ABS, brake and traction lights are on, but only sometimes!
Discussion in 'Newbie Forum' started by Lazo, Apr 5, 2019.
  1. Lazo
    Lazo New Member
    Naperville, IL
    I have 2013 Prius gen II. On one the coldest days of this winter ABS, brake and traction lights came on. Took the car to the Autozone near me for reading error codes. The Autozone guy tried to read error codes but couldn't and said this could be because some of the sensors got covered with ice. Couple of days later when weather got warmer I checked if the lights were still on. They were on at first, but after a couple of miles of driving they disappeared. So I thought the autozone guy was right and now everything is fine. But after some time the lights came on again even if the weather was not freezing. Then again disappeared. Three days ago they came on again only for a short time. I decided to find out what was going on and bought Mini VCI cable and Techstream. Scanning shows the code C1466 - Rear Speed Sensor RH Circuit. Does anyone know what that is? If something was faulty, then the lights should be constantly on, right?
    Any help is appreciated.
  2. Lazo
    Lazo New Member
    Naperville, IL
    Yesterday I cleared the error code with a pin method and the error code is gone for now. I don't know if it ever comes back or not. Before I posted the first post I went to a car wash. Maybe it was just a dirty sensor and it was cleaned by car wash and that's why the error is gone. Could it be just a dirty sensor or is it too far from being cleaned by car wash?
    51,972
    the speed sensor is part of the hub. it could be a bad or corroded connector, or it might need to be replaced.
    i don't think it can get dirty.
    just keep an eye on it and see what happens.
  4. Lazo
    Lazo New Member
    Naperville, IL
    Thank you bisco.
    So far so good. No lights are on for the last couple of days. But I still wonder what could trigger that error code and disappear. Yes, I will keep an eye on it and report back if it reappears.
  5. bisco
    51,972
    ice may have impacted it
    Lazo likes this.
  6. Lazo
    Lazo New Member
    Naperville, IL
    Ok, the lights are on again. They are not constantly on, but sometimes on and sometimes off. Where is that hub and how do I replace it?
  7. bisco
    51,972
    you should purchase the service manual at techinfo.toyota.com, and do the troubleshooting. then follow the repair procedure.
    alternatively, there may be youtube videos. check in with @NutzAboutBolts on youtube
  8. Lazo
    Lazo New Member
    Naperville, IL
    Thanks, I'll try that. I watched some YouTube videos about replacing speed sensors for other different cars, but could not find any video specifically for Prius. All of them were pretty straightforward, remove the wheel, locate the sensor, remove the bolt holding it, unplug the wire from the other end and remove the sensor. But in Prius the sensor is covered with a some metal frame and I could not find bolts holding it. You're right, I do need a repair manual for that project.
  9. Lazo
    Lazo New Member
    Naperville, IL
    This video really helped to understand:
  10. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    I thought they stopped making Gen 2’s in 2009? (n)
  11. Lazo
    Lazo New Member
    Naperville, IL
    I thought my car was gen 3 too, but when I went to Toyota dealership for software update, the guy working there said it was gen 2. I watched some gen 2 wheel hub change videos, I noticed that gen 2 rear wheels don't have calipers at all whereas mine has. That means mine is not gen 2. Probably Toyota guy was simply wrong and I mistakenly gave him a benefit of doubt:confused:
  12. bisco
    51,972
    yours is gen three. he probably doesn't know about gen one :whistle:
    Raytheeagle likes this.
  13. Lazo
    Lazo New Member
    Naperville, IL
    I replaced the rear right wheel hub and now those three lights are on all the time. I checked with Techstream, the same error "1466 Rear wheel sensor RH Circuit" pops up.
    Any ideas?
  14. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    Get a friend to drive the car for you. Sit in the passenger seat and go online with techstream and look at all 4 wheel speeds while driving down the road at a steady speed. Highway and on cruise control would be best, if possible. If there's a sensor problem it should be obvious.
  15. Lazo
    Lazo New Member
    Naperville, IL
    I'll try that too, if I find a not busy person:), thanks. Meanwhile I ordered wire harness from ebay. I just did not want to believe that it could be because of the bad connection as the problem appeared only when I press on brakes. I was quite sure that it had something to do with the sensor itself. Are there any fuses to check additionally? I'll replace the harness and see if that solves the problem.
  16. Lazo
    Lazo New Member
    Naperville, IL
    I replaced the harness, but nothing has changed. Then I thought maybe computer has to learn about the new bearing and reset the lights with pin method but the lights came on again. I checked the ABS fuses under the hood, all of them look fine. Then I checked with Techstream's Active test, as suggested by TMR-JWAP, I get all sorts of readings (reminder: my issue is with rear right sensor):
    When I was changing the hub assembly I noticed that parking brake cable was not very tightly attached to the caliper, I mean it was fairly easy to remove its metallic round head from the caliper's hook. But it's not loose, just not very tight. Could that be the sign of something?
    Any ideas are appreciated.
    #16 Lazo, Apr 18, 2019
  17. ChapmanF
    18,241
    I see nine screenshots there, where in every single one of them the front left, front right, and rear left speed sensors are showing 27 to 30 mph and the rear right is showing zero.
    I don't know that "all sorts of readings" would be the way I'd describe that. I think it would pretty much convince me there's an issue with the rear right sensor.
    So far, it seems like the hub us new, and the "harness" is new; I trust you mean the short harness segment from the sensor itself up to the car's floor harness.
    So the troubleshooting will probably just be a matter of getting a meter and the wiring diagram and tracing further along the path from there to the ECU, until you know where the problem is. The repair manual should have ideas to help with that.
  18. Lazo
    Lazo New Member
    Naperville, IL
    I don't know why but I was focused on the wheel acceleration part and did not even notice that each wheel speed data was there. That's a miss on my part. Thank you for pointing that out. You're right, RR wheel is 0 all the time. Is there any way to check if the new hub's sensor is working? I know one way would be to install that hub on the left side and see if it shows any values there, but that's a lot of work for just checking and plus I may mess up a good hub assembly on that side. I just don't want to move on to ECU before I know the sensor is not broken.
    #18 Lazo, Apr 19, 2019
  19. ChapmanF
    18,241
    Oscilloscope. The waveforms are shown in the manual. With that, you can also just follow along down the wiring until you come to the place where the waveforms aren't.
    I would certainly follow along the suggested troubleshooting steps in the suggested order, before jumping to the ECU. Those things are solid state and, while I know they can fail, it wouldn't be my first guess, any more than I'd call a coin to land on edge.
    Also, you wouldn't find me betting against the sensor in a new hub. There's just not enough to go wrong; it's going to work until the day magnets aren't magnets, or coils of wire aren't coils of wire. I guess there could be one with a manufacturing defect that got past QA, but that would be another coin edge.
    That leaves wiring and connections, which are where most of my attention would be going.
    #19 ChapmanF, Apr 19, 2019
  20. Lazo
    Lazo New Member
    Naperville, IL
    I am returning the hub that I bought through amazon. I watched some YouTube videos on how to check if speed sensor works or not. Such as this:
    Turns out it can be checked simply by measuring AC voltage when spun, mine does not change at all and stays in 0. I hope this is the culprit, because I really don't want to dig into the skid control unit as it is allegedly located deep in the engine compartment and have to remove a lot of things to get to that.
    #20 Lazo, Apr 19, 2019
