A radio 'Did you know?"
Discussion in 'Gen 3 Prius Audio and Electronics' started by Jetboy, Aug 27, 2011.
  1. Jetboy
    Jetboy New Member
    Great Lakes Bay Region Michigan
    Did you know that you can turn on the radio by pushing the band select button? I only found out by accident that it works that way.
  2. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    That, and turning on the overhead map lights by pressing (your other post), are but 2 items contained in the owners manual. ;) Worth a read--lots of good stuff in there.
  3. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    Also from the steering wheel
  4. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    It's too bad there isn't an alternate owners manual stripped of all the cautions, legalese and completely dumbed down to the point they are hard to follow instructions. I doubt it would be more than 30% as big as the regular owners manual and it would be easier to find useful information.
  5. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    you should be able to turn it off by holding down the mode (or whatever it is on the genIII) button on the steering wheel.
  6. V8Cobrakid
    3,790
    152
    you really should read the manuals... or finish reading them. there are a lot of little things like that to this car.
    did you know at speed (over 8mph) you can't switch the car into another gear? it goes to N.
    if you turn the car off without parking it, it will park it for you...
    the list goes on...
  7. liskipper
    liskipper Member
    373
    79
    Long Island, NY
    I think that you meant to say that it will engage park.
  8. Mendel Leisk
    40,242
    I think "do you know" is a good thread idea. Only: maybe just one thread, for any and all? The manual is a big, verbose document. Very easy to discover, and then forget things. Worth pencilling in such findings in on the back page I guess.
    One I've forgot: anyone recollect the auto-window relearn procedure for 3rd gen prius? What I mean is the one-touch up or down function. If the battery's disconnected it can be lost.
    I've been looking through the manual, no luck. Might have just read it on the internet, for that matter.
  9. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I know it's in the shop manual and think it's not required after the battery is disconnected, just after components like the window motor are replaced. From page 5423 in my .pdf manual, YMMV
  10. V8Cobrakid
    3,790
    152
    they changed it for gen III. gen II, you have to do it (only the drivers window has auto)
