A tip: buy the Toyota oil filter wrench
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by brick, Apr 3, 2007.
  1. brick
    brick Active Member
    1,083
    79
    Upstate NY
    I learned the hard way last night that the Toyota oil filter wrench is an essential element of the first oil change. I can usually get those things with my bare hands, but I swear it must have been epoxied on in Japan. No problem, I figured...just get one from NAPA. NOPE! The stock Napa size is just a hair too large, and the OEM filter spins. Next I tried one of those strap wrenches, which just began to dent the filter. By the time I figured out I was no-go on the filter removal the Toyota dealer had already closed. My only recourse was to re-install the old oil (which had been drained into a sqeaky-clean contaner, fortunately). A 15 minute job was turned into a 1.5hr+ exercise in futility because I didn't have the right tool. Don't make my mistake!
  2. subarutoo
    subarutoo New Member
    1,213
    23
    Chatsworth, CA
    I got a $5 Walmart filter wrench that fits on the end of the filter with a 3/8 socket drive. If you don't jack the car, you have to kind of change it by Braille, but it works every time. I even use it to give it a little tug to snug it up, not trusting hand tight on something I can barely reach or see properly.
  3. jeneric
    jeneric New Member
    442
    Redmond, WA
    You didn't want to ram a screwdriver through it?
  4. etyler88
    etyler88 etyler88
    450
    Dover, DE
    <div class='quotetop'>QUOTE(jeneric @ Apr 3 2007, 02:23 PM) [snapback]417123[/snapback]</div>
    Screwdriver method always works.
  5. tochatihu
    tochatihu Senior Member
    9,457
    3,656
    Kunming Yunnan China
    2001 Prius
    10-4 on the screwdriver. Another possibility is to wrap duct tape around the base of the oil filter to inprove the fit of those 'oversized' filter end wrenches.
  6. subarutoo
    1,213
    23
    Chatsworth, CA
    <div class='quotetop'>QUOTE(etyler88 @ Apr 3 2007, 11:26 AM) [snapback]417128[/snapback]</div>
    I have actually done that on a truck at work that the filter wouldn't budge. You'd need a very short screwdriver for the Prius, thus, no leverage advantage. Go to Wallmart, buy the tool.
  7. brick
    brick Active Member
    1,083
    79
    Upstate NY
    I thought about the screwdriver method for a moment but realized that I would be SOL if it didn't work. At least this way I was able to punt and keep my service appointment for this afternoon (which I did...problem solved $25 later.) I walked into the parts department and saw that their filter wrenches were just generic tools of the right size ($7 for theirs.) So I guess the point isn't that it has to be their wrench, it has to be one that works.
    Looking back at it, part of the problem might be that the filter is so small relative to the big, wide Volvo filters that I'm used to. They fit much better in the hand and it's easier to get some leverage. (Major PITA to get to, though...the Prius is laid out much better.) Oh well. This operation will go much smoother at 10k. Next time I won't have a service writer telling me that synthetic oil is somehow bad for it. ;)
  8. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    I got one of the end-cap style wrenches and also found it a bit
    loose, but two smallish strips of gaff tape fixed that. It's nicely
    snug and holds itself on the filter once seated. On my first couple
    of changes I got lucky and managed to get the filter loose by hand
    and/or some simple grip tool or other, but decided to go get the
    wrench on general principles since unless you're laying at just the
    right angle under there it's kind of hard to get your hand in around
    the back of the filter at all.
    _H*
  9. sub3marathonman
    sub3marathonman Active Member
    557
    75
    <div class='quotetop'>QUOTE(hobbit @ Apr 3 2007, 09:10 PM) [snapback]417348[/snapback]</div>
    OK, so now not only are we impressed with hobbit's Prius knowledge, we know he has incredible grip strength too.
    I too couldn't get the OEM filter off, and ended up crushing it with the strap wrench before it would budge. And yes, I had to buy the new strap wrench because my oil filter wrench wouldn't fit the original one.
  10. c4
    c4 Active Member
    607
    51
    I got the filter off by hand the first time, but it took a lot of grunting and cursing.. I think the main problem is that you really don't have the grip or leverage when you're lying on your back under the car.. The second time, I bought one of those end-cap wrenches and they slip and pop unless you really get them on the filter (ie, get a hammer and give it a few taps so that it goes right onto the filter), and then they work fine, but it also becomes a real pain to get the wrench off the filter afterwards..
    I saw an oil filter wrench set a few years ago that was a great idea, and I'm still kicking myself for not picking one up because they seem to have disappeared off the face of the earth... They looked like a set of plastic tumblers with grips on the outside, but on the inside, there was a metal insert that fit over the end of the filter, so they way they worked was that you'd pick the size of wrench you need, and the whole thing would slip over the filter and give you good grip to remove it, while the plastic cup would catch any oil spilling from the filter as you removed it, so no drips and no mess.. If anyone comes across a set like this in their travels, please, please, please let me know!
  11. u4iia
    u4iia New Member
    24
    WA
    <div class='quotetop'>QUOTE(brick @ Apr 3 2007, 10:08 AM) [snapback]417084[/snapback]</div>
    I purchased a plastic end cap filter wrench from Wal-Mart. Plastic was the wrong move. Striped in a heart beat. Went through my favorite list of curse words then purchased a metal one from the dealer for 8 bones. I could not believe how tight the factory put that thing on. I held my breath, broke a sweat and grunted that thing off. Took the fun out of my first oil change. Oh well...
  12. BethlehemPrius
    BethlehemPrius New Member
    180
    Bethlehem, PA
    Don't know where to buy one as my dad gave me a spare he had, but they make wrenchs that attach to the end of a socket and then when you turn it, it grips down on the filter not allowing it to slip.
  13. priusFTW
    priusFTW Gen III JBL non Nav
    434
    White Mtns New Hampshire
    <div class='quotetop'>QUOTE(BethlehemPrius @ Apr 10 2007, 04:47 AM) [snapback]420698[/snapback]</div>
    I agree with the OP, I also bought the wrench direct from Toyota for a few bucks. Fits perfectly.
  14. rudiger
    rudiger Active Member
    696
    45
    Cincinnati, OH
    <div class='quotetop'>QUOTE(brick @ Apr 3 2007, 01:08 PM) [snapback]417084[/snapback]</div>
    Are you sure you got the correct 65mm NAPA wrench? There are several different ones and some of the cheaper versions aren't very good. Autozone, in particular, sells a cheap, metal, 65mm end-cap wrench that is of very poor quality and has a lot of play. Likewise, the plastic, dual-use oil filter wrenches that places like Wal-Mart sells can have disasterous results, as well (particularly if the wrong 67mm end is used).
    I test-fit an OEM Toyota filter with the specific wrench from NAPA below and the fit was perfect. In fact, it was the best of any end-cap wrench I had found:
    NAPA Oil Filter Wrench
  15. Bob64
    1,540
    93
    Virginia
    Any other opinions on the filter wrench that is sold by the dealer? Does it slip more or less then the alternative ones that people have mentioned?
  16. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    <div class='quotetop'>QUOTE(Bob64 @ May 12 2007, 02:31 AM) [snapback]440433[/snapback]</div>
    I can't compare; all I've used is the Toyota wrench. But an alternative couldn't slip any less. As Brick and others report, it fits perfectly.
  17. bobc
    bobc New Member
    361
    Durham, NH
  18. Ghostrider
    Ghostrider New Member
    121
    You don't have to buy the Toyota wrench. Take the oil filter to Parts Plus and they have a metal cap that fits perfectly for about 4-5 bucks. Plastic is not a good choice since the square holes tends to warp.
  19. rudiger
    696
    45
    Cincinnati, OH
    <div class='quotetop'>QUOTE(Ghostrider @ May 12 2007, 01:53 PM) [snapback]440642[/snapback]</div>
    I agree, although it is possible to find a cheap metal end-cap wrench that is just as bad as a cheap plastic one. AutoZone sells a metal 65mm end-cap wrench that looks to be of very low quality and doesn't fit the Toyota OEM oil filter very well. NAPA also sells a cheap metal 65/67mm dual-use end-cap wrench (BK 7759010, $3.99) which I suspect is the bad NAPA wrench that's "just a hair too large" to which the OP refers.
    However, NAPA sells another, more expensive, metal, 65mm only, end-cap oil-filter wrench (SER 3253, $8.79) which fits the Toyota OEM oil filter perfectly. In fact, it fit the OEM filter the best of any end-cap wrench I could find and I cannot imagine this particular NAPA end-cap wrench ever slipping.
    In short, the OP just bought the wrong metal NAPA end-cap oil filter wrench.
  20. ystasino
    ystasino Active Member
    793
    50
    Tucson, Arizona
    How difficult is for a novice to drain and replace the oil and change the Prius oil filter? Does it do much to the warranty?
