A/C redirects air to floor vents even with dash vents selected.
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Chuparosa, Jun 21, 2024.
  1. Chuparosa
    Chuparosa New Member
    Rio Rico, Arizona
    It's 106 degrees outside. I had a long drive this afternoon and the A/C works great except that every two or three minutes I have to hit the mode button again because it shifts by itself from cabin air to floor air. I don't usually realize it until I'm uncomfortably warm and my feet are cold. Is this fixable?
  2. Air_Boss
    Air_Boss Senior Member
    4,124
    1,146
    New Yawk
    If you can drive internal air mixer and diverter door position via the mode switch, the motors work, so it could be an ‘AUTO’ logic issue. I think I saw the steps to enter diagnostic mode. Suggest you search on that term.
  3. Chuparosa
    Rio Rico, Arizona
    Thanks. I have NO idea what you just suggested, but my mechanic will. I appreciate the reply.
  4. ChapmanF
    16,944
    Sounds like it could be an intermittent signal from the 'mode' button, so the A/C amplifier thinks it's doing what you're telling it to.
    There might be a test mode available where you can press all the buttons and make sure they show pressed when you do, and not pressed when you don't. I haven't looked for that specifically, but if there's such a test mode the repair manual will cover it.
    Toyota Service Information and Where To Find It | PriusChat
  5. Air_Boss
    4,124
    1,146
    New Yawk
