AC replacement cost - $3500?!?!
Discussion in 'Gen 2 Prius Main Forum' started by Gooeny, Aug 10, 2011.
  1. Gooeny
    Gooeny New Member
    MD
    hi -
    My ac stopped working and the dealer said it's from major road debris (rock). I believe it. The fan works but the air is not cooled.
    The dealer said I need a new compressor, condenser, and sub-assembly hose to the tune of $3500! I'm taking it for a second opinion tomorrow but nervous of getting an outside -dealer repair. Assuming i actually need those parts replaced - is this a reasonable estimate???
    35k, purchased new, have had no problems and I take it in for recommended maintenance.
    Please help. Thanks.
  2. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    The condenser is cheap (< $200) but a new compressor's more expensive (closer to $1k). The oil is also not cheap.
    I'm not an expert but it still sounds high for the replacement so definitely get a second opinion.
    If it does turn out to need complete replacement you could do with finding somewhere that will buy salvage parts for you.
    They might be hoping your insurance will cover it, you're desperate to be cool and you wouldn't question the cost.
  3. Gooeny
    Gooeny New Member
    MD
    Yep - that's the first thing they said - call your insurance company. I do want to be cool but not that badly! They didn't even offer a used part, but I don't imagine that dealers would do that. If those parts did need to be replaced, am I definitely looking at a $2000 bill? I was hoping for 1k but it's not looking good...
    Thanks for your response.
  4. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,515
    38
    Santa Fe, NM
    Unfortunately, you are looking at $2000 for a repair with new parts ($1500 MSRP). But $3500? No.
    There is a place in Columbia, MD that was added to the hybrid shop list. Try them for a second opinion. It is not clear that the compressor needs to be replaced if you are not yet getting high voltage triangle of death codes.
    Preferred Independent Hybrid Car Repair and Service Shops | Hybrid Cars
  5. a_gray_prius
    2,927
    783
    IL
    FYI the condenser is typically deep inside the dash and they typically have to rip the whole thing out, so I believe $3500 if parts are $2000 (give or take a few hundred dollars)
  6. koolingit
    koolingit Member
    158
    51
    Mocksville NC, USA
    The condenser is located in front of the radiator and isn't hard to replace (hardwarewise). The evaporator is the one that's buried deep inside the dash.
  7. vertex
    vertex Active Member
    672
    143
    new york
    2018 Prius Prime
    The condenser is a few hours of work to replace. I bought a new aftermarket one for $150 3 years ago. You will need to add 10CC of ND-11 oil or CarQuest Hybrid oil, which I used. You should be able to find a good AC shop that knows about the Hybrid oil, and your total cost should be under $1000, provided that is all that is needed. The drier is part of the condensor, so you won't need to change that, as you do with most AC systems after a major leak.
  8. Gooeny
    Gooeny New Member
    MD
    Update - I took it to a shop that is very trusted by a co-worker and I was impressed with the mechanic. He said that the compressor (plus the dryer vent) needs replacing. Parts total 1k plus labor/special oil etc.
    He actually let me see the problem and pointed out the location of the compressor and what was wrong (the tube connecting to it cleanly broke off). Design flaw, anyone? Since moisture got in the compressor, he said it needs a new one. But he said I definitely don't need a new comdenser. You all are talking about a condenser only....I'm now even more confused!
    The shop I took it to was the 'third' quote, my preference is to go with a more local shop so I'm taking it in tomorrow. Who knows what they'll say... Thanks all and i'll keep you updated if anyone's interested.
  9. Patrick Wong
    18,200
    6,491
    1. Since your OP said that road debris caused your AC system problem, typically the condenser (located in front of the radiator) is the part that is damaged.
    2. However, your post #8 indicates that the AC compressor hose broke off, which is unusual.
    3. The reason that your dealer suggested replacing the condenser is that in the event that the compressor produced debris as the hose broke and the compressor failed, some debris may be lodged in the condenser and the passages in the condenser are too small to be effectively purged of that debris.
    4. Apparently, the tech at your third repair shop believes that is not a problem, hence he is not asking you to replace the condenser at this time. After the compressor is replaced, you'll find out whether any other problems exist or not.
  10. seilerts
    3,326
    1,515
    38
    Santa Fe, NM
    I don't think so, as yours is the first case of this that I have ever heard of. To be honest, rock damage to the condenser happens all the time, and that's what most of us were thinking.
    That said, I think you are in good hands with the second mechanic. Further, I would be interested in buying the old compressor. Please pm me if you are interested.
  11. vertex
    672
    143
    new york
    2018 Prius Prime
    The tubes to the compressor are removable. You should just be able to replace the tube, unless the compressor casting is cracked.
  12. seilerts
    3,326
    1,515
    38
    Santa Fe, NM
    I'm still trying to figure out how this could happen. You said a rock did this? Is the black plastic splash guard still in place underneath the car?
  13. bcphotography
    bcphotography New Member
    Fresno
    I
    That seems a little overpriced for a new ac unit. I would shop around, you can always find one somewhere other than the dealer for cheaper.
  14. mickey513
    mickey513 Member
    127
    Cali
    This seems very expensive but that's the price you pay when you visit their dealership. If I were you, I'll source all the cost of parts online from a Toyota site of some kind. These sites will usually sell you OEM Toyota parts at 20% + below MSRP. Take it to a local mechanic and have it done there, probably be less then $2k in the end. And I'm pretty sure the Prius AC runs on R134 Refrigerant, is $6 a can at Walmart or your local auto part store, probably need like 2 cans.
  15. lech auto air conditionin
    830
    601
    261
    san francisco
    !! IF YOU PUT TWO CANS OF r134 IN A PRIUS YOU WILL NEED A COMPRESSOR AFTER YOU JUST BURNED IT UP!!! one can = 12 oz two= 24oz :eek: please look up the SPEC: decal under the hood. If you are just 2oz over this is bad for a pruis on a hot day if you put two cans in " can we spell thermal nuclear melt down!!!""................:eek:
  16. mickey513
    mickey513 Member
    127
    Cali
    I didn't have the exact specs for AC fill but almost all at home auto AC recharge kit comes wit a hose and a guage attached to it that shows how much refigrant is left and how full the system is. Being a AC shop, I'm pretty sure you know what I'm talking about. No one in the right mind will goes pass full mark if the guage indicated it's full.
  17. seilerts
    3,326
    1,515
    38
    Santa Fe, NM
    I have manifold gauge envy
