Lately when I turn the AC on my battery runs all the way down to two purple bars. The temp here is hot and it happens when I'm traveling at low speeds. The battery finally gets back up once I drive faster. Is this normal or is there something I should be doing to prevent this?
Normal, the A/C is driven off the battery at low speeds and when the battery gets low enough the engine must run to keep the battery at proper operating levels. It goes up once driving at normal speeds because that also causes the engine to run charging the battery back up. Basically, the car manages the battery and the gauge for it doesn't need much attention.
Very normal. My 2004 does it whenever it is 90deg or higher, especially when I am waiting in a drive-thru line.
It really helps, when you're stopped, to just reach over and hit the A/C button, leaving the blower on in recirc mode. I can usually tolerate that for the minute or so it takes for the light to change. Saves a bit of juice and I notice it on the battery guage.
Keep in mind that the AC is used to help cool the HV batteries. So it is best to leave the AC on in hot temps and let the computers take care of the HV batteries.
Yes, I think if in eco mode it will turn off the ac compressor at stop signs and lights and start again when you start off. Please correct me if I'm wrong.
You're wrong. What it does is make the compressor run less ALL the time, giving you slightly warmer air from the vents, and it lowers the blower speed all the time as well.
ECO mode also takes a LOT longer to cool the cabin temp down in hot weather. In hot weather I would certainly let the AC cool the cabin temp down to a comfortable level before switching to ECO if you are like me and more concerned with HV battery health than mpg.
I recommend sitting out stage 1a before getting the car underway. That way you can drive the wheels from the engine instead of just the battery and the generator has a chance to get ahead a little bit.
From the Toyota manual.■Operation of the air conditioning system in Eco drive mode In the Eco drive mode, the air conditioning system is controlled as follows to prioritize fuel efficiency: ●Engine speed and compressor operation controlled to restrict heating/ cooling capacity ●Fan speed restricted when automatic mode is selected.
If you read the fine print, you'll also see about how this is only true in "auto" HVAC mode. As soon as you adjust fan speed manually you lose auto mode and ECO HVAC mode status.
I understand that. Thanks. If you can't get cool enough by decreasing the temp. Just put in manual and adjust to your needs. I have always gotten cool in 95 degree heat but thats just me, YMMV! Cooler here than down south!
