ABS+Slip+TirePressure lights on
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Mykola, Aug 3, 2015.
  1. Mykola
    Mykola Junior Member
    St. Louis, MO
    During normal driving, I had all of these three lights appear on dashboard at the same moment. The car still works fine, no apparent problems.
    I have 19K on it, it was in an accident with the previous owner (front right impact).
    What could cause the lights on? Real problem or sensor malfunction?
    Should I take it to Toyota dealer to check or reset lights and see?
  2. citroenjohn
    citroenjohn Active Member
    139
    103
    Mid-Michigan
    I have 45,000 miles on my C and have never had this happen. Once in a great while the traction control light will come on momentarily when I hit a bump. To me sounds like something weird is going on with one of the car's computers, but, I know nothing about how they work. Cars are becoming so complicated I sometime wonder if I have the necessary skills and knowledge to put air in the tires. Having said that the cars of today sure are reliable and run good, especially my C.
  3. Mykola
    St. Louis, MO
    I inspected the sensor on the side that was involved in the accident and found the problem - sensor wire was hanging too low and touching the tire. It was rubbed off to the point of losing connection with the computer. I reconnected the wires and those lights were gone after a few seconds of driving.
    This may be useful to others: a few lights at once probably mean just a sensor or wire problem, not a real issue.
