwooooooooooow!!!!
    thats amazing thanks
  9. Braddles.au
    Braddles.au DEFAnitely using an EBH
    295
    99
    Canberra, Australia
    The lowest specification Prius L in Japan wears 185/65/R15, apparently on the same wheels as the 195/65/R15. Gets a few more km per l than the wider-tyred models.
    If you reduced to 175 on 14", you would need something like 80-ratio if you could find them to maintain outside diameter.
  10. edwardob
    edwardob Member
    227
    33
    ireland
    i think this is was i was trying to figure out.......the lowest spec prius can tolerate
  11. edwardob
    edwardob Member
    227
    33
    ireland
    since then i got wolrace 15 wheels[from mark 4 golf] with 195 65/15 tyres on .....cant belive difference in mpg from 17" wheels so far....like nearly 5mpg amazing diff ..cheap wheels[free] cant beat that with average 41/2 mm tread left
