Acceleration and maintenance
Discussion in 'Gen 2 Prius Main Forum' started by nkx1, May 27, 2005.
  1. nkx1
    nkx1 Junior Member
    Buena Park, CA
    I recently started researching new car options, and I was intrigued by the outstanding gas mileage of the Prius. And the 2004+ models look more attractive to me than previous models (no offense to pre-2004 owners). Anyway, per the subject line, I have two questions (not necessarily related):
    1) I read on an online article that 0-60 is somewhere around 10 secs. Is this accurate, and if so, are there any performance modifications to enhance this figure? I love the idea of an environmentally friendlier vehicle, but dislike the slowness.
    2) Since the Prius has an ICE and an electric motor (sorry, don't know the acronym), are there increased maintenance costs as a result of the two systems?
  2. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    1. It's accurate. Much more isn't really necessary and the Prius is tuned more toward economy than high-end performance. I can start from a dead stop and hit the highway at 75 mph if traffic is going that fast. I bet there are ways to boost that number, and a turbo module (or whatever they're called) has been mentioned- not sure if anyone's actually gone through with it.
    2. The hybrid powertrain is warranted for 8 yrs/80K unless you're in a CA emissions state, in which case it's longer. You'll see by searching the boards this is a common question and most of us owners have had no problems. Most of us actually have fewer maintenance costs than with our previous vehicles!
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    Get in a Prius and drive it before you decide it's 'slow' based on a 0-60 figure. I think you'll here from Prius owners, almost to the person, that they seem to accelerate faster from a stop than the vast majority of cars. The acceleration is very smooth, very seamless and much more than adequate unless you intend to drag race.
    I've heard one or two complaints from people who frequently need to merge very quickly into fast moving traffic in large cities that it seems 'sluggish' getting up to speed. If that's your situation then you definately still need to test drive a Prius to make sure it's good enough.
  4. nkx1
    nkx1 Junior Member
    Buena Park, CA
    Sorry, didn't mean to insult the Prius with the "slowness" comment. I currently have a '99 Toyota Solara, V6 manual, which has a reasonably respectable 7.0 sec 0-60 time. So going to a car with lesser acceleration would take some getting used to.
    I was also considering a '00 to '02 Corvette (I know, two different sides of the spectrum), but each car has it's advantages:
    Corvette = Girls, fun, gas mileage of around 20mpg avg, but potential high maintenance/repair costs.
    Prius = Low maintenance/repair costs, over double my current gas mileage, and a better conscience regarding the environment.
    I wish I had enough money for both, but unfortunately for me, I need to pick only one.
  5. galaxee
    9,810
    468
    MD
    There are plenty of girls who will want to check out your Prius if you get one :) Seriously, these cars get a lot of attention.
    That puts all the good things on the Prius side!
    But in all seriousness, drive it first and be sure. :)
  6. efusco
    19,891
    1,194
    Nixa, MO
    <div class='quotetop'>QUOTE(nkx1\";p=\"93459)</div>
    I'm sorry if my reply suggested that I thought you were insulting the Prius. That's not how I took it. I just reiterate. Go drive a Prius, I think you'll find it takes much less "getting used to" than you'd think.
    This is the thing...the "normal" acceleration speed, pedal pressure, etc for the Prius is probably pretty close to it's maximal...but doesn't feel or sound like you're flooring it. So maybe on average you're accelerating 0-30 in 5 seconds? (made up number, I don't know the actual 0-30 times)
    In your Solara you probably rarely, if ever, push it's acceleration anywhere near it's maximal...but given the power and speed and your implication that you like the power, maybe your 0-30 time is closer to 4 seconds. Can you really tell the difference?
    This'll have to be one of those 'trust me' issues until you go drive one for yourself. Hell no it's not a power machine...never claimed to be. But it does get off the line quite spritely and I've been very happy with it's pick-up in a large number of driving conditions over the almost 24k miles I've had mine.....and it was my car after a 254HP V8 Expedition.
  7. Godiva
    Godiva AmeriKan Citizen
    10,339
    I'll repeat what a few others have already suggested.
    Go drive one first.
    There is a thread on the board regarding the viability of the Prius as a chick magnet. Apparently it's quite good in that regard. And you can always pimp it up with some flames to enhance the effect.
    I've only had mine two months, but my understanding is that the maintenance will be less. And if I follow the regular maintenance I'll probably have very few problems. I expect I'll sell the car before I have to do any major repairs. note: I usually buy a new car every 10 years.
    As for the 0-60. This is something I've never quite understood. Rarely, if ever, in my driving life have I ever had to go from 0-60 in the shortest amount of time as possible. So the question is really what kind of power does the Prius have. Go test drive it. It's fine. That was my concern. I wanted to make sure it wasn't sluggish. Well, in point of fact it has more pep than my Saturn SC2 Coupe stick. I moved from a manual to the Prius. The Prius is more responsive from a stop than my old car. And it climbs hills just fine. I can pass cars going up hill. And there isn't that annoying ka-chunk when it changes gears like a regular automatic has. It's smooth as silk. And while I'm not a mechanic, I think it's the torque of the electric motor that makes it really responsive from a stop, since the ICE doesn't kick in until it is efficient to do so. I used to have trouble going up the parking garages at a slow speed in the Saturn. Not the Prius. It was like it was attached to a ski lift tow rope or something. No problem at all.
    Are you planning on doing a bunch of illegal street drag racing?
  8. Tideland Prius
    16,402
    It's adequate. I had 4 ppl and a load of luggage and shopping on a recent roadtrip and getting up to 60 is rather uneventful. The accelerator may or may not be harder to press than you're used to. I know half the time I'm accelerating, I'm not pushing it (mostly since I wanna conserve my mileage). You won't feel the acceleration cause it's linear and smooth.
    As for maintenance, all I've had so far is its first oil change. Nothing more.
  9. Denny_A
    Denny_A New Member
    133
    Fox Valley, WI
    I let my "green" brother (biologist, tree hugger) test drive my '05 just after it had rolled over its 600th mile. The "don't accelerate aggressively" window is 0-600 mi.
    He asked whether I measure acceleration with a stopwatch or calendar. So I invited him to check it out. It would be a first for me too. We were impressed. But, older folks like us are easily impressed. The fact that the motor cranks out 295 lb-ft of torque from 0 to 21 mph, before gradually ramping down with increased velocity, means that the initial acceleration is right smart. The Internal Combustion Engine (ICE) joins in to pick up the slack as motor torque ramps off.
    I was impressed. Brother, who was not expecting much, was impressed. In the old days (60's) he built a couple of street racing cars (40 Ford, etc.), and is a CART fanatic. He had floored the pedal, from a standing start, and zoomed to 60+ before backing off. He drove for about 45 minutes. By the time he pulled back into his driveway he was going hmmmm...hmmmm...hmmmm. Translation- who knew? Like Mikey - he liked it!
    Me too. 8)
  10. nkx1
    nkx1 Junior Member
    Buena Park, CA
    Well, if I end up purchasing a Corvette, there will inevitably by the obligatory humiliation of Musting and rice rocket owners at stop lights, so that would be entertaining.
    But if I can forgo that aspect of owning a car, it sounds like the Prius could be a very worthwhile vehicle in most other aspects, most notably gas consumption.
    Btw, thanks for all your replies so far!
  11. Mystery Squid
    Mystery Squid Junior Member
    This man knows what he's talking about! Seriously too... My Prius has attracted more chicks than any other car I've ever owned (and that list includes super nice 280ZX, mint '94 Mustang Cobra, '95 Mustang, etc.)... See thread entitled "Unbelievable Popularity..." :mrgreen:
  12. jamarimutt
    jamarimutt New Member
    985
    The Prius accelerates well for most uses; it sometimes hesistates for a split second when sudden acceleration is needed but this is not a problem. I am very satistied with the performance and, of course, the fuel economy.
    My 2002 GTI 1.8T took 8.6 seconds to reach 0-60, so there's no way a 1999 Solara is going to do it in 7 seconds. I don't miss the 8.6 vs. 10.1 seconds acceleration, nor the 22 mpgs.
  13. galaxee
    9,810
    468
    MD
    Correction: SHE knows what SHE's talking about. :)
  14. majordude
    majordude Member
    119
    &quot;The OC&quot;
    What did you decide? The Vette or Prius?
    Whereabouts do you live in BP? I am close to you.
  15. MGBGT
    MGBGT New Member
    42
    I went from a modified 2003 MINI Cooper S that could do 0-60 in well under 7 seconds, to the 05 Prius.
    I DO miss the handling of the MINI, but I DO NOT miss the 0-60 times. Even though on the books the Prius is slower, it makes you drive in such a relaxed way. It has more than enough pep for me, and I never felt it needed more ooommmmph. The transition was not at all difficult for me.
    M
  16. yoda
    yoda Member
    116
    San Diego, Ca.
    Heya,
    If the zero to whatever-speed number bothers you then I have to make a couple of points....
    First - as stated by others - DRIVE IT. Don't let a number stop you from a great purchase.
    Second - If you're looking to hot-rod the quarter-mile, then you're looking at the wrong car. Prius is NOT a sports car.
    Third - And I'm sore people are tired of reading this from me, but I'll re-say it for your benefit - My last car was a 1997 Trans-Am. A VERY fast vehicle and I don't - REPEAT, I DON'T - miss the power one bit. Triple-T accelerates just fine.
    Hope that helps....
    Yoda
  17. tleonhar
    tleonhar Senior Member
    1,541
    34
    Belle Plaine, MN
    I need to chime into here as well. I've been watching the hybrid market for a few years but was a bit unsure, then about a year ago, I drove by a Toyota dealer and thier demo unit was out front. Naturally I had to check it out, the sales guy came out, and I was in for my first test drive. My expectations were for a typical econo-box (albiet, damn nice looking econo-box), the car was anything but sluggish! In what seemed like nothing, I'm doing 77, then had to back off sort of promptly, I was on a 55 stretch of road and approaching a state patrol station (oops). I'v taken a couple test drives since, our salsa red package 4 is due in the week of 5/31 - 6/6.
  18. NuShrike
    NuShrike Active Member
    1,378
    What do you need faster 0-60 times for? Are there roads out your way that has some minimal acceleration rate? On the high/freeways how fast do people have to accelerate to merge anyways?
    The Prius has 295ft-lbs of torque from 0mph, and that's already like a mini-turbo.
    The Prius is also faster than the H2 0-60. I sure don't hear people complaining, or having problems driving that slow brick around.
  19. nkx1
    nkx1 Junior Member
    Buena Park, CA
    For the people who asked, "Why do you need to go fast?" I don't know, it's just a cool feeling to know that you can (and sometimes will) out perform almost any car you will see on the road. An ego thing I guess. As I mentioned earlier, it's exciting to have short little races at stoplights (not full-on street racing, but just a little fun), and to power past other cars on the freeway.
    As for the Solara not being as fast as I stated, here's a link to Motortrend stating the 1999 Solara V6 5-speed (my exact car) goes 0-60 in 7.1 sec. http://motortrend.com/roadtests/sedan/112_...ota/index1.html
    I still haven't decided what car want yet. I was looking at other hybrid choices as well, such as Accord, but none even come close to approaching the gas mileage of the Prius. I think I'll take a little while longer to decide what I want after test driving the Vette and Prius. Realistically, I probably wont be making a purchase for 6-12 months, but I feel confident that the Prius is a nice car after hearing all of your comments.
    For majordude, I live off of Dale and La Palma, accross the street from the mall. How about you?
  20. majordude
    majordude Member
    119
    &quot;The OC&quot;
    Wow, I go past you on my way home from work!
    (You probably haven't noticed me because I drive in stealth mode.)
    :mrgreen:
