1. Flying White Dutchman
    4,376
    313
    its getting hot... and now the a/c is not working
    i checked all the fuses
    now is there a little glas thing with next to it a dop saying "H"
    is this to check if there is still coolant inside the airco system?
    because i can not see anything only metal color inside?
    maybe tomorrow a visit to the dealer..
  2. Patrick Wong
    18,200
    6,491
    The "little glas thing" is a sightglass. The purpose of this is to allow you to view the refrigerant status when the compressor kicks on.
    I suggest that after the car is READY, you have a helper press the A/C Auto button to turn on the air conditioner while you observe the sightglass. As the compressor turns on, you should see bubbling in the refrigerant, then the bubbling should go away after pressure is built up. The refrigerant is clear in color.
    If you never see any bubbling, this means that the compressor did not turn on. If you continue to see bubbles, this means that you have insufficient refrigerant in the system.
    The H cap is for the valve that accesses the high pressure side of the system. There also is an L cap, for the valve that accesses the low pressure side of the system. The purpose of these valves is to allow the tech to measure the pressure on both sides of the system. Additional refrigerant is added via the low side valve.
  3. Flying White Dutchman
    4,376
    313
    when the car is in ready mode and the a/c on
    there is now noise from the engine bay.
    only thing i hear is the fan on the passenger side of the car turning full speed
    i can not hear the electric a/c motor running and also the 2 fans with the radiator don't turn.
    after a wile the ice turns on.... and thats it..
    but after the ice shuts down again i hear a noise from the left radiator fan and its not turning.. not sure its the fan but its close to there!
    i looked at the glass and there is nothing to see
    i also did a fault code readout from the canbus and there are no faults.
    and also the dashboard is not giving any warnings.
    still there is no cool air.....
  4. Patrick Wong
    18,200
    6,491
    Your initial msg said that you checked the fuses. Did you also check the driver's side junction box (hidden behind the instrument panel to the left of the steering wheel) that contains the 10 amp A/C fuse?
    From your second msg, I take it that the cabin ventilation fan is operating, but that cold air does not come out. My repair manual lists the following possible trouble areas:
    1. Volume of refrigerant
    2. Refrigerant pressure
    3. Pressure switch circuit
    4. Air mix damper control servomotor circuit
    5. Air mix damper position sensor circuit
    6. Room temperature sensor circuit
    7. Room humidity sensor circuit
    8. Ambient temperature sensor circuit​
    9. A/C inverter circuit
  5. inventor00
    inventor00 Active Member
    1,131
    60
    Phoenix, AZ
    Have you driven on any dirt roads with rocks on lately?
    We had a stone go through the grill and kill the A/C compressor summer before last- they have still not changed the grill to prevent this from happening...only about a $750 cost.... and not covered by the warrenty - since it is "Road hazard"
  6. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    I'm surprised more Prius cars don't have dead A/C over this. Before I fashioned the grille guard, I was really surprised at how pockmarked the condenser headers were from normal road debris.
    Although driving a lot on gravel would probably hasten the process, I think just driving on normal roads will eventually damage the condenser. If the A/C is not engaging at all, the LP switch has cut it out. That usually means most to all of the coolant is gone
  7. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    Jayman,
    Grill guard? Can you pontificate please?
  8. Flying White Dutchman
    4,376
    313
    because of my stupid job i can not go to the dealer for a few days
    so have to wait and see..next week maybe!
    i don't hope its the problem because of road hazard and that i have to pay that lot of money....
    and yes i checked fuses under the hood and under need the steering wheel and also the 12 volt fuses in the back!
    isn't there supposed to be warming when the airco compressor is not working or pressure is to low?
  9. jayman
    13,439
    641
    Winnipeg Manitoba
    I think I posted this a *long* time ago, back in '05, so here it is again.
    I went to Home Depot and got a roll of gutter guard stuff. It's a plastic mesh to keep leaves out of your gutters. I got mine in black. As you can tell from the photos, it blends right in. With the zip ties total cost $15
    Not too unusual to find rocks lodged in the gutter guard. I guess that means it's doing its job
    Would you also like me to post photos of the A/C condenser header tube? It was already badly pockmarked by the time I put on the gutter guard stuff
  10. jayman
    13,439
    641
    Winnipeg Manitoba
    Not really. The tech is expected to go through a standard A/C diagnostic
    With my FJ Cruiser, in winter I pull the clutch relay for the A/C compressor. By default, when the airflow is set to Defrost, the A/C will try to run unless the ambient temp sensor cuts it out
    As I have a heated garage, that means even at -40 the A/C compressor will try to run for a few minutes, I figured that couldn't be good for it (PAG oil too thick below +5 C)
    With the A/C clutch relay out, whenever I pulled out of the garage and the system commanded the A/C to run, the LED in the A/C button would flash. No other indication it had "failed"
  11. Flying White Dutchman
    4,376
    313
    after the dealer did a refill it workt BUT i can now see bubbles and not going away
    so there is a leak.
    will see what the dealer got to say about this!
