293,000km, soon stuck at 299,999?
Discussion in 'Gen 2 Prius Technical Discussion' started by R-P, Mar 19, 2021.
  1. R-P
    R-P Active Member
    804
    288
    Netherlands
    Just called dealer and chose 'technical question' in the phone-menu. What happens at 299,999km? Answer: goes to zero again.
    So I ask: goes to zero or gets stuck at 299? He didn't know.
    If it resets, I can live with it. Some cars from the early 2000's only have 5 (mechanical) digits... But if it gets stuck, I can't!!! Is there a solution? Yes, new meter which starts at zero. I didn't ask if they would replace it for free, but I think I know the answer...
    So is there a solution?
  2. Mendel Leisk
    40,235
    If it’s a 2009, like your stats show, maybe no problem; it was only some early years of gen 2 doing this?
    R-P likes this.
  3. R-P
    R-P Active Member
    804
    288
    Netherlands
    Would be great if that were true. Got triggered by looking at a cheap (but safe) runabout for my daughter and found tons of Prii with 299,999km... Didn't pay attention to their manufacturing dates but will have a look if there are 2008/2009 among them.
    Edit: most seem 2004/2005/2006. Also found a 2004 with 315,000 so now I am confused :ROFLMAO:
    But if there is little I can do about it anyway, I'll just *try* to use the second resetable meter to zero once I am at 300,000km and keep track of when I reset it. I keep track of it anyway, but the non-resetable one made sure I didn't forget one.
    Long ago with my motorcycle on holiday I was really happy that it used so little gas only to find a forgotten receipt a month later... (Went from a CB350 (350cc) to a CB750 (750cc) to an Pan European ST1100 (1100cc) and each one had a bigger gastank AND was more frugal!)
  4. PriusCamper
    PriusCamper Senior Member
    11,851
    4,803
    Pacific Northwest, USA
    It will go way past 300,000km as long as you added enough blinker fluid...
  5. msg7086
    msg7086 Member
    39
    38
    North Jersey
    It's 2004-2006 that carries version 1 of the dashboard.
    The link you post shows 299999 on the pic if you look closely.
  6. R-P
    R-P Active Member
    804
    288
    Netherlands
    Damn, you have better eyesight than I do ;) They must have extrapolated. When my odometer was off my bike (accident that wrecked my cowl) and I drove it without for a month, I later put a drill on it to get it to the correct mileage.
    Just topped it off, so that shouldn't be an issue.
    PriusCamper and Mendel Leisk like this.
  7. PriusCamper
    11,851
    4,803
    Wow! They sure don't make blinkers as nice as that anymore!
