AC light is Always lit/on
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by priinoob, Sep 16, 2023.
  1. priinoob
    priinoob Junior Member
    Ma
    Hello folks. So I have this issue with AC button is always lit. When I press it to disable or to switch the regular fan nothing happens. I can turn it off completely with OFF button but whenever I use fan buttons it always lits the AC led even when it’s not in defrost or floor mods. What might be causing this issue? I tried generic troubleshooting with holding down two buttons to see if I get any codes based on this video:
    AC works fine when it comes to cooling or heating but I don’t understand why it wouldn’t switch to regular fan mode. I tried to hold it down, wiggle it to see if the button is stucked but did not help.
    There is also no lights on the dashboard.
    I appreciate any help.
    50,849
    is the compressor always on when the button is lit?
  3. priinoob
    Ma
    I’m not sure where to look :/
    50,849
    looks like the lower front left around 4:30, but you really don't need to see it, it makes a pretty loud buzzing noise, especially after the engine shuts down:
    search
  5. priinoob
    Ma
    It’s not always on. Loud buzzing noise is gone after a minute or two.
  6. bisco
    50,849
    well, at least you know it's just the light and not the compressor.
    i guess you'd have to trace the schematic at techinfo.toyota.com
  7. priinoob
    Ma
    at this point i’ll just ignore and use ac heating in winter. is it bad idea?
  8. bisco
    50,849
    Not at all, that should work fine
    priinoob likes this.
