4th gen head gaskets are starting to show up in large numbers...
Discussion in 'Gen 4 Prius Main Forum' started by AmazingFacts, Aug 9, 2023.
  1. AmazingFacts
    AmazingFacts Member
    112
    62
    San Jose
    Two Eco
    4th gen head gaskets failures are starting to show up in large numbers.
    Fourth generation Prius head gaskets are starting fail.  - YouTube
    I just picked up a 2016 Prius Eco project car with almost 300k miles with blown head gasket. Engine turns over and hoping that the piston rods aren't bent. HG failure symptom are there from milky oil, rattle upon startup, and using up coolant fairly quickly.
    Any threads here on a head gasket replacement for 4th gen? Should be very similar to 3rd gen HG replacment job correct?
    Is it possible that all hybrids have a head gasket failure issue from the repeated warm-up/cool-down cycles? Good explanation here:
    #1 AmazingFacts, Aug 9, 2023
    Mr.Vanvandenburg likes this.
  2. Leadfoot J. McCoalroller
    8,092
    7,574
    Pennsylvania
    2018 Prius c
    Not all hybrids- Toyota's own 1.5L 1NZ-FXE engine is proof of that, before you even look at other brands.
    But maybe all the 1.8L ones....
    51,973
    gen 2 seemed to hold up well, but are gen 4 like gen 3, or is it happening at higher miles?
    AmazingFacts likes this.
    51,973
    tough to tell how many and the mileage from that short clip. there have been reports here, but a lot seem to be from overheating due to the coolant leak at the heat exchanger
  5. Mr.Vanvandenburg
    1,353
    571
    2020 Prius Prime
    There is a big difference in cold to warm in San Jose to somewhere like Edmonton in the winter too. I know what he is saying but so do the engine engineers. Like 100 years ago or more they knew about expansion and contraction in an engine. Engines with cast iron block and aluminum heads, all should be in the junk yard. But are they, no.
    A guy says large numbers showing up, like what are those numbers and how many cars were made? This is how rumors get going. It’s so easy to fall into the rumor trap and think your car is next. I’ve been through it on several cars. Nothing bad ever happened that was supposed to on any.
  6. bisco
    51,973
    it doesn't happen until it happens to you. hopefully never, but on my 12 with 30k on the engine, something's happening
  7. MikeV
    MikeV Junior Member
    95
    philadelphia
    is there an engine code or codes that go along with this?
  8. bisco
    51,973
    Op has 300,000 miles, is that really a failure?
  9. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,467
    2,434
    Taylors, SC
    I'd call it "worn out" or "end of serviceable life,"
    kc5dlo and bisco like this.
  10. MikeV
    MikeV Junior Member
    95
    philadelphia
    i would die before i reach 300k friving only 10k yr on avg
  11. bisco
    51,973
    You’re not going to get a code before the head gasket blows, so either keep a close eye on the coolant, or make a preemptive strike by installing the repair loop
  12. Mendel Leisk
    41,486
    Too, Gasket Masters is not exactly Moses with tablets...
    johnHRP and bisco like this.
  13. Bill Norton
    Bill Norton Senior Member
    2,162
    736
    MONW, Ks.
    Just found this thread only because a friend's '17 Prius @ 205k miles has the infamous Head Gasket failure.
    He was told by a local dealership that, "It's $4800. $5800 with pistons and rings."
    He said he has had that dealer do all the scheduled maintenance since buying the car there used with 35k miles on it.
    Still,, a few days ago his Prius started 'shaking and has a check engine light'....
    I see no reason to call a perfectly fine car with 300k miles on it "at end of life".... Why?
    Just because this particular engine has a pisspoor Head - Head Gasket - Block design? Which is repariable...
    Another Prius friend has +200k miles on a repaired head gasket, on his Gen2, only that shop used the Felpro head gasket.
    Both these guys are couriers and rack up crazy miles on their Prii.
    We'll see if they got it better with the Gen5's... Someday in the future.
  14. bisco
    51,973
    was he losing coolant?
    did they check the exhaust manifold heat exchanger?
  15. Georgina Rudkus
    3,467
    2,434
    Taylors, SC
    The failure of the head gasket comes on as the result of the failure of the rubber like lining on each surface of the metal core of the gasket.
    The 100k miles 10 year Toyota projected service life of the Super Long Life HOAT coolant may be contributing to the degradation of the lining.
    As a precaution, halving the coolant change interval to five years or 50k miles and three years or 30k miles for any succeeding coolant change, being inexpensive, may extend the life of the "rubber" in the head gasket.
  16. Bill Norton
    2,162
    736
    MONW, Ks.
    First: I had a typo ^ above. 'Friend's Gen3 with a Felpro HG with +200k miles on the repair.'
    (He's had many very high mileage Gen2's and never a HG failure.)
    I was sitting next to the Gen4 guy when the call came in from the dealership. On speaker phone they said 'misfire cyl2'. They 'borescoped cyl 2 and saw it dripping coolant from the HG'. Nothing else was mentioned regarding coolant leaks.
    This guy drives his Gen4 as a courier. M-F, +250 mile/day. I don't know if he pops the hood daily. (who does?):whistle:
    I know it just started "Shaking with a check engine light" that morning and he took it directly to his dealership.
    #16 Bill Norton, Jul 26, 2024
  17. Bill Norton
    2,162
    736
    MONW, Ks.
    Didn't know about a 'Super Long Life' coolant.
    I use parts store 'Asian' pink coolant listed for Toyotas and others.
    My current routine is to drain about a half a gallon of coolant slowly enough to refill the reservoir as it flows out, not letting it go dry.
    I have been doing this at each 5k mi. oil change. I have done this 3 times now. Eventually it should be all new coolant, right?:cool:
    This routine give me HOPE!!(y)
    Hope that this pisspoor HG design doesn't bite me too soon.:rolleyes:
    But it looks like it's due someday, right? The good thing is Gasket Masters lists KC as one of their places!
    #17 Bill Norton, Jul 26, 2024
  18. Mendel Leisk
    41,486
    #18 Mendel Leisk, Jul 26, 2024
  19. Georgina Rudkus
    3,467
    2,434
    Taylors, SC
    Coolant change is a 20 minute job when using a UView vacuum device or any of the low cost equivalents sold at Harbor Freight or on Amazon.
    There is no complicated need to put the car into service mode or run, stop and rerun.
    Drain the coolant, pull a vacuum, turn the valve to install the coolant, top off the reservoir. That's all folks!
    Bill Norton likes this.
  20. Bill Norton
    2,162
    736
    MONW, Ks.
    Thanks for the info.
    But I would imagine there is still old coolant remaining in the bowels of the engine and who knows what else doesn't drain completely.
    My method is easy, and eventually I'll have close to 100% fresh coolant,,, I hope.
    Also, I tried to find the 'low cost.. Harbor Freight version of this $1700 tool.
    #20 Bill Norton, Jul 26, 2024
