6000K HID Fog Lights
Discussion in 'Gen 3 Prius Accessories and Modifications' started by ChrisMNC, Jun 25, 2010.
  1. ChrisMNC
    ChrisMNC New Member
    Huntersville, NC
    I installed them tonight. Bought the kit at carhidkits.com
    really very simple install, took about 20 min. The light does not scatter and REALLY lights up the ground in front of the car. They match the LED headlights pretty much perfect too. I blocked the headlights to see. Now if I could just figure out how to turn the fogs on with the parking lights my life would be complete.
    I will get pics and post later.
    Chris
  2. liskipper
    liskipper Member
    373
    79
    Long Island, NY
    Would you mind posting the part number you got, and perhaps an explanation of what you had to do to install them? Since you say you have the LED headlights, I assume you have a V. Does the time you quote include the uninstall of the existing tungsten fog lights?
    Thanks.
  3. ChrisMNC
    ChrisMNC New Member
    Huntersville, NC
    Sure, once on the site you just click on Toyota>Prius>6000k kit>at the bottom you tell them year/make/model (even though you already chose it) and choose which lights they are for. They sent me the digital slim ballast and I did not pay the $20 upgrade fee. You can also just choose the 6000k kit for the H11 bulb, either way works.
    Install is simple; take off cover below each light, take out current halogen bulb put the HID bulb in, make 4 connections. I stuck the ballast on a metal fixture right below the housing. Put the black tray piece back on and you are done. No special wiring or modifications needed, just plug and play. You use the stock housing and everything all you replace is the halogen bulb.
    Hope that helps. Let me know if I can provide any other information.
  4. Rockys007
    Rockys007 Junior Member
    Irvine, California
    I have a Pkg III that does not have factory installed fog lights. I want to install fog lights BUT with HID bulbs NOT the Halogen bulbs. Does anyone know if someone out there sells a complete fog light kit WITH HID bulbs, without me having to buy a regular halogen fog light kit and then having to buy an HID kit to convert the halogen to HID's. Thanks in advance for any input.
  5. bagwell
    bagwell Active Member
    592
    49
    the woodlands, tx
    ...from blinglights (pretty sure priuschat used to sell them)...$69
    http://cgi.ebay.com/ebaymotors/Toyo...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
  6. Tideland Prius
    16,403
    Not that I know... most kits assume you want some sort of light when you install them
  7. Tideland Prius
    16,403
  8. Mylar
    Mylar Member
    163
    36
    Cincinnati, OH
    2019 Prius
    I'm looking into upgrading my 2006 Prius fog lights to HID. I found this kit on eBay. It's more expensive than the other kits. Has anyone used this kit?
    04-09 Toyota Prius 6000K 9006/HB4 JDM HID Fog Lights - eBay (item 190475267282 end time Dec-31-10 23:51:36 PST)
    Any input would be appreciated!
  9. comatoes
    comatoes #GreenLife
    288
    17
    How about those pics? :)
    How do you like them a year later?
  10. XMAN LIVE
    XMAN LIVE "Just have Fun!"
    271
    23
    49
    Cypress TX
  11. Philatc
    Philatc Pushing Tin
    137
    46
    Calfornia
    Will these lights void anything? I have a 2010 Pkg 5 and worry about the increased draw from the new bulbs. I dont know anything really about HID bulbs thank for the input.
