A/C not so cold!
Discussion in 'Gen 3 Prius Main Forum' started by Alexma, Apr 14, 2011.
  1. Alexma
    Alexma Member
    103
    SoCal Chino Hills
    Since there are no belts on my 2011, is the A/C compressor just as effective in the new design?
    The A/C seems to be a little weak, that is not that cold.
    Going to have service check it out @5k service.
    Anyone else feel that the "coldness" is not up to par?
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    I've felt it can be weak as well but only when temperatures around here have been in the high 90's and above with the sun out fully. For most days, it is fine with me. Were you running in ECO mode while you had it on? That affects the A/C.
    For me, the changeover from freon killed the 'coldness' of a/c years ago...
  3. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    As long as i don't have it in eco it's seems just as cold as any other car. I always leave it in eco and it still does a good job here, and it does get into the mid 90 for at least 30+ days a year with a heat index over 100 alot of the time. Gen II also didn't drive the ac with a belt so its nothing new.
  4. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    My wife doesn't think the A/C is very good either. But as adamace1 wrote, in ECO it is a bit less aggressive with the A/C so if you're driving in ECO and feel it's inadequate you might want to try normal mode.
  5. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    I don't think it's AC but rather movement of air. Yes, the AC is a bit slower to get going (though I want to be clear: it can handle cooling the car on a very hot day), but then I think it is for heat, too. The fan system just doesn't seem to gun out air like a jet engine as it has on my other cars.
  6. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    This is interesting. I live on the coast with the 95 degree and 95% humidity days and my AC does fine. I have to turn the vents away from me at times it gets so cold. I use Normal mode all of the time and not Eco. I am wondering if Eco is causing some of these issues.
    My wife does not like the fact that the fan is not blowing air as soon as you turn the car on. I like the fact, though, that the system waits until the air is either cool or warm before it starts blowing air.
  7. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    ECO mode manages a/c differently than NORMAL mode. ECO turns a/c compressor on-off more frequently to enhance engine economy.
    If you're using AUTO function on the air controls, flow adjusts according to inside cabin temps. So for those who like high air volume flow, you might want to manually adjust air speed.
    With all that said, I'm surprised y'all notice so much temperature variation. I use ECO all the time, but do not use AUTO. I find the a/c coldness and air flow satisfactory. If anyone has warranty left, let the dealer check it out and let us know.
  8. ETC(SS)
    7,157
    The A/C is rather weak in this car, but I've found that I don't notice it until the temperature and humidity tie in their race for triple digits down here on the Redneck Riviera.
    Like some others, I don't use Auto and I keep the car in ECO most of the time, and so this may be a case of semi-imposed frugality.
    I don't think anything is "wrong" with the car (inasmuch as I can tell from the OP's post) but rather some cars have really REALLY good HVAC systems and others don't.
    My G3's HVAC system isn't as "cold" as my last work car....but I'm not begging my boss to give me my old car back! :D
  9. Politburo
    Politburo Active Member
    971
    208
    A system designed for R-134a should not have any problem. Your perception may be colored if you had a vehicle where a conversion from R-12 to R-134a was done. In those cases, since the system was designed for R-12, the performance will be poor.
    It's possible, for weight/space/cost reasons, that Toyota slightly undersized the GenIII system compared to other vehicles.
  10. Alexma
    Alexma Member
    103
    SoCal Chino Hills
    Thanks for all the replies!!!!
    Here was the case.....
    Coming home from AZ freeway speeds, 70-80 mph in "normal" mode.
    Outside temp read 72-76 degrees.
    The system was on LO...which I also tried to play with the degrees to see if it made a difference.
    Both my Tundra and Sequoia with rear air gets pretty cold which run on the newer R134a.
    Being new to the hybrid, I thought it might have to do with the electric compressor.
    I tried to look for the heater core valve to see it it was closed all the way, didn't see anything like that.
    That it may be different because of it being a hybrid.
    Going to drive it today, going to sick a thermometer in the vent today and see what temps I am getting.
  11. Alexma
    Alexma Member
    103
    SoCal Chino Hills
  12. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    The A/C works fine on both of our Gen 3 Prii in sunny So. California. I wish A/C has less impact on FE, but you don't get something for nothing.
  13. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    If you want a stronger response from the AC, drop the desired temperature to 68F.
  14. unkprius
    unkprius Member
    152
    Don't forget the 3 ft windshield staring down on an almost equally big -black- anti-reflective(yay) heat absorbing(boo) dashboard. You can feel the heat rolling off of the dash when the sun is beating down, regardless of outside temp or how much the ac is running.
  15. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
  16. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    I have no 3rd gen, but the the Prius has been using an electric A/C compressor since the 04 model year. The 3rd gen went beltless by moving the water pump formerly driven by a belt to an electric one.
  17. Alexma
    Alexma Member
    103
    SoCal Chino Hills
    Thanks again everyone!!!
    Does anyone know if there is the typical heater valve on the Prius like the ones found on my other two trucks along with camry, etc.
    Does anyone know how the Prius makes heat? Is there a heater valve or does the hybrid use a different method to make heat?
  18. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    did you set the the air to recirculate or to take in outside air?
    recirculate will make it cooler quicker.
  19. Alexma
    Alexma Member
    103
    SoCal Chino Hills
    Recirc....that cools the cabin the fastest by cooling cooler air.
    Problem is.........the air was still not that cold.
  20. bretaz
    bretaz Member
    475
    52
    Surprise, Arizona
    I have decided the AC sucks in this car. The first few days we had in the 90s, I knew I was in trouble. I can't wait for it to hit 120.
    Good thing we still have the 99 Solar a for the summers.
