18650 how?
Discussion in 'Gen 3 Prius Audio and Electronics' started by Ben Schneider, Dec 2, 2024.
  1. Ben Schneider
    Ben Schneider Junior Member
    central florida
  2. ChapmanF
    16,940
    To replace the 201.6 volt, 125 amp, 6.5 amphour hybrid battery? Why?
    If the highest-output ones you're looking at can give 5 amps. you'll be looking at around 1,350 of them, in something like a 54s25p configuration. You'll also need to build a battery management system able to prevent imbalances developing within or between those 25 strings of 54, and work out how to make your BMS communicate with the car's HV control ECU.
    It sounds like a good source of headaches ....
    Brian1954 likes this.
  3. ASRDogman
    ASRDogman Senior Member
    7,006
    3,668
  4. Grit
    Grit Senior Member
    6,366
    4,154
    Wilkes Land
    Reinventing the wheel eh?
  5. bisco
    50,800
    we need missionaries
  6. Ben Schneider
    central florida
    maybe less than 60 batteries
  7. MAX2
    MAX2 Senior Member
    1,333
    415
    101
    Third planet from the Sun
    Bargaining is not appropriate here!
    1350!
  8. DirkAshburn
    DirkAshburn Member
    109
    44
    Virginia
    Over covid I upgraded an old electric E300 scooter, overvolting it to 36v powered with 3 18650 custom packs. This is the same thing, just a tad more upscaled right? :)
  9. Grit
    Grit Senior Member
    6,366
    4,154
    Wilkes Land
    The scooter would just overheat and burn itself in flames on the sidewalk and won’t need to call the fire department. If a car does that, you’ll be on the news.
