ABS, VCS (!) Lights on after bearing change - tried resetting
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by JMPrius07, Feb 7, 2024.
  1. JMPrius07
    JMPrius07 Junior Member
    Hello,
    I was wondering if anyone could suggest the next step for me in this issue.
    I changed the front right bearing, which I had done before. When I test drove it, the lights came on.
    I did the paper clip jumper and everything was ok and then reset it with the 8 pumps of the brakes.
    When I started the car, the lights turned off, but when I drive it about 100 yards, the lights come back on.
    I checked the brake fluid level and all good. My battery was replaced about 2 years ago, so I dont think it is that.
    Any ideas what to look for next? Thanks for any help
    225XXX miles
    PriusPaddler likes this.
  2. Danno5060
    Danno5060 Active Member
    389
    200
    Wyoming
    Pull the speed sensor and see if there's anything stuck to the end. Check the cable is plugged in and routed properly.
    Check to see if that dust cap that protects the tone ring on the CV axle is still there, and that the hole in the dust cap is lined up with the hole in the steering knuckle.
    That's all I got offhand.
  3. Brian1954
    Brian1954 Senior Member
    2,227
    876
    South Central PA, USA
    If the warning lights are on, you have trouble codes that need to be read. Once you read the trouble codes, come back and post them for further help.
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,048
    1,974
    NJ-USA
  5. JMPrius07
    Thanks everyone. It was the speed sensor. I took it off and had some debris on it. Cleaned it up, reset using paperclip, and all good now.
    Danno5060 and Brian1954 like this.
