6 of 7 describes the Prius
Discussion in 'Gen 3 Prius Main Forum' started by bwilson4web, Jan 25, 2009.
  1. bwilson4web
    15,931
    Like another of the seven blind men describing the 2010 Prius, this is my review. Curiously, two days later at the Detroit Auto Show, not by intent, I brought back only two photos of painted sheet metal. Hopefully these notes will provide some insights that might yet be of interest.
    EXHAUST HEAT RECOVERY
    Technically this is a heat exchanger that runs engine coolant through the hot exhaust. This warms up the engine quickly and provides additional heat in the winter for cabin and to keep the engine at an optimum temperature. It taps the 1/3d of the heat typically lost out the exhaust pipe.
    Our 1.5L engines warm up at about 10C/minute until reaching 82C when the thermostat opens and the cooling system begins dumping heat. But the exhaust stream heat exchanger should increase the rate of warm-up to 20C/minute or better (no one has independently measured the efficiency, yet.) In contrast, one hour with a block heater will raise the temperature ~30C and save 3 minutes of warm-up if you have a power outlet. This technique works by using otherwise wasted exhaust heat.
    EXHAUST GAS RECIRCULATION
    You'll notice there are four exhaust ports feeding the manifold and a fifth that feeds to the exhaust gas cooling and control system.
    The cooled exhaust gas feeds via a small pipe to the intake manifold where it can provide up to a 10% dilution of incombustible and now cooled exhaust gas. The reduces the peak flame temperature, which reduces NOx production and allows a leaner mixture to be used. This lean mixture provides part of the fuel economy savings.
    Exhaust gas recirculation systems were used in the 1970s in some of the earliest air emissions systems. However, lacking computer control and timing, they often suffered from 'coking up' that led to higher maintenance and other problems. Hopefully this system will fare much better.
    DUAL VARIABLE VALVES
    Unlike the current Prius engine that only changes the intake valve timing angle, the new one tunes both the intake and exhaust timing. This allows the engine to be optimized over a wider rpm and power band.
    ELECTRIC WATER PUMP
    Ordinarily the water pump has excess pumping capacity and coolant temperature regulation comes from a constricted, mechanical thermostat. This increases the mechanical loss, which means the engine has to work harder. But an electroniclly managed water pump pushes through only as much coollant as needed. Best of all, it can run in hot temperatures to minimize 'cooking' as heat from the exhaust manifold seeps into the block.
    1.8L ENGINE
    The larger displacement and torque means the engine can generate the same power as the 1.5L engine at a lower rpm. This avoids the problem that drag losses are proportional to the engine rpm and higher speeds are often less efficient than a lower rpm.
    20% MORE EFFICIENT TRANSAXLE
    The previous photo also shows the smaller transaxle, which is 20% more efficient than the current transaxle. It does this by elimination of the chain and using 'forced lubrication' (also called 'dry sump.') So instead of a pool of lubricant that is stirred by the gears, oil is pumped to where lubrication and cooling is needed and no more.
    MODULAR TRACTION BATTERY
    The existing, proven NiMH battery modules are now housed in a smaller, separate battery housing from the control electronics. This modular approach makes future technology a lot easier to introduce.
    SPRING AND SHOCK REAR SUSPENSION
    Unlike the integrated, McPhearson strut, this allows changing just the shocks instead of the whole unit. This should lead to improved handling as they age by a simple, affordable shock replacement. Individuals will be able to 'tune' their rear suspension for their typical driving route and style.
    REDUCED UNDER-BODY DRAG
    The bottom is uniform and smooth. This helps reduce an often neglected source of aerodynamic drag. The body also has a more aerodynamic shape with 5 cu. feet more space.
    CONCLUSION
    This is an excellent kaizen refinement of the Prius. There is more that could have been done (hydraulic lifters, more exhaust energy capture, battery improvements) but this is enough for now and provides a reasonable upgrade path for new technology.
  2. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    How would you address the continual collapse of Hydraulic Lifters in an engine that stops so frequently? As much as I'd like them as well (my '04 is beginning to clatter), I'm not sure how technically feasible it'd be.
  3. dogfriend
    7,512
    1,188
    Carmichael, CA
    Because the HSD spins the crankshaft up before starting, wouldn't the hydraulic lifters already have pressure before the engine needs to restart?
  4. bwilson4web
    15,931
    Hydraulic lifters are found in the Lexus 250h:
    They are also found on the Ford Fusion and Escape engines:
  5. HTMLSpinnr
    5,341
    920
    251
    Why no love for Prius I wonder?
  6. bwilson4web
    15,931
    Speculation: hydraulic lifters may not fit in the same cylinder head with the advanced Toyota patent on variable valve technology. The Toyota patent includes the ability to change the valve stroke and potentially eliminate the throttle plate. If I have a choice between valve click and elimination of the throttle plate, I'll eliminate the throttle plate every time.
  7. HTMLSpinnr
    5,341
    920
    251
    Trouble is I'm not sure they did eliminate it this time (we found the servo, or was it the MAF), but if they're one step closer, that'd be nice. What they really need is hydraulically actuated valves ala BMW.
  8. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    You can't completely eliminate the throttle plate on an EGR engine. When the engine starts there's no exhaust gas to recirculate, so there has to be something else to control the amount of oxygen drawn in. You don't start the car at full throttle! (Well, maybe a legacy petrol engine that's flooded.)
    My understanding is that EGR works by keeping the volume and pressure of intake gases constant, but reducing the actual oxygen content. The oxygen content of exhaust is effectively nil - it either combined with carbon to form CO2 and CO, with hydrogen to form water vapour, or with nitrogen to form NOx. (The three-way catalytic converter strips oxygen from NOx, which is then used to convert CO to CO2.) Air is 20% oxygen - if you mix 50% air and 50% recirculated exhaust, you get 10% oxygen content. In addition, the warmer air/exhaust mix is less dense, so less mass of air/exhaust for a given volume.
    Yes, engines run better at peak with colder, denser air, but at low power outputs you want less oxygen in the cylinder so you can inject less fuel while keeping the stoichometric ratio. Just injecting less fuel would make the engine run lean and produce more NOx.
    Once exhaust recirculation is up and running, the throttle plate should open right up to 100% throttle.
    Also, let's be honest: things fail. The throttle plate is also needed to control the engine if EGR stops working. Even diesels have a 'throttle plate' in the air intake, although there it's called a shut-off valve. If the engine runs away the computers can shut the valve to shut it down.
  9. ronhowell
    ronhowell Active Member
    681
    32
    Cypress, CA.
    So in a Prius equipped with EGR the throttle plate is receiving a modulation signal from the ECU as a function of the Intake gas oxygen content, as well as its temperature and pressure? The target I assume is the 14.7:1 stoichiometric ratio for complete combustion of the fuel/air mixture.
    With a higher intake temperature and a lower percentage of oxygen in the intake air flow I can understand (I think!) how a higher throttle setting would apply, even at lower power demand. But chemistry was never my strong suit.
    These modern engine systems sure are getting to be complicated beasts!
  10. grand total
    grand total Member
    154
    ON, Canada
    I'm not sure about that. I think the eventual target should be electrically operated valves.
  11. joe1347
    joe1347 Active Member
    669
    44
    AZ
    Interesting how much stuff/parts are associated with the internal combustion engine as compared to the simpler battery pack and electric motor. Assuming that batteries eventually get 'cheap', one would think that an all electric car would be much cheaper than a comparable internal combustion engine vehicle.
    I wonder what percentage of a cars manufacturing cost does NOT include the actual internal combustion engine?
